Question about Pool & Spa
I want to reset the timing of my hurlcon VX7T salt chorinator for 3 hours only per day? Please help!
Hurlcon pool salt chorinator
3 Suggested Answers
Cloudkicker
  • 18 Answers
SOURCE: my low salt light on
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Posted on Jul 06, 2011
maxcarson
  • 7627 Answers
SOURCE: hurlcon pool pump reset switch where is it??
If there is a reset it will be locater near the power inputs, could be beneath a cover. Try looking here:http://www.hayward-pool.com/pdf/manuals/NorthStar.pdf
Posted on Nov 04, 2012
Hurlcon sand pump seems to pump water out of the pool. It's like it's on backflush all the time. Anyone had similar problems?
Either your Filters Valve setting is in the wrong position, or your filters valve needs to be rebuilt or replaced. (valve diverter or and/or valve gasket)
Jan 24, 2016 | Pool & Spa
Hurlcon MX 250 Pool/Spa heater. Why does it have an intermittent F2 alarm (high temp >45d)?
check the manual bypass inside if ok check the temp sensor also check gas pressure if too low will overheat and shut off
Dec 31, 2015 | Pool & Spa
Hurlcon ctx 2hp pump troubleshoot
motor overheating replace pump
May 21, 2017 | Pool & Spa
Hurlcon cx240
bad sensor and cell calsified need to super shock poool
Mar 19, 2017 | Pool & Spa
Hurlcon pool pump reset switch where is it??
Nov 04, 2012 | Hayward 2HP Pool Pump Motor A O Smith...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
Hope this helps.
Jul 06, 2011 | Grilling
I have a Intex Pool that is 18 ft by 52 in. I have a Salt water chlorinator unit and I am tryiong to start up my pool. I added 80 kg of salt which is the recommended amount for my pool and then I ran my...
I have a krystal Clear deluxe Satlwater system recently the water went green(lots of rain) I added more salt and have run the pump extra time. It is better but not back to normal. Do I have to shock it and how do I do that? What and how much do I put in for an soft set pool 18 x 48.
thank you
Jun 17, 2010 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
47 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
