MAYTAG Neptune # WAS0086VS drain pump electric how do bench test
  • Washing Mach... Master
  • 17,129 Answers
Please check on this link for tips: drain pump
Posted on Jan 15, 2013
  • 8 Answers
SOURCE: maytag neptune mah3000aww
re original issue, see if R11 is burned. if so, need to change R11 resistor and associated triac, and probably wax motor so it won't do it again. temporary fix just cut out R11, door won't lock. if your model won't spin that way, depress actuator for microswitch from door wax motor. instructions on web.
Posted on Oct 23, 2008
SOURCE: front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Posted on Mar 09, 2009
  • 1294 Answers
SOURCE: i have a maytag neptune washer the water will not drain out of it
First drain as much water from the drum as possible and unplug from the outlet. Then there are 2 screws left and right under the front lower panel at floor level. Undo those two screws. Pry the front panel DOWN from the door panel. Once the lower panel is removed you will see the pump and pump filter on your right. The pump filter is to the left. It has a large turnscrew. Be ready with a pan or something to catch the water from the open filter! Screw this counterclockwise until it comes loose. You will now be able to remove the filter and all the debris. After cleaning, re-screw the turnscrew. Before you put back the front panel test that it is clear by doing a wash. If it still doesnt drain you must remove debris from the pump itself. The pump is between the pump filter and the pump motor on the right. Undo the white clips from the motor and the retaing clips attiching the filter to the metal washer body. Then turn the motor clockwise to separate it from the filter. Refit carefully after job is done. And fit outlet tube a correct height, not too deep. <courtesy tzotsi>
Posted on Mar 10, 2009
milten1
  • 1304 Answers
SOURCE: Why won't the washer drain? Pump appears to be
if this issue is because you hear water in the machine when the tub spins......
thats normal, its called the balance ring
centrifical force, pushes the water in the lid, outward helping to use the sling weight, as a counter balance
its 100 percent normal to hear sloshing when turning the tub by hand
Posted on Oct 13, 2009
  • 31 Answers
SOURCE: Maytag Neptune Washer MAH8700AWW will not spin.
You may have tried this, but check the door switch, and the pressure switch(water level switch) to see if either could be bad. both of those affect whether the washer spins or not.
Posted on Jun 12, 2010
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
MAYTAG NEPTUNE WON'T SPIN OR DRAIN
If it can't drain, it shouldn't spin. Pump blocked? Broken pump? Level sensor broken?
Sep 05, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Neptune #MAH6700AAW will not drain, how to test control board?
Have you checked lid switch? If bad, unit will not spin and drain.
Sep 12, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Water will not pump out
Drain pump in bottom of machine is probably toast. Check for pump noise during a cycle test. If no noise, check the electrical connector going to the drain pump. If no power is getting through the connector, check the computer. If power is getting through to the drain pump, replace the drain pump.
Jul 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't drain
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune won't drain
your pump is clogged with matt mud...
remove the back panel
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Oct 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune nd error code
will heres some of the easy test,,,check drain hose for blockage,,,ckeck punp for coins always unplug unit..now this is more serious so be careful..ckeck for 120 volts at the pump..its a electric,,,,im here if you needed me
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
