Question about Cozy Heating & Cooling
MY COZY HEATER W505-F D HAS A PILOT LIGHT BUT WONT TURN ON
Therinnaiguy
  • 1420 Answers
SOURCE: Cozy heater
Make sure the gas valve is turned to the "On" position after the pilot stays lit. You may need to replace the thermopile. Some units have a thermopile rather than a thermocouple and it will not allow the gas valve to open if not enough voltage is being sent to the gas valve. Hopefully your gas valve is working properly and will not need to be replaced.
Posted on Dec 05, 2007
hotuna
  • 288 Answers
SOURCE: Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Posted on Dec 23, 2007
hotuna
  • 288 Answers
SOURCE: cozy wall heater lights fine then goes out after 3 or 4 minutes
Make sure all the wire connections are good and tight. Next lift off the cover and look for a little thermal disc mounted up by top of the heat exchanger. Most have a re-set button but not all. If you have this ,by-pass it ,see if that solves the problem, if so it may be defective, or doing its job and you have a venting problem. If you don't have this and have changed the thermocouple (was it a copper tube with a fitting that screwed into the gas valve, or did it have 2 wires, that is a pilot generator, kind of same thing) make sure the probe is set correct, with the pilot flame heating the top 1/3rd of the probe. The only thing left is the gas valve.
Posted on Dec 25, 2007
mikedem7
  • 25 Answers
SOURCE: heater wont light
the problem is the thermocoupler. it is the other small tube next to the pilot light. this tube sends a signal to the main valve to let the fuel go through. sometimes you have to change the whole pilot unit.
Posted on Aug 19, 2008
  • 10 Answers
SOURCE: cozy furnace
The pilot orifice could be dirty causing the pilot flame to be too small. Unscrew the pilot tube at the pilot assembly. The orifice is inside. Remove the orifice and blow it out with compressed air only. Reassemble and see if that fixes the problem. If the pilot flame is set too low, sometimes opening a door will cause a draft to blow out the pilot. If the thermocouple is good and the pilot flame is set properly, the control valve may be bad.
Posted on Feb 05, 2009
Help! I have a cozy wall heater model W355F-D. I have never ever lit a pilot light in my life and honestly, Im a little nervous. Can you maybe help me and walk me through it?
You should have control knob on the gas valve that has off, pilot and on , turn knob to pilot and hold in you should have igniter button press this in and it will spark at the pilot you may have to press this a few time to get pilot to light . when pilot is alight still hold knob in for 30 seconds then turn to the on position .
Nov 19, 2016 | Cozy Heating & Cooling
We light the pilot but the heater still wont come on. Is there a Cozy repairmen in the Dallas area?
It sounds like a flame sencer you jest have to look in the yellow page under heating most heating contracters could fix jest about iny type of furnice.
Jan 21, 2011 | Cozy (W352E) Heater
Have problem with w355 f cozy wall heater won't turn on with pilot light working. Sometimes if I bang on the valves control it will lite up.
need to clean out pilot orifice, unscrew the silver tubing from the pilot and a 1 inch long orifice will fall out, clean by either blowing air or a clean out bit, if there is just a small amount of dirt or debris that comes from the gas this will reduce the amount of voltage to the valve.
Dec 27, 2010 | Cozy (W352E) Heater
Where I do I light the pilot light on my Cozy Wall Heater? I know it needs to be lit somewhere on the bottom of the unit but I cannot find the spot and my heater will not turn on. I am a senior and not...
in front of the burner it is next to a copper tube(black if it has been burned)! it angles a little towards the copper tube! u turn the knob on gas valve to pilot then hold down and light hold for one minute then turn it to the on position (u might have to push down slightly as u turn the knob) make sure u have thermostat to the lowest setting before u light the pilot so it won't turn on while u have your face too close to the heater then turn your thermostat up to desired temperature when it is on the the on position! Good Luck!!
Nov 07, 2010 | Cozy (W352E) Heater
The dang thing wont light
if the pilot will not light and you have natural gas remove pilot tubing and pilot orifice and clean out.
Oct 04, 2010 | Cozy Enclosed Front Console Heater 70,000...
I have a cozy wall furnace and I'm having trouble with pilot
try changing the thermocouple may be worn out also check the flue heat limit switch
Best regards
Greg
Dec 11, 2009 | Cozy (W352E) Heater
Cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Feb 02, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Cozy wall heater
On top of the gas valve you will see a knob. Turn the knob to the position that says pilot. It's on the side of valve. Press the knob down with one hand and take your long lighter stick it by the pilot tube looks like a small aluminum tube should light pretty quickly hold for 30 seconds release the button you have been holding down. Now turn the knob to the on position. Make sure the thermostat is turned off so the flame don't fire up as soon as you turn knob. If you are uncomfortable gas your gas company and they should come out for free.
Sep 21, 2008 | Cozy (W352E) Heater
Heating & Cooling Logo
50 people viewed this question
Top Cozy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
