Question about OKI C9600hdn Laser Printer
C9600 tray does not lift up
  • wojciechz Jan 24, 2009
    there is no paper jam any where. I checked few times.
    Genius:
  • 1,913 Answers
Chweckcthere is not any paper jam . remove inkcartrdge then check .aslo check in back side of printer .may be there is paper jam.
remove paper if jammedup.let me know.
Posted on Jan 24, 2009
Paper jam in number two how to clear same?
The paper paths on these types of printers work in a simalar maner not knowing where your jam is is going to be a bit difficult.
Does the paper tray lifting gear on the rear of the paper tray work correctly, remove the tray and load with paper. There should be a gear on the rear of the tray, turn it with your hand and the paper should lift. If that doesn't work, check for broken lifting gears on the tray. Alternately if the trays don't have lift gears then if lifting is done internally in which case try to look if the paper has been raised up to the feed rollers. Before you remove the tray you have to look inside and investigate.
In my experience a difficult to find piece of paper usually cause the problem.
Good luck with the problem.
Feb 11, 2015 | Xerox WorkCentre C2424DN All-In-One Laser...
ERROR 0X00000709 PRINTER HP CM6040F MFP
hi,
Error related tray lifting....just check which tray is not lifting and find "is there any kind of abstraction to lift the tray".
Then just refix the tray lifter assy. connector otherwise replace lifter assy.
hope it will help.
Feb 04, 2014 | HP LaserJet Office Equipment & Supplies
OKI C9600 paper jam problems: Paper jams continually, either on first attempt to printing or if it prints a page the 2nd page inevitably jams. Printer has only done 1500 pages since new ,and i have removed...
Wow! That's quite the printer you have there. The C9600 does have a feed roller in the front; and it's not uncommon for paper to still get stuck. Does your paper "fan" when it goes through; or simply, go through and jam? It's possible a paper feed sensor is bad too. Another thing you might want to check is the paper tray; and that the paper is set to the proper size.
Also be aware, the OKI 9600 had a recall a year or so ago for some potential "shock issues" I would advise you to check with OKI directly to determine if this printer is part of that issue too.
Jan 04, 2011 | Office Equipment & Supplies
Please how do i resolve 60.02 hp printer error
Something is preventing tray 2 to be lifted.
Take tray tray out of the printer and check for obstructions preventing lifting of the paper.
Switching tray's is possible to ascertain if the problem lies with the tray or the printer.
If the problem is with the printer the lift motor is suspected to defect.
Dec 31, 2010 | HP LaserJet 9050n Printer
Getting the msg "service call 22 man tray lift"...
This service indicator is referring to the main lift motor that is located on the rear of the machine, which comes in contact with the back of the tray and then engages to lift the paper up to the tray. I would suggest removing the paper tray and inspect the back of it, ensure that no parts appear broken and attempt to manually crank the arm that causes the paper to lift. If all is functioning on the tray side, then look towards the back of the machine through the front, make sure there is no lodged paper or debris. If no physical obstructions are present, and nothing appears to be broken and the paper tray aligns up properly, then you most likely have a failing lift motor.
Let me know.
-David.
Nov 08, 2010 | Minolta magicolor 2200 DeskLaser Printer
U6-03 error on sharp ar-m350... is there a code i can type in to fix it?
Tray 3 is not lifting or lowering properly. There could be a bad lift motor on the tray. The tray could have a bad sensor. Someting is either not moving the tray up and down or the sensors are not detecting the movement.
Remove the paper and the tray, inspect the tray , see if it moves freely, look for something bent or out of place.
U6-03 indicated a tray three lift problem.
Aug 09, 2010 | Sharp AR-M350U Copier
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
Waititng for tray 2 to lift
if the tray doesn't lift than there may be a problem with the lifting motor. remove the right cover assembly and near the center bottom is the motor assembly. insert the tray and check to see if the motor is functioning. also check the tray, there is a gear on the tray that drive the tray up into position.
Sep 25, 2009 | HP LaserJet 4250n Printer
My toshiba 2060 copier starts knocking when warming up and then show the trays are empty , do you know what it could be?
the lift motor for the paper trays is faulty or if yu pull the trays out and look behind the tray there are som connection there check there aint no paper stuck there.. if you put the trays back in on at a time you should find the one causing the problem.. my money is on the lift motor as this lifts the tray up to the paper sensor to show paper in trays..
Aug 03, 2009 | Toshiba 2060 Copier
Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Sep 25, 2008 | Ricoh Aficio 450 Copier
OKI C9600hdn Laser Printer Logo
132 people viewed this question
Top OKI Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
