Question about Propellerhead Reason 4.0 - Windows and Mac Upgrade Version for PC, Mac
Reason 4 install prob
Hi
i installed reason 4 in my psl the instal was done properly but now when i run the reason 4 alwasy demand for dvd the dvd is ther but still its not working
pls tellme
  • Anonymous Mar 30, 2009
    i have the same problem
  • v_ton May 07, 2009
    Same **** happend to me :S
    Scholar:
  • 61 Answers
If you installed Reason 4 and the first time it asked for the DVD and you did not have it, you may need to re-install it and then have the disc ready. This happened to me the first time, and I had to re-install the program. It's just part of the copy-protection.
Hope this helps!
Posted on Mar 18, 2009
Just installed a MQ 3 -35 in my home in order to improve low city supplied water pressure (35psi). Now my home pressure is at 75 to 80 psi, too high. How can I regulate the pressure down to 55-60 ps
proper way is to install a water pressure regulator and due to potability reasons it needs to be brass ,bronze, stainless steel, or CPVC plastic , (no steel or cast metal) of course the less high tech way is to plumb a valve from pump outlet back to its inlet and adjust valve to max pressure setting you want at max demand , I don't recommend this method as it wont be able to give you a constant pressure regardless of demand as the first method will , Note: some water regulators are a "relieving" type and require special install methods and maybe three lines to it
Aug 16, 2015 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Unable to complete windows installation
try formatting the drive or use a different drive
Apr 10, 2014 | Microsoft Windows XP Home Edition
How to format windows xp and install windows 7
You need the original installations DVD's.
On windows xp,you can't upgrade to windows 7 so you have to run a clean installation.This is done by inserting the installation DVD's to run set up and following instructions.
To maintain the settings that you have in windows xp,you may need an external hard disk first to migrate files off your pc.This is done using Windows 7 Easy transfer from which you will later re-install your files and softwares.This software is available in windows 7 installations DVD's under support.
Visit this sites to learn more on the installations.
Hope this helps.Thanks!
Please rate this answer.
Oct 23, 2011 | Computers & Internet
My laptop is not showing me the DVD/RW.
Go to device manager by typing devmgmt.msc in RUN option which u find in START option... after that click on CD/DVD drive and press Uninstall.... after that restart the notebook will install CD/DVD drive drivers...... hope this could help u.
Jul 23, 2009 | Quantum Meridian CD Net CD-ROM Drive
Downloaded reason 4, installed it but keeps asking for a dvd
try to use this software to help you.
you can download and even burn youtube videos to DVD .
YouTube video to DVD
Jul 08, 2009 | Propellerhead Reason 4.0 Upgrade - Windows...
APEX Digital VCR&DVD PLAYER ADV-3800 will not play DVD's.
What it so far done, it looks pretty fine. I'd break apart the problem if is posible to do it, i mean maybe you have some other sets around the house or some friend who have them.
  • i'd test the dvd/vcr in a different tv
  • i'd test the tv with a different dvd
i would start over again the installation after this test.
the reason is to know if you can trust in those sets and second maybe with some other try the installation works
May 01, 2009 | Apex Digital ADV3800 DVD Player/VCR
Hi my dvd drive is reporting a prob when uninstalled then re installed
it clearly indicates that it is not connected properly or the area where it is connected is got little bit loose.remove the connection and check it properly to make it connect firmly and then see it will work. thanks.
Jan 04, 2009 | NEC ND-6650A DVD RW Dual Layer Burner
DVD movie prob. w/ Sony Vaio Laptop
Please do not rate this until we have exhausted all problems that it can be. Thank you.
My name is Dean and I have a web site with some things that might help the problem. Even if it does not help it will thoroughly clean your computer of anything that is garbage and things will run better.
First uninstall any program that you have tried to use as long as you have the install disk or the program files to install them again. You will reinstall anything that you need after the computer is cleaned. These are a lot of things to do, but trust me. A woman that has been in the computer business for 25 years di this and it made a keyboard and mouse work after they had almost stopped. So plese go step be step. Follow all directions and go through all of the settings and put anything that you can to a higher setting. Advanced (and or custom) mode installs on anything that you ever install. I am going to post everything seperate as I can until we are sure that everything is clean.
Thank you for your patience, we will get the computer straight if you follow everything.
Jun 25, 2008 | Computers & Internet
Dvd not working
do you have a dvd viewing program installed on the Computer.
Like Power DVD Or Nero.
Try installing one of these or a recent version of Windows media Player. I,d recommend Version 9-10 if your running XP.
mike @ Compurepair.
Feb 22, 2008 | ASUS DRW-1608P2S DVD RW Dual Layer Burner
Cd burner
need to know a bit more like codecs installed , burning software etc.But think if you install program like nero it should solve all your problems cos nero installs all you need to burn media.
Jan 10, 2008 | Acer Aspire 5100 Notebook
Propellerhead Reason 4.0 - Windows and Mac Upgrade Version for PC, Mac  Logo
2,135 people viewed this question
Top Propellerhead Computers & Internet Experts
Chris Larocque
Nikki  Mclean
Nikki Mclean
Alun Cox
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
