Question about Work Safety
What is the minimum thickness required for safety glasses?
    Champion:
    New Friend:
  • 217 Answers
Different countries have different regulations, but the US recommends that the glasses be at least 1 mm at the thinnest part
Posted on Jan 15, 2013
What is the differance between a class 2 safety vest & a class 3 safety vest & is there a class 1
Class 1 safety vests are for workers in low impact areas, where traffic flow does not exceed 25 mph and where personnel are working a good distance away from it. Parking service attendants, delivery vehicle drivers, and sidewalk or roadside maintenance workers are examples of jobs who would qualify for a class 1 safety vest. These vests should have a mandatory minimum of 155 square inches of reflective tape. Dimensions of the reflective tape can be either 6.46 linear feet of 2 inch tape or 9.39 linear feet of 1 3/8 inch tape. The reflective stripes should be around the middle in a 360? stripe and above each shoulder. Vests should be either a safety yellow or safety orange color.
Workers who are involved in jobs where there is heavier traffic are required to wear a Class 2 vest. Jobs that require workers to work in areas where there is poor visibility due to weather will also need a more reflective Class 2 safety vest. Class 2 vests will have a minimum of 201 square inches of reflective tape that is 2 inches in diameter. Dimensions of the reflective tape can be 8.373 linear feet of 2-inch tape or 12.2 linear feet of 1 3/3 inch tape. Examples of jobs that require Class 2 vests are airport baggage handlers and ground crew, forestry workers, high-volume parking or toll-gate personnel and law enforcement personnel. Reflective stripes will be over the shoulders and round the middle in either one or two 360? horizontal stripes.
Jobs that require workers to be the most visible are ones that put personnel in close contact with heavy traffic. High risk jobs include accident site investigators, emergency responders, railway workers, utility workers, and survey and flagging crews. These workers will often be close to traffic exceeding 50 miles an hour, so it is important for them to be as visible as possible. Class 3 safety vests and garments must have a minimum of 310 square inches of reflective tape that is 12.92 linear feet and 2-inches thick. Class 3 garments also provide more coverage to the arms and legs than do class 1 and class 2 safety vests.
Feb 28, 2015 | Work Safety
Minimum thickness for buick lesabre front rotors
Hello there
From a kind chap on this page
http://buickforums.com/forums/threads/18395-Service-limits-for-brake-rotors
For a 2000 Buick LeSabre
FRONT BRAKE ROTORS:
Discard Thickness30.7 mm (1.209 in.)
Lateral Runout (New)0.06 mm (0.002 in.)
Minimum Thickness after Refinish31.08 mm (1.224 in.)
Rotor Diameter 15 inch Wheels (New)278.0 mm (10.9 in.)
Rotor Diameter 16 inch Wheels (New)303.0 mm (11.9 in.)
Rotor Thickness (New)32.20 mm (1.267 in.)
Thickness Variation (New)0.025 mm (0.001 in.)
Sep 15, 2014 | Buick LeSabre Cars & Trucks
Avalanche minimum rotor thickness
Rear Brakes JC5/JH5 Utility Only
Rotor Discard Thickness* .............................. 28.50 mm (1.122 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 29.0 mm (1.142 inch)
Rotor Thickness-new .................................... 30.0 mm (1.181 inch)
Rotor Maximum Allowable Lateral Runout ................. 0.05 mm (0.002 inch)
Rotor Maximum Allowable Scoring ........................ 1.50 mm (0.059 inch)
Rotor Maximum Allowable Thickness Variation ........... 0.025 mm (0.001 inch)
Rear Brakes JH6
Rotor Discard Thickness * ............................. 27.50 mm (1.082 inch)
Rotor Minimum Allowable Thickness After Refinish ....... 28.0 mm (1.102 inch)
Rotor Thickness-new .................................... 29.0 mm (1.141 inch)
Nov 12, 2013 | 2002 Chevrolet Avalanche
What is the minimum thickness on front & rear brake rotors? 2002 Elecra Glide Standard
There is no stated minimum thickness of the rotors as the rotors are not intended to be turned. If they are worn, they must be replaced. When it comes to brakes, never go the cheap route. If your bike stops running, you fuss about it. If your bike won't stop, you get hurt, maybe killed. Always do your brakes correctly and completely. If the rotors look like they need replacing, replace them. The life you save may be your own.
Ride Safe
Steve
Mar 24, 2011 | Harley Davidson FLHT - FLHTI Electra Glide...
What is the required wall thickness required for the pressurized water tank using stainless sheet with a diameter of 36'' and a hieght of 80'' ? using a pressure supply of 40psi.
So are you going to build your own? Is it going to be for cold water only? Cheaper to buy a safe manufactured one. And a bladder tank is even better : Shell thickness: The minimum thickness
of a shell shall be determined using the
following equation:
Ts = PR/ES
E = Weld efficiency for longitudinal welds
(0.85).
NOTE: E = 1 if 100% of production
is tested at the maximum
working pressure.
S = Yield strength 20,000 psi
(140,000 KpA) or greater if certified
by the manufacturer.
See this link. http://www.watersystemscouncil.org/VAiWebDocs/standards_docs/ANSI_Final_0905.pdf
Jul 16, 2010 | American Standard Plumbing
Is the back window a double pain or single and how thick is it?
if its a motor vehicle it will be a single pane of safety glass,if it has a built in heated rear window some models use two panes moulded together ,depends on who makes the glass
Mar 10, 2010 | 1988 Chevrolet K1500
What is minimum thickness on front rotor for 2004 sante fe and are ceramic pads required
1/8th inch pad thickness.discs if undercut by more than 1/32nd must be scrapped.they are so cheap anyway.......buy new.
Mar 06, 2010 | 2002 Hyundai Santa Fe
What is the minimum required thickness allowed after wear on front vented rotor/discs vw golf mk3 vr6 presently the thickness of each surface on each side of the vented disc is 6mm and are quite lipped.
The standard vented rotor is 20mm (0.787 inches) thick and should be ground to no less than 18.5mm (0.728 inches) for your vehicle. The measurement is taken with a micrometer measuring total thickness from inside of rotor to the outside of the rotor.
Good luck.
Regards,
Aug 26, 2009 | 1998 Volkswagen Golf
2003 sierra rear brake rotors
there is many kind of brake system of ur truck here i will send u everything about the brake and i hope its help
Rear Brakes JC3
Rotor Discard Thickness* 18.50 mm/0.728 in Rotor Minimum Allowable Thickness After Refinish 19.0 mm/0.748 in Rotor Thickness (new) 20.0 mm/0.787 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JC4
Rotor Discard Thickness* 28.50 mm/1.122 in Rotor Minimum Allowable Thickness After Refinish 29.0 mm/1.142 in Rotor Thickness (new) 30.0 mm/1.181 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring1 .50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JH2
Rotor Discard Thickness* 28.50 mm/1.122 in Rotor Minimum Allowable Thickness After Refinish 29.0 mm/1.142 in Rotor Thickness (new) 30.0 mm/1.181 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JH6
Rotor Discard Thickness* 27.50 mm/1.082 in Rotor Minimum Allowable Thickness After Refinish 28.0 mm/1.102 in Rotor Thickness (new) 29.0 mm/1.141 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JH7
Rotor Discard Thickness* 28.5 mm/1.122 in Rotor Minimum Allowable Thickness After Refinish 29.0 mm/1.142 in Rotor Thickness (new) 30.0 mm/1.181 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
* All brake rotors have a discard dimension cast into them. Replace any rotor that does not meet this Specification. After refinishing the rotor, replace any rotor that does not meet the minimum or discard thickness specifications.
Mar 15, 2009 | 2003 GMC Sierra 2500HD
Work Safety Logo
474 people viewed this question
Top Work Safety Experts
Bobby Lewis
Bobby Lewis
Domenico Grillo
matt
matt
Are you a Work Safety Expert? Answer questions, earn points and help others
