Question about CCTV Camera Pros DPRO-EC550VF2 IR Dome Camera, Weatherproof Housing, Indoor / Outdoor
DPRO-EC550VF2 instructions instructions focus
Scope is out of focus
You focus on the reticle with the eye focus ring. You need a parallax adjustment ring to "focus" a scope. Your scope does not have this feature. Are you trying to use it at a very short distance?
Mar 30, 2013 | Weaver K4 4X38 Riflescope
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
Question regarding how to process focus bracket pictures
Focus bracketing is mostly used like exposure bracketing, in a situation where you are unsure of the focus or in tricky situation. You focus normally and the camera will take 3/5/7 shots depending on the camera and you can then examine the shots on a computer and pick the best one. If you want to "blend" the pictures together, that is called focus stacking and is hard to do unless you use specialized software such as Helicon Focus:
http://www.heliconsoft.com/heliconfocus.html
Even with such software, you have to make sure the subject is perfectly still from frame to frame, so a tripod would normally be required.
Also, if all you want to do is get a large amount of the scene in focus, you do not need focus bracketing and focus stacking, simply select a small aperture (large f-stop) and that will increase you depth of field considerably.
Jul 25, 2010 | Canon PowerShot S51S Digital Camera
Turning the focus knob on my Meade LX50 Schmidt-Cassegrain Telescope does not change the focus; does not move the primary mirror. I need an exploded diagram and/or step by step instructions on how to...
The focuser has probably come loose from the "rod" on the mirror.
Here is the focuser disassemble instructions:
http://www.petealbrecht.com/Installing%20Digifocus.pdf
and this shows how to disassemble the main tube-
http://www.astromart.com/articles/article.asp?article_id=594
Jan 03, 2010 | Meade LX50 (8105003) (500 x 203mm)...
How do i replace my headlamp in my ford focus?
download this file
2000 Focus user manual.
All instructions are at the maintenance section of the guide.
For more helpfull guids please visit Ford Focus Owners Manual Archive at http://www.focusplanet.com/
Nov 27, 2009 | 2000 Ford Focus
Towbar Wiring Instructions Ford Focus
On the left inside the boot behind the carpet is a blue connector, this has all of the wires for the rear lights. if you use a test lamp you can identify which wires do what and connect as you go. Use a self tapping screw for earth.
Aug 27, 2009 | 2002 Ford SVT Focus
Hardin Optical deep space hunter 10" telescope
i have a deep space hunter telescope but have lost the manuel can i find one
May 29, 2008 | Hardin Optical Deep Space Hunter 10...
Manual Focus Problem
Yup, the Oly C5050 MF leaves a lot to be desired... What I did was to use the AF to get a focus lock then while still holding the shutter half way I would change focusing mode to MF - it will keep the distance value of the AF... Hope this helps...
Sep 13, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
CCTV Camera Pros DPRO-EC550VF2 IR Dome Camera, Weatherproof Housing, Indoor / Outdoor Logo
43 people viewed this question
Top CCTV Camera Pros Video Cameras Experts
Are you a CCTV Camera Pros Video Camera Expert? Answer questions, earn points and help others
