Question about General Electric Water Heaters
Ge gas water heater gg38t06axk not heating - General Electric Water Heaters
4 Suggested Answers
  • 2976 Answers
SOURCE: takes a long time to heat water
If you are using a 3/8" copper line for your gas, get it replaced ASAP. It will fail. 1/2" Black Iron is required with natural gas. 50 gallons is a lot of water to heat. Look on the heater label for the recovery rate.
Posted on Feb 27, 2009
  • 306 Answers
SOURCE: where is termostat on a ge 240 volt water heater
It's inside a removable inspection plate on the side of the heater - ususallly real close to the heating element.
Posted on May 06, 2009
motor1258
  • 6674 Answers
SOURCE: the electronic ignition on a gas water heater will
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Posted on Jul 20, 2010
Water not heatig
http://waterheatertimer.org/How-to-fix-water-heater.html
Gas or electric or solar... tank or tankless... oil fired, indirect etc?
What do you have
Gene
h
Aug 03, 2014 | GeoSpring Hybrid Water Heater
Install problems ge hybrid water heater
1) Copy following links for detailed resources:
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
2) T2 is tank temperature sensor failure located just above upper element.
Call for service/ warranty.
Call GE 888-433-4394
3) Was water heater completely full of water before applying power.
Do you have 10 gauge wire and 30 amp breaker.
Is unit receiving 208-240 Volt power. Click breaker fully on-off.
Move wire to another same size circuit breaker.
Mar 03, 2013 | General Electric Ge Appliances GEH50DNSRSA...
GE SmartWater Hot water tank. Water heater will not stop heating.
Hello Anita:
1) For gas water heater: Turn off gas to heater:
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
2) For electric water heater: Turn off circuit breaker.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#veryhot
3) For gas: Copy following link to identify gas control valve thermostat, and troubleshoot by type of gas control.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
4) For gas: Gas control valve thermostat has probably gone bad.
5) Add comment and give clear description of water heater.
6) Call plumber.
Feb 17, 2013 | Water Heaters
GE Smart Water Hot water heater 40 gal will not stop heating water.
1) For gas: Turn off gas to heater:
2) For electric: Turn off circuit breaker.
6) Call plumber.
Feb 17, 2013 | General Electric GE SmartWater Household...
My smart water pilot is on but it is not heating the water tank
GE is Rheem.
Models change frequently.
Copy following link for troubleshoot resources by type of gas control valve.
Newer water heaters require frequent air intake cleaning.
To do this with Rheem requires removal of combustion parts, and then air compressor to blow out screen.
It is probably time to have a plumber give water heater a catch-up on recommended maintained, such as checking gas pressure, bleeding gas line, checking vent draft, clean combustion parts, clean air intake, check if gas control is working correctly.
Sep 03, 2012 | General Electric GE SmartWater Household...
Pilot light will not stay lit on GE 40 gal. gas water heater tank
You have tank-type gas water heater:
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Jul 30, 2011 | General Electric Water Heaters
Where is termostat on a ge 240 volt water heater
Apr 19, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Takes a long time to heat water. Brand new Ge 50 gallon water heater. Once heated it right temp,just a long time to heat it and then won't maintain hot water. Is gas line to small? 3/8 copper line. Thanks
Feb 27, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
This is a new whirlpool hot water heater.Pilot lights, burner fires, water heats up to temp. burner and pilot both shut down. Unit has to be started manually each time
LP OR NAT GAS , IF IT IS LP CHECK GAS PRESSURE @ TANK AND MAKE SURE NOT TO HIGH , IF NAT STILL COULD BE THE PROBLEM HAVE THE GAS COMPANY CK PRESSURE
Feb 22, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
55 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
