Question about Rapoo H6000 Bluetooth Stereo Headset with Microphone Black
My Rapoo H6000 suddenly stopped working. i couldnt turn it on, nor it charges when plugged into USB. this is the second time it happens.
It was working well day before, then come next morning i cant turn it on, tried charging thinking it is low batt, but no red light is present when i plug it in. HELP.
  • James Brian Tan Jan 16, 2013
    note this is the second tiem this happened on 2 diffrent units. Yes i have 2 non workign devices now T_T
Whi iphone5c suddenly stop working and e charged either?it went off and does not get to be charged either? b
Press down your "home" and "power" buttons at the same time for about 10-30 seconds. Make sure the phone is plugged in while you are doing this. The apple logo should appear after 15 seconds or so. Once it appears, your phone should be good to go!
Feb 15, 2014 | Apple iPhone 5c
Repair the wireless connection
According to Rapoo, the solution is:
Rapoo 2900 E2700 E9080 pairing steps
1. Please first charge the keyboard to make sure the energy level is good.
2. the pairing steps are:
a : turn off the keyboard,
b: plug in the receiver,
c: turn on the keyboard
d :keep pressing "Esc" and "Pause break" keys for 5 seconds
3. If it is repaired successfully the mouse cursor can work normally. Please remember to plug the receiver again after successful pairing.
Unfortunately, I don't seem to make mine work at all :(
Maybe it's broken.
Dec 13, 2013 | Rapoo E2700 Wireless Multi-media Touchpad...
Rapoo H6060 red light doesn't go off
DUDE THIS SAME THING IS HAPPENING WITH ME BUT I BOUGHT IT YESTERDAY AND TODAY NIGHT IT SHOWS RED LIGHT CONTINUOUSLY! PLISS HELLP MEE
May 23, 2013 | Universal Rapoo H6060 Bluetooth 2.1EDR...
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Nuvi 760 suddenly stopped working - will not turn back on
Try holding the power slide to the left and holding it there for 8 seconds. If that doesn't work, try charging it via your PC & USB cable. If that doesn't work, try a mains charger if you have one (I had to do this with mine). Good luck!
Dec 30, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Sony Ericsson K770i Phone won't turn on red light apears on the top left, any suggestions?
This has happened to me twice - the first instance occurred when I'd only had the phone a few days and the second occurred today after months of trouble-free use.
On both occasions the phone wouldn't charge via the mains charger - it wouldn't switch on even when plugged in and neither the battery or the charger were warm to the touch after hours of charging, indicating that nothing was happening.
The solution for me was to connect the phone to my PC via the USB cable - nothing happened at first, the PC didn't recognise the phone and it remained lifeless. However, I left it attached to my PC and after 10-15 minutes it suddenly whirred into life.
The battery was COMPLETELY flat despite my attempts at mains charging, so I let it charge via USB for a while then transferred it to the mains charger. This time the mains charger worked.
I've no idea why, but this has worked for me twice so give it a try.
Jun 07, 2008 | Cell Phones
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
have you only been charging it with the usb cable?
try plugging it into a ac adaptor, (make sure the button is in the off position at the bottom)
and it should hopefully restart, then turn it to the on when it's loaded, and leave it plugged in till it's completely charged
that might work
Feb 26, 2008 | Toshiba gigabeat S MP3 Player
Rapoo H6000 Bluetooth Stereo Headset with Microphone Black Logo
55 people viewed this question
Top Rapoo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rapoo Audio Player and Recorder Expert? Answer questions, earn points and help others
