Question about Toyota Sewing Machines
The stop motion knob on my toyota aisin 2051 sewing machine is not tightening enough. where can i get a replacement?
This therefore makes the main flywheel rotate when the motor is activated, but the stitching end does not move up and down. also i need a replacement belt. Is there a repair manual available? (not an instruction book - that I have)
3 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: brother sewing machine
There is cluch on the handwheel that connect motion,try to tighen this If negative,There are two small bevel gear (hard PVC )connecting to the upper crankshaft where the handwheel was connected.This transmit motion when motor run, most commonly the vertical rod where one bevel gear was connected maybe broken or viceversa at the upper crankshafting that holding the bevel drive gear is broken try to check this.
Posted on Mar 07, 2009
  • 980 Answers
SOURCE: I HAVE RECENTLY GOT A ZHEJIANG AISIN ELITE RS2000
The instruction book you should be looking for is a Toyota rs2000
Posted on Oct 21, 2009
How to free a seized main shaft
Sounds like the clutch: here is a link to the instruction manual:
http://www.aisin.at/assets/manuals/RSSDENG.pdf
It has a fault fining section page 50
Jun 12, 2014 | Toyota STF17 Sewing Machine
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
I removed the hand wheel cover on my Bernina 1001 because the wheel was too tight and now I cant get it to do anything...sew, wind bobbin. Help
With the wheel on you will have a 3 pronged washer, make sure that the screw on the stop motion wheel is unscrewed all the way, put the stop motion wheel back on ans tighten it hand tight only, tighten the screw in the stop motion and see if the stop motion frees off and then tightens again so the machine will work, if it does not take the stop motion wheel of again and move the 3 pronged washer in a different position and put the stop motion wheel back on again
Oct 04, 2013 | Sewing Machines
VX808/Vx809. When put pressure on foot control stop motion contro doesn't move.
I would suggest that the machine needs to be serviced to find out why it not responding the way it should.
Mar 22, 2012 | Brother Sewing Machines
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
Brother VX-1100 - Stop motion knob will not move, the machine hasn't been used in a while, how do you get the knob to move? Thanks Si
This sounds like there may be some oil that has turned to varnish and is therefore, seizing the stop motion knob in place. The old oil will have to be dissolved unless it has just been overly tightened. With the machine not used in some time, it should be serviced and lubed so it will work like new again.
<Ray>
Nov 05, 2010 | Sewing Machines
Took stop motion knob off how do the pieces go
You should have a three pronged washer, put that on first anyway round, then put the stop motion wheel on and tighten fineger tight, tighten the small screw that should be on the stop motion wheel and tighten a bit more, if it does not tighten up take the stop motion wheel off and put the three pronged washer in a different position.
Jul 17, 2010 | Sewing Machines
Brother sewing machine
Mar 06, 2009 | Brother LS-2125 Mechanical Sewing Machine
Stop motion knob won't tighten
Remove the stop motion wheel and you will see another part that is loose(looks kind of like a washer with ears on it). Reposition this on the shaft and put the stop motion wheel back on. The stop motion wheel was too loose and it allowed the washer to fall off the shaft. The screw is nice to have and it keeps the washer from falling off the shaft but it's not absolutely necessary to use the machine. Just be caredul when winding the bobbin.
sewman7
Dec 03, 2008 | Sewing Machines
Sewing Machines Logo
108 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
