Why is my samsung HT-D330K writing PROT and shutting down
3 Suggested Answers
  • 55 Answers
SOURCE: when i turn on my
PROT means that the AMP is protecting itself from damage due to bad or incorrect wiring or damaged and or incorrect speakers. Check your wiring and speakers.
If you find no problem then, DISCONNECT YOUR SYSTEM FROM THE POWER, disconnect your speaker wires...all of them, then reconnect the power ONLY, turn on the system and see if it still says PROT. If it does then your amp is damaged.
Posted on Feb 20, 2011
ecmorgan69
  • 279 Answers
SOURCE: Ihave a samsung dDVD player ht-d330k when I switch it on, it writes "prot"and immediately switches off. What should I do
There is an issue on the system board. Send it for repairs. Unless you're very knowledgeable about such matters, you're just going to damage it. I checked the manual, and that error isn't even listed.
http://www.theatresystem-manual.com/manuals/samsung/Samsung_HT-D330K.pdf
In the manual are also listed customer service phone numbers if you wish to call them. Good luck!
Posted on Aug 24, 2015
When I turn my system on, it waits 5 seconds, says "PROT" then shuts itself off.
There could be a short circuit in one of the speakers. This would cause high current flow thru the amplifier and result in self-protect. Disconnect all speakers from the unit and try powering up again. If there is no PROT, then reconnect speakers one by one until fault found or all speakers are reconnected.
Oct 04, 2015 | Samsung Ht- C550 5.1 Channel 1000 Watt...
Aug 24, 2015 | Samsung Audio Players & Recorders
When i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
Feb 20, 2011 | Samsung HTC550 Theater System
My system turns on then the word "prot" appears
its protection mode a failsafe put in place to shut down the unit in the event of a possible critical failure .......maybe a fuse.......maybe a dead system your budget will decide what your next step is ok good luck
Dec 17, 2010 | Samsung HT-Z310T Theater System
Whatb does it mean when the PROT comes on and then shuts off the dvd player
hello, prot mean protect the output transistor may have blown or a capacitor has poped or swelled up or the just could be a case of a dry joint
regards
shaun
Nov 22, 2010 | Samsung HT-X50 System
Samsung ht c550, enciende, saluda, lee y aparece el mensaje PROT y se apaga.
when i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
Oct 11, 2010 | Samsung HTC550 Theater System
When I put on my DVD player, it says "hello, DVD, LOAD, PROT" and turns off...
I assume "PROT" means some sort of protection mode. I would check to see if any of your speaker wires are crossed at the speakers or the receiver. If not you may have shorted something internal.
Mar 18, 2010 | Samsung HT-WP38 System
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
65 people viewed this question
 Grubhead
Grubhead
