Question about Work Safety
What is high-visibility clothing? - Work Safety
  • 80 Answers
High-visibility clothing is made from highly reflective colors or properties so that it stands out against regular backgrounds.
It's used as a safety device in situations where it's important to be seen ie builders on site, drivers by the side of the road, cyclists etc
Posted on Jan 15, 2013
Why isn't tumble dryer drying clothes?
is there high n low switch............might be set to low...........cheers
Jun 29, 2014 | Zanussi ZDC37100W Electric Dryer
Where can I buy an inexpensive high-visibility vest?
A lot of countries have laws now that say you have to wear a high visibility vest if your car breaks down on the road somewhere and this has helped reduce the price of them.
Take a look at amazon for some cheap options. you probably wont' be wearing it that much so i dont think quality is a big issue.
http://www.amazon.co.uk/b?ie=UTF8&node=303630031
Jul 15, 2013 | Work Safety
What is high visibility clothing?
Wikipedia says: High-visibility clothing, a type of personal protective equipment (PPE), is any clothing worn that has highly reflective properties or a colour that is easily discernible from any background. Yellow waistcoats worn by emergency services are a common example.
Jul 03, 2013 | Work Safety
I need to purchase some high-visibility clothing. Can anyone recommend a good online site for this?
You can check out the Working Person's store. They have big range of jackets, pants, gloves etc;
http://workingperson.com/workwear-1/high-visibility-clothes.html
Jan 15, 2013 | Work Safety
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
We have an Aquasmart top loader and our clothes, mainly dark items, are being covered by a scum after washing. We have put the machine through the clean cycle, but this has not made any difference.
I have found with my aquasmart that if you use the 'high efficiency' the water does not cover the clothes sufficiently which is why the soap residue (noticeable more on dark clothes) is visible. I don't use high efficiency. even on conventional sometimes I still have to check that the water level is high enough. Also **use only liquid, low sudsing detergent and do not put it on the clothes-use the dispenser only. As for my machine... Time for the repair man to check the sensing I think
WC Gold Coast
Aug 29, 2010 | Fisher and Paykel Washing Machines
NO HEAT
Either heater is burned up, or high limit is bad. If you take dryer apart and get to heater you will be able to visibly see the broken heater wire. To check high limit switch disconnect the only two wires on the switch and using Ohm meter put one lead on each terminal. Should read closed if switch is good. High limit switch is located on panel covering heater coils If heater is not broken, and high limit switch is closed then you are losing power on your temperature control.
Jan 10, 2010 | Whirlpool LER4634J Electric Dryer
No water level in new Kenmore HE3T Steam front loader
high effeciency washes use very little water , the water is at the bottom of the drum (not visible )
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Work Safety Logo
997 people viewed this question
Top Work Safety Experts
Bobby Lewis
Bobby Lewis
Johan Erasmus
Johan Erasmus
Are you a Work Safety Expert? Answer questions, earn points and help others
