Question about Frigidaire FEF352 Electric Kitchen Range
How do I unlock the oven door?
The door is actually open and I can't shut it back because the lock is engaged. It is a Frigidaire Self Cleaning Oven model #FEF365BGWC.
Thanks,
Tammie
  • tammie6205 Jan 24, 2009
    Hi Mark,
    No, I cancelled the cleaning cycle but I can't get the door to shut back because the lock is still engaged. Yes, I know this sounds weird, don't ask how I got myself in this predicament, lol.
    Thanks,
    Tammie
    Oh, phooey!!! I turned off the breaker for a minute or two and started it up again to no prevail. I guess I've done it good this time @#$%. Yes, something told me I should gone to bed instead but I am one of those silly night owls.
    Any other tricks up your sleeve?
    President:
  • 1,214 Answers
If the lock is engaged, is the oven in a self cleaning cycle? If so, cycle power to the oven, that should cancel the self cleaning cycle.
Reply back if that worked or not and I'll try to help you further.
Posted on Jan 24, 2009
  • 3 more comments
  • Mark Egan Jan 24, 2009
    Tammie,
    Turn the power off to the oven for a minute or so. This should reset the controller board, if the controller board is what is energizing the door solenoid.
    Otherwise, it could be the mechanism is broken. I'll look at the assembly and reply.
    What are you doing up this late at night anyway? :-)
    Well, I cant get into SearsPartsDirect right now, which is where I look at exploded views and wiring diagrams.
    Well,
    the latching mechanism can be set manually, but until I can get into the Sears website, I can't tell for sure.
    Look at the oven just above where the door closes, and see if there is a grill of some type. If so, get a flashlight and look up inside the grill, your should see a solenoid connected to a lever, which latches the door. See if you can move the lever with a screwdriver poked through the grill.
    Tammie,
    Take a look here -
    http://www.applianceaid.com/clean-lock.h...
    Let me know if you have success, or any other questions.
  • Richard Jarrell Jun 06, 2012
    I had the same problem. Door open but lock engaged so door wouldn't close. I called Frigidaire. Hold down the light switch button on the upper left front of the oven then press the Clear/Off button on the control panel...yours might say "Cancel". Door should close and door lock light stop flashing.
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven lock is on and will not come off
you can hold the clear/off button for 3-5 seconds this hsould realse the lock.if not you can temporarily remove te back cover and remove the motor.sometime unplugging the unit may relase the lock
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When cleaning the stove i touched my accident the
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door is locked shut. How do we get it to
Try cutting the power to it. ALSO push in to relieve the tension on the latch while attempting to open it.
Oct 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FEF352 Electric Kitchen Range Logo
395 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
