Question about Frigidaire Electric Dryer
Runs a sec then says check cord - Frigidaire Electric Dryer
  • 314 Answers
Operational Issues
  • If your Frigidaire washer won't turn on, check that the power cord is plugged directly into the wall and not into either an adapter or extension cord. Examine the water supply valve, and see if it's in the "On" position. If the water supply valve is cracked or broken, replace it. Check the household circuit breaker, and reset if tripped. Look at the fuses, and replace them if they have broken wires or are black. The motor can overheat if you overload the washing machine. It will release a rubber smell. Give it 30 minutes to cool down, and then restart the cycle. Examine the lid switch, which is located in the door frame. Replace if burnt out.
Spin/Wet Load
  • If the washer won't spin, verify that the lid is completely closed. Open up the main housing panel, and locate the pump. Take out the pump, and try spinning the pump pulley. If it won't spin, change out the pulley. Look for broken belts, and replace these components. If the clothes are too wet, check that the cycle is actually finished. Examine the drainage hose, and clean it out if clogged or if it has lime buildup. Verify that only 4 inches of the drainage hose sticks into the tub. Remove any excess tubing. If the tub is not spinning, replace the motor coupler.
Posted on Jan 15, 2013
Hi, I have a nice master B150D that ran flawlessly last season,brought it out this year replaced nozzle,spark plug,new fuel. Fired it up ran for 30 sec. pop's the circuit breaker,reset,runs 20 sec....
if a circuit breaker pops i assume its an RCELD or is it a MCB type
it is some leakage to earth somewhere in the electrics
if it runs and pops the breaker
and you can plug it in and it will sit there
then i assume its something do do with the fan system
or ignitor . driver system
look for sources of leakage to earth
and you could measure the peek current it uses with a multimeter inline
set to AC amps
anyway its defo not a gonner just some bad electrics
Dec 09, 2014 | Heating & Cooling
Lost password for my netgear n300 wireless router how can i retrive
Best way is do a factory reset.Press and hold reset button during this procedure ,do not release the button until you are finished and you will be back to factory default.
1)Hold button 30 sec.
2)remove power cord hold 30 sec.
3)plug in power cord 30 sec.
You should now be in default factory mode,good tyo go.
Nov 09, 2013 | NetGear Computers & Internet
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Will not continue to run when not useing it and air is low
ARE YOU USING AN EXTENSION CORD??
THESE UNITS DRAW SO MUCH POWER THAT THEY WON'T WORK ON AN EXTENSION CORD.
SOME CONTRACTOR MODELS ARE DISIGNED TO WORK WITH AN EXTENSION CORD.
HOPE THIS HELPS
Jun 05, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Power on but nothing on screen
maybe the cords are not correct. and when the system shuts down does it blink red?
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
I am getting an error message "S545"
Fuser unit malfunction code.Check the connectors,thermistors and thermofuses.Reset the code :enter in the service mode (press total clear yellow key and pres 1-0-7 press and hold down more 3 sec.the Clear key (red C key)) turn OFF the machine,umplugged the cords wait 10 sec,plugg the cords amd turn ON the copier.
Aug 14, 2009 | Ricoh Aficio 1035 Copier
Shut it off this a.m and now it won't come on. screen black. can hear it run a little
press and hold the power button for 5 sec. that will shunt down the machine. unplug the machine, press and hold the power button for additonal 30 sec. plug in the power cord and restart the machine
Dec 05, 2008 | Acer Computers & Internet
My wirless connection is not working. I checked with my cable company and it is not the internet connection. It is the wireless from Motorola. I am doing this from my work computer................... a...
reset the router and do installation again. unplug every cord except for the power cord then hit the reset button for 10 sec. then wait 10 sec. more to unplug the router and star your installation again.
Sep 10, 2008 | Motorola Mobility H500 Wireless Headset
MONITOR FAULT
check A/C voltage,fuse,maincap220/450v,bridge rectifire,reg.IC,FET.
check O/P sec. Voltages 5v,12v,65v,80v,150v Voltages may be variations on make.
Combo section 80vdc,60vdc
processor 5v,Vertical sec+12v,-12vdc
filament sup.6.3vA/C
Horizontal sec,H O/p 100v/120v
check dries
and pt
Aug 29, 2008 | Computers & Internet
Frigidaire  Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
