Question about Work Safety
What kind of glass are safety goggles made from?
    Champion:
    New Friend:
  • 217 Answers
It isn't glass, most are made from a composite shatter-proof plastic
Posted on Jan 15, 2013
What is protective eyewear?
Protective Eyewear is any kind of specially designed gear that protects the eyes from damage. This can include all kinds of threats such as extreme weather, chemicals, sporting injuries etc. And includes things such as sunglasses, safety glasses and swimming goggles.
Hope this helps :-)
Jul 15, 2013 | Work Safety
Looking fo top brand ski sunglasses and goggles. Any recommendations for me?
You can use the following site which reviews the best glasses for snowboared and ski.http://www.skisunglasses.org/top-brand-sunglasses-and-snowboard-goggle-ski-sunglasses-review
Nov 07, 2010 | Clothing Accessories
Microwave is scratched
You will need the following:
Polishing compound, jeweler's rouge or whitening toothpaste
Electric buffer
Lamb's wool buffing pad
2 ounces of ammonia
2 quarts of water
Rubber gloves
Safety goggles
Lint-free paper towels or cloth
Step 1:
Apply polishing or jeweler's rouge to a lambs wool buffing pad. You can either buff the scratch by hand using a circular motion or with an electric buffer on medium speed.
Step 2:
Wash the polishing compound, jeweler's rouge or whitening toothpaste off from time to time in order to check on the progress of the scratch removal.
Step 3:
Mix two ounces of ammonia with two quarts of water. You may want to be sure to hold your nose closed during this process! Also, always wear rubber gloves and safety goggles when working with ammonia.
Step 4:
Clean the glass surface with the ammonia water with a clean soft sponge.
Step 5:
Dry the glass with a lint free towel. If the scratches are not completely gone, they should at least be less apparent. If there is no significant difference, consider contacting a glass company to replace or rebuff the glass.
Jul 27, 2009 | Frigidaire FMV156DC Microwave Oven
Replacing a rear view mirror
You have to CAREFULLY ( probably wise to wear safety goggles ) and with a flat blade screwdriver, pry out ALL the broken mirror glass wearing gloves. Now with the 2 adhesive strips, align mirror glass and adhere to base. Hope this helps
May 13, 2009 | 2008 Subaru Forester
32 in hdtv with a 9in scratch across it how can i fix it cheep
If the front of the screen is glass, then follow these steps:
  • Step 1 Apply polishing or jeweler's rouge to a lambs wool buffing pad. You can either buff the scratch by hand using a circular motion or with an electric buffer on medium speed.
  • Step 2 Wash the polishing compound, jeweler's rouge or whitening toothpaste off from time to time in order to check on the progress of the scratch removal.
  • Step 3 Mix two ounces of ammonia with two quarts of water. You may want to be sure to hold your nose closed during this process! Also, always wear rubber gloves and safety goggles when working with ammonia.
  • Step 4 Clean the glass surface with the ammonia water with a clean soft sponge.
  • Step 5 Dry the glass with a lint free towel. If the scratches are not completely gone, they should at least be less apparent. If there is no significant difference, consider contacting a glass company to rebuff the glass.
May 09, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Tiller safety tips
* As with any garden equipment, especially gas-powered, you should make sure you have adequate protective gear. * Safety goggles, work gloves and earplugs are all necessities. * Wear sturdy, steel-toed boots if you have them; if not, wear your most durable close-toed footwear. * If you plan to be out in the sun for a long time, don't forget a hat, sunglasses and sunscreen too!
Aug 27, 2008 | Mantis Crevice Cleaner Attachment
Bench Grinders Safety issues
Goggles or safety glasses need to be worn to protect the operator's eyes from the sparks and metal filings that result. Depending on the workpiece and time of exposure, hearing protection may also be required, the dust produced is also potentially hazardous. The toolrest (or workrest) should be mounted slightly below the center of the grinding wheel with less than 3 mm clearance from the wheel. This prevents the work from jamming between the toolrest and the wheel. Grinding wheels designed for steel should not be used for grinding softer metals, like aluminium. The soft metal gets lodged in the pores of the wheel and expand with the heat of grinding. This can dislodge pieces of the grinding wheel. Wire brushes require particular attention for the safety of the operator and bystanders as the metal wires may become dangerous projectiles as they could bind with the object being brushed and so throw it away with great energy. The machine needs to be securely mounted to a pillar or a bench to be used safely and effectively, often with an emergency stop switch or pedal fitted close by the machine, for use in emergencies.
Aug 27, 2008 | Clarke Power Products Cast Iron Bench...
How to Protect myself?
When running a die grinder, it is important to follow some simple safety rules. Never wear loose jewelry while operating the grinder. Neck chains can easily become caught in the die grinder and cause strangulation. Safety goggles should also be worn at all times.
Aug 27, 2008 | Taylor Pneumatic: 1/4" Front Exhaust Die...
Work Safety Logo
443 people viewed this question
Top Work Safety Experts
Bobby Lewis
Bobby Lewis
Domenico Grillo
matt
matt
Are you a Work Safety Expert? Answer questions, earn points and help others
