Question about MSI Computers & Internet
When i try to format my computer it stops at the final stage. i tried with other harddisk also same problem. then i formated my hard disk on other system and loaded xp on it. and used on my system but it now restarting .if tried to reformat same problem ouccurs.
  • 2,878 Answers
Try deleting the partition, then doing format. There is a quick and full format to try. You can also run chkdsk x: /f/r. X being the drive letter.
Posted on Jan 15, 2013
BigLou1958
  • 104 Answers
SOURCE: windows xp
Do you see the hard drive in you bios? This is where to start. If you can not see it in the bios check the hard drive pins to see if you have it set ( master or slave ).
If you do see it in the bios you may have to check with asus to see if there is a special driver needed when installing windows XP.
Posted on Oct 21, 2007
map9966
  • 2351 Answers
SOURCE: Not able to install win Xp
Well your order seems correct. To use one drive with 2 or more partitions you'll need each partition to have at least 2 to 3GB for windows to move around. It would be easier for you to have the Mfg's bootable utilities disks to set up your partitions. Windows 98 must be installed first. I'm guessing it is currently set up on the partition D:\. & it runs. ( Good choice, either here or on a seperate drive). Put your Windows XP cd into your cdrom drive. At boot up pressing the F8 key & bringing up your boot menue. Pick the cdrom that has your XP cd in it. Windows will show you just what partitions are on your drive & it will see windows 98 too. This is where you must be mindfull of your choices. Choose the first partition on the drive for win XP. If you want to use the NTFS allow XP to do a quick format. Continue with the install of XP. When windows XP does a restart "let it time out on it's own to restart", & you will see the words "Press any key to boot to CD. Do not touch any key. Just allow windows to continue by it's self. Leave the CD in the drive. There will come a time where windows XP will change the boot.in file & display which OS do you want to boot to. Pick Windows XP & keep selecting Xp till it is finished installing it's self.
If this fails, you will have to recheck that windows 98 can still boot on it's own but think this will work. If by some Godly reason it hangs wait a few minutes. Post back what you noticed & your thoughs. So I can find a reason this has happened. It should work. Good luck!
plaese vote...
Posted on Feb 04, 2008
jonniewalker
  • 1031 Answers
SOURCE: formating hard disk drive
Preparation Step1When you format a computer hard drive you will lose everything that is on the drive. Therefore, it is very important to back up anything you might want later. Additionally, if you are going to be formatting and installing XP you need to make sure you have the discs for any applications or third party hardware you use since you will need to re-install your programs and drivers after re-installing Windows. Step2Take a moment to think of anything that you have on the computer that you wouldn't want to lose. Generally, you probably want everything in your My Documents folder, and you also want to save things like your favorites or bookmarks from your Web browser. Remember that each user on the computer has his or her own My Documents folder, Desktop items and Favorites/Bookmarks. Step3Save everything to a CD, DVD or a hard drive that you won't be formatting. Formatting a Secondary Hard Drive Step1Right-Click on the “My Computer” icon either on your desktop or in the Start Menu and select “Manage.” Step2A new window titled “Computer Management” comes up. Select “Storage” from the left hand side by clicking it once, then select “Disk Management(local)” from the right side by double-clicking it. Step3Now in the lower part of the main frame (right side) of the window you should see a nice visual of all your hard drives. Each line is a different drive. Each box on a line (with a colored bar at the top and a size displayed in MB or GB) is a partition on the drive. Partitions are separations of space on a drive. Unless you are doing something specific that requires multiple partitions, you only want one partition per drive. Step4First you must delete any existing partitions on the drive you are going to format. Do this by right-clicking on the partition's box and selecting “Delete Partition...” Since you already know that you will be deleting everything on the drive, and have already backed everything up, you can safely say yes to any warning the computer presents you with. Step5 If there are multiple partitions make sure you have saved everything off them since they might each have different drive letters (i.e. “D:” or “F:”). Then repeat the above step for each of them. If you only want to format one partition that is OK and you can continue to the next step without deleting the other partitions. Step6The box for the drive to be formatted should now have a black bar at the top of it and should say “Unallocated” under its size (see picture). Right click on it and select “New Partition...” The New Partition Wizard comes up. Step7In the New Partition Wizard click next. On the next page make sure “Primary Partition” is selected and click next. Now make the size equal to the maximum (it should already be set to it), and click next again. On the next page the computer will automatically choose the first available drive letter for the new drive. However, if you like you can choose another drive letter from the drop-down menu, and then click next. Step8Finally the New Partition Wizard asks if you would like to format the new partition and if so what format. Choose “NTFS” as it is faster and more secure. Leave the “Allocation unit size” as “Default.” In the “Volume label” field enter whatever name you want the drive to have. Simple is better. Avoid using spaces. Lastly, if the drive is brand new and has never been used before check the “Perform a quick format” box. If the drive has been used before leave this box unchecked. Leave the “Enable file and folder compression” box unchecked and click next. Then on the next page click finish. Step9The wizard will now spend a little while formatting the drive. On old or large drives this may take a while. Do not close the “Computer Management” window until it finishes. You will know it is done when the word under the size of the drive changes from “Formatting” to “Healthy” and the name and drive letter you chose for the new drive show up. After it is finished you can proceed to use your newly formatted drive.
Posted on Oct 13, 2008
cpenzes
  • 1102 Answers
SOURCE: error loading operating system
you'll need to run windows setup again.
Insert the cd restart and when asked to start with cd click enter.
Posted on Jan 14, 2009
map9966
  • 2351 Answers
SOURCE: cannot load operationing system because of fault saying, "no hard disk found in this computer"
Check the data cable. Make sure it is fully connected. (Sometimes they come loose). Check all connected data cable's & power cables within the system. Start with the new drive you installed. Unplug the data cable & re-connect. Follow it to the motherboard & do the same. If no cable seemed loose than replace the hard disk drive's cable with a new cable. Standard 80-conductor Ultra DMA IDE/ATA interface cable. See below;
ab2779a.jpg When you start up the dimension 4600, enter the bios, watch your screen at start up. You will need to press F2 or F10 key to enter the bios.
Once in the bios check that you hard disk drive is shown.
Most bios will list the drive by its model number. If you see the model number of the drive chances are you can save & exit the bios. Button up the case. You should be able to load windows.
Luck!
Mike
Posted on May 06, 2009
How to format the harddisk??
Attach the hard drive to another computer and use the OS of that computer to format the drive.
Mar 14, 2015 | Computers & Internet
Harddisk not showing on pc
is the disk backup or in the pc internal hard-disk if external no need software download just get another pc or use recovery software to get your data from it and then format and re backup your data
Jun 27, 2017 | Buffalo Technology DriveStation HD-HC500U2...
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
Evesham explorer laptop,format,booted from disk,formatted partition ,reaches stage of copying windows files to folders but has been running for 5 hours..and files still not copied...
Change your windows disk.
Also delete all partition of harddisk and create partition again .
Then boot with disk.
Try this 2-4 times you done it.
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | Computers & Internet
Hard disk no open
Hello, may b your other harddisk mite hav sum errors in it. Hope its detected in windows, bt not accesable.
Try booting with any linux live CD (google "puppy linux", its just 90MB approx) and connect the harddisk. Now access ur harddisk from linux. If u still cant access it, then u should format it.
if it works in linux, then backup all ur improtant data and format it wit NTFS. Ur prob shud b solved!!
Jun 22, 2009 | Video Game Consoles & Games
Hard drive crash
This may not be a Hard disk issue. this seems to be you have a issue with your motherboard or CPU.
Jun 10, 2009 | Computers & Internet
Hard disk problem
you may try formating into a linux partion first using partion magic and then to any of the windows partition
Jan 18, 2009 | Seagate 40GB EE25 5400.2 Ruggedized PATA...
Usb harddisk problem on LG 50PT81+ not compatibel XP
LG have created a solution that only allows you to backup to a hard disk in the format that they have created.
The hard disk can not then be read by a computer as they only recognize formats such as NTFS, FAT or FAT32: not LG´s format!!!
If you reformat the disk in FAT32 format then you can copy files to the hard disk and see your photos, or certain types of DIVX files and listen to music via your TV,......BUT...you can not save TV programs from the TV to the same hard disk UNLESS you allow the TV to reformat the hard disk to LG´s format ) in which case you will lose all the files you previously had on the hard disk.
In practice LG have created a backup solution that is of little use to most users particularly bearing in mind that the backup takes almost as long as the original programs and as long again to restore.
Most of LG´s products are very clever and have a tendency to be in advance of the market.
However on this occasion LG almost had a good idea but many users are going to feel tricked like I did,
Jan 20, 2008 | LG 42PX5D 42 in. Plasma HDTV
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Computers & Internet Logo
29 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
