Question about Poulan Garden
What size mower drive belt poulan pro PP22042HP
ccrozier_agr
  • 36 Answers
SOURCE: Poula Pro Mower
Hi,your machine is probably a hydro static drive & needs the oil changed in the transmission.
But the pump that pushes the oil around inside it is probably to far gone for repair.
I am not sure about this machine but we have had a simlar problem with a rideon this summer.
It has one pedal that you push forward for forward movement & rearwards to go backwards.
We were able to get a new drive pump for the transmission but it was expensive, most of these machines have nearly the same transmissions so getting the parts should be no problem.
Also we do know is that there are some machines with oil emersed discs inside (like wet type clutches) these also need regular oil changes & can burn out without oil. (Bronze plated disc)
You would need to find the name plate on the transmission & there should also be model & serial no on the casing.
Once you have these details you should be able to find transmission parts lists online.
Posted on Nov 29, 2008
  • 376 Answers
SOURCE: drive belt diagram on poulan pro 19.5 automatic
Go to ... www.poulanpro.com Scroll down, on the right click on Download Manuals. Then enter the model number that is under the seat. Then you can choose the owners manual or the parts manual. The owners manual will tell you how, the parts manual will give you diagrams and part numbers. Dwain
Posted on Jun 14, 2009
MNfisherman
  • 11896 Answers
SOURCE: what size drive belt for a mtd lawnflite 11 hp
(1991) 131-531C611/505
(1990) 130-531C611/505
(1992) 132-531C611/505
(1993) 13-505 / 133C561C611
Posted on Jul 20, 2009
  • 376 Answers
SOURCE: i cant get the drive mower belt on my poulan pro lawn tractor!
The belt you should have bought is part # 140294 and yes, it is longer.
Posted on Jul 29, 2009
  • 22 Answers
SOURCE: my poulan pro 6.75 self-propel mower stalls frequently
Replace the coil. Remove the top cover so that you can see the flywheel. There will be a horseshoe shaped peice with the plug wire attatched to it along with a small whir plugged onto it. Remove the two screws holding it on and unplug small wire and disconnect plug wire. When you put the new one on place a business card between coil and flywheel, this will give you the proper spacing, reconnect small wire and plug wire, reassemble top covers and you are good to go.
Posted on Aug 14, 2009
WHAT SIZE DRIVE BELT I NEED FO 30" RIDING LAW MOWER ? MODEL NO P01230lt SERAL NO.011310A001123 model no PO12530lt 12.5 HP
We do not have any info on this site
Just a chat room
Take you info to a small equipment
dealer/repair shop & they can look it up
for you
Jul 06, 2014 | Poulan Pro Lawn Tractor 2006 and Newer...
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
2008 poulan pro 18.5 hp 42" cut 6 spd smokes bad when i put it in gear
check drive belt make sure its not rubbing against melt guied tabes
Aug 18, 2013 | Poulan Pro Lawn Tractor 2006 and Newer...
It keeps eating drive belts! It looks like the pulleys are not parallel. Can you align them? It appears to be spring loaded
Either the belt you are using is not the correct lenght and width, or one of your pulleys is worn out. Make sure that you are using the correct belt. Poulan mowers (made by AYP) will typically use a fractional length belt...meaning that you have to buy a Poulan belt to go on it. With the proper belt and pulleys, the front drive pulley should be level and the belt pattern should not contact anything other than the pulleys.
Aug 30, 2010 | Poulan Pro " Pro" Self Propelled Mower
We have a 48" 23 hp poulan pro riding mower, our problem is the drive belt from the engine to the deck is always breaking, this is the 4th one we bought this summer. what could be the problem
More than likely, you are using a automotive belt not a "V" belt. Automotive belts are pretty tuff but can not stand up to the beating a mower takes. Go to your mower place and get the proper size "V" belt for your Poulan. Make sure it is both the proper size and a quality belt. I recommend "Gates" belts.
When you start your mower, start it with the engine at slow speed, to lessen the shock that the belts and clutches take.
Thanks for your interest in FixYa.com
Aug 16, 2010 | Poulan Pro 46Inch 22 HP Yard Tractor with...
I cant get the drive mower belt on my poulan pro lawn tractor!
Jul 27, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
