Question about OEM 2009 Dodge Grand Caravan Radio / CD Player 9zd39692s Without Nav.; AM/FM/DVD/20 Bright green HDD/MP3/factory Passenger Side Rear camera compatible REN, w/SAT radio Houston, Texas
Radio turns on and off every 2 minutes
Radio turns off and on randomly
Did you end up finding a solution
Posted on Oct 29, 2014
My Ford 2005 Focus clock/radio is possessed.
Check engine light would have nothing to do with this ! Check engine light is for engine codes ! there is a problem with the radio it self ! or SJB - smart junction box , ford's BCM - body control module . You should take it to a qualified repair shop . or ford dealer !
Sep 11, 2016 | 2005 Ford Focus
Why static on motorola CLS 1110?
Are you referring to static (random snapping, crackling, popping) that only occurs when you are handling the radio, or a steady hissing sound when turned on? The first may indicate the radio has a defect or loose internal connection; the second is reduced by adjusting the squelch setting. More information is always helpful.
Aug 01, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
I took my 2006 PT Cruiser to a shop to dtermine the cause of a small drip of coolant. For some reason they tested the electrical system but never found the issue. After I picked it up the radio lights...
Under the hood of your car is a fuse box. Locate the IOD fuse (ignition off-draw) remove it. Wait a minute or three and then reinstall. There's something their that will reset your radio. Good luck!!
Feb 17, 2014 | Metra 2006-2008 Chrysler Pt Cruiser...
Motorola walkie talkie randomly cuts off
buy professional radios and you get better battery contacts
dont go to work with child's toy
Mar 22, 2012 | Motorola Walkie Talkie 2-Way Radio
'02 Rendevous beeping randomly, no lights or trouble indicatiors on. Beeps when parked, beeps while driving, no rhyme or reason apparant. sometimes goes 10 or 15 minutes without beeping, other times beeps...
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line from the IPC or body control module (BCM). If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Is the sound heard different from typical Audible Warnings ?
Fasten Safety Belt Warning
The radio activates the fasten safety belt audible warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, slow rate and duration (5 pulses). The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled, signal is low. The IPC receives a class 2 message from the SDM indicating the driver's seat belt status.
If the seat belt is buckled when the ignition is turned on, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops. If the seat belt is unbuckled after the initial transition to ON, the chime does not sound.
Headlamps On Warning
The radio activates the headlamps on warning as requested by the body control module (BCM). The BCM sends a class 2 message to the radio indicating the chime frequency, fast rate and duration, continuous. The headlamps on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the driver's door is open, signal is low.
• The BCM determines that the headlamp switch is in the park or head position.
Key-In-Ignition Warning
The radio activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open, signal is low.
• The BCM determines that the key-in-ignition switch is closed, signal is low.
Turn Signal Reminder
The radio activates the turn signal warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The turn signal warning sounds when the following occurs:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit, left or right turn.
• The vehicle has traveled a distance of 1.2 km (¾ mi) by counting pulses on the vehicle speed input circuit.
The IPC turns OFF the turn signal reminder when either the ignition switch is turned to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits, left turn or right turn.
Additional Chimes
The following chimes will turn ON when an associated indicator/message turns ON in the IPC/DIC:
• ABS indicator
• AWD Disable indicator
• Battery/Charge indicator
• Brake indicator
• Change Engine Oil indicator
• Door Ajar indicator
• Hot Coolant Temp indicator
• Low Brake Fluid indicator
• Low Fuel indicator
• Low Oil Level indicator
• Low Oil Pressure indicator
• Low Tire Pressure indicator/reset
• Low Washer Fluid indicator
• MIL (Service Engine Soon) indicator
• Oil Life Reset
• Park Lamp Out indicator
• Rear Hatch Ajar indicator
• Service Traction System indicator
• Service Vehicle Soon indicator
• TRAC OFF indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation .
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console .
Did the Mechanic check for DTC'S - diagnostic trouble codes in the BCM or insturment cluster ? Did you try a Buick dealer ?
Jul 09, 2017 | 2002 Buick Rendezvous
XM radio tunes to random station when turned on
There is an internal battery to hold the station and presets. It is probably no good. Either that or there is something very wrong with the unit.
Here is what I recommend. Call XM. Tell them your receiver is not longer functioning correctly and that you are thinking about canceling your service because you don't have a receiver. They will then offer you a receiver because they don't make much money on them, the make their money on the service.
that's how you get a new free satilite radio.
Dec 24, 2009 | XM Radio (XMP6000)
My monitor turns off every 2 minutes, even when you re power the monitor it will just shut down randomly. anybody knows whats wrong with it? and how much it will cost for repairs?
does it always shut down every 2 minutes? or is it "random" like you said? i ask because it can be configured to turn off as desired (that is if it is not used).
http://www.tothepc.com/archives/configure-your-computer-to-turn-off-automatically/
i think this website might be able to help you
Dec 16, 2009 | AOpen F2715 (Black) LCD Monitor
Persistent occurance of "Sirius Seek List"
http://www.sirius.com/pdf/manuals/ST2-User-Guide.pdf
See page 24 on [or search for alert]. It's taken me a while to find this as I HAD the same problem
Mar 13, 2009 | Sirius Satellite Radio Sirius Starmate ST1...
FM radio intermittent static on '95 volvo 940
Sounds like you either left something loose or lost a piece of shielding. Was there a filter on the antenna that you forgot to put back on?
Jan 10, 2009 | 1991 Volvo 740
Vauxhall astra radio keeps switching on and off on its own
I had this problem for the last 2 weeks, didn't think much of it, but recently the car radio just turned on and off by itself, it decided to do so whilst the car was switched off and it drained my battery. After doing some tests with the Amp meter and removing the fuses for the radio and infotainment system the amps going through the batter went from about 0.7 to 0.001 (far more accpetable) - so the radio was draining the battery and randomly turning itself on/changing stations and the internal display system had stopped working.
after putting the fuses back in and re-testing the radio worked fine (almost like it had a full reset - no random turning on and off OR changing of radio stations)
the fuse box for my astra was next to the battery under the bonnet (see your car manual - I had lost mine so googled for it)
http://pdfcast.org/pdf/2006-vauxhall-astra-owners-manual-operation-safety-and-maintenance
PAGE (267 or 265)
but it seems yanking the fuses for the radio (FUSE number 35 and 36) seemed to fix it (been a few days and no flat battery) -
It maybe an intermitent fault, in which case i'll have it looked into, but as garages charge an arm and a leg i'd give this solution a go and if your battery is good all you need to do is remove the fuses and put them back after say a minute or so)
Jun 24, 2008 | Audio Players & Recorders
OEM 2009 Dodge Grand Caravan Radio / CD Player 9zd39692s Without Nav.; AM/FM/DVD/20 Bright green HDD/MP3/factory Passenger Side Rear camera compatible REN, w/SAT radio Houston, Texas Logo
87 people viewed this question
Top OEM Video Cameras Experts
Are you an OEM Video Camera Expert? Answer questions, earn points and help others
