Question about Dewalt DW8920 Blade Kit for DW892
How do you use the feeler gauge to adjust the blade on the unishear
How do I use the feeler gauge that comes with the blade kit?
  • Dewalt Master
  • 885 Answers
Go to Dewalt's service website at http://servicenet.dewalt.com/ and search for your model in the find parts box. Select the 3225-10 model and there will be a manual available that describes how to set your blades.
Posted on Jan 18, 2013
Why does my MTD tractor screech and die when I engage the blade?
Sounds as if the valves need adjusting... You will need a feeler gauge and find out what the specs are for that engines valves clearance...
Oct 11, 2015 | Mtd Garden
How to adjust valves on fs110 stihl grass trimmer
you need to go get a valve cover gasket set from the dealer.. it comes with the required feeler gauge to do this... then put the piston on top dead center... look for the magnet to pass the ignition coil. and adjust to where the feeler gauge is barely grabbed by the rocker arm. be careful of the socket you use, it needs to be thin enough to not touch the rocker arm...
Aug 27, 2014 | Garden
Feeler gauge numbers
If you use a micrometer and measure the guages, you will find they are tapered.
Jan 16, 2014 | MSI L1350D-1672US Netbook
Adjust the parking break on a 2010 f-150?
Hi Jeff, Inspect the back plates of the brakes to see if there is a slot for inserting a feeler gauge. I would think there will be. Insert the feeler gauge into the slot and adjust until friction is felt on the blade. Adjust both rear brakes to the same clearance. Front Disc brakes are self adjusting (As should be the rear?)
Nov 10, 2013 | 2010 Ford F-150
Adjust timing
Using a feeler gauge.You will have to look up the specs for your bike and use the proper blade on the gauge to adjust it.
Jul 17, 2013 | Honda CBR 900 RR Fireblade Motorcycles
How can i adjust contact breaker's gap in maruti 800
most cars fitted with point ,wow old problem i generally set the gap @ .16 thou, if you havent got a set of feeler gauges us an old hacksaw blade ,
Apr 30, 2012 | Maruti Cars & Trucks
How do you set the points and the coil in a old 10 hp tecumseh snow blower
turn the crankshaft until the points are open, then use a .010 feeler gauge or a business card to place between the contacts of the points. then close the points, by loosening the screw that holds them in place, until they snugly touch the card or feeler gauge blade. the coil adjustment will require the same feeler gauge blade or card. loosen the the two screws that hold the coil in place and place the card or blade between the flywheel and coil legs. turn the flywheel until the magnets pull the coil into the flywheel then tightened the screws and remove th card or gauge blade.
Nov 26, 2010 | Garden
The print is only clear on the left side of the forms...
Platen Gap Adjustment (Figure 35)
IMPORTANT Only do this procedure if the original equipment shuttle frame assembly or platen has been replaced by a new or
refurbished unit.
1. Prepare the printer for maintenance (page 338).
2. Remove the shuttle cover assembly (page 357).
3. Loosen the platen open belt (page 415, steps 2, 3, and 4).
4. Raise the forms thickness lever (1) to the fully open position.
5. If you are adjusting any model except the 6400-i20, select a 0.011 inch (0.28mm) flat feeler gauge.
If you are adjusting a 6400-i20, select a 0.012 inch (0.30 mm) flat feeler gauge.
ATTENTION Do not force the platen against the feeler gauge. Damage to the hammer tips will result.
6. Insert the feeler gauge (2) straight down between the hammer bank cover plate (3) and ribbon mask (4), within four
hammer positions of the left end of the hammer bank.
ATTENTION Adjust the platen set screws less than 1/4 turn on one side, then check the other side. Adjustment sensitivity is
approximately 0.03 inch per revolution of the set screw. Also, insert the feeler gauge no more than two inches down
from the top of the ribbon mask.
7. Gently close the forms thickness lever (1). As the platen is closing, gently slide the feeler gauge up and down, keeping it
between the hammer tips and ribbon mask. If the feel is too tight as the platen closes, adjust the 3/32 inch set screw (5)
counterclockwise. If the feel is too loose, adjust the set screw clockwise. With the forms thickness lever closed all the way,
the feeler gauge should contact both the tips and the ribbon mask and move with light friction. Shift the gauge slightly to
verify.
8. Repeat steps 4 through 7 at the right end of the hammer bank.
9. After adjusting both sides, check the gap again at both ends. Readjust if necessary.
Aug 25, 2009 | IBM 6400 Matrix Printer
How to adjust the valve adjustments
you need to remove the valve cover and if they are even adjustable there will be locknuts on a stud on one side you need feeler gauges and adjust by loosenin the nut with cylinder in compression sequence tightrn stud with screw driver or allen wrench whichever applies put feeler guage probably.018 between rocker and vale tightrn untilfeeler gauges move with some resistance lock nut tight but be sure you can still move feeler gauge get all cylnders then reinstall valve cover
Jul 21, 2009 | 1992 Daihatsu Rocky
Dewalt DW8920 Blade Kit for DW892 Logo
69 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
