Question about Compaq Presario M2000 Notebook
Vertical line on monitor screen appear when i pressed power option
  • 109 Answers
There are two possible reaseon :
1- Internal Screen cable connector mal functionning (To be replaced)
2- Screen replacing.
Posted on Jan 15, 2013
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
LG20" monitor. Suddenly a red
Try to reset it
Scroll through the menu options by using the up and down arrow buttons located just under the "Menu" button. Scroll down to the "Setup" icon, which looks like a big cog. Press the "Auto/Set" button to access the Setup menu. Scroll, using the down arrow, to "Factory Reset." This setting is located at the bottom of the Setup menu. Press the "Menu" button on the right side of the monitor. This will bring up the On Screen Display. If nothing happens when the "Menu" button is pressed, press and hold it for several seconds to unlock the On Screen Display. Press the "Auto/Set" button to choose "Factory Reset" and then press the down arrow to reset the monitor.
Jul 23, 2011 | LG Computers & Internet
Hi, i have AL1716 monitor (2 year old). Recently, there is a blue vertical line which appears on and off sometimes in the monitor. Can anyone suggest on a solution
Is the vertical line always at one location ? (on the screen)
If so, it appears that the video card/driver (on your PC or laptop) may be causing the line to appear occasionally ... i.e. flaky ... and it will likely fail (completely) in due time. To confirm it's the video card, try using another monitor (long enough) to see if it happens.
[ The line may also be caused by "dead" pixel on the screen ... but this usually happens on randomly located pixels on the screen, not on one vertical line. But, it may also be a possibility ... in which case, using a different monitor may prove it one way or the other ]
Aug 11, 2010 | Computers & Internet
Vertical lines accross the screen
Vertical lines running down the screen is indicative of a data failure to the screen itself, which means either the screen is starting to fail or the data being transmitted through the data cable is being interferred with. Put a hand on either side of the monitor and give the monitor a light twist....does the line disappear? or do more lines appear...in either case, there is a problem where the data cable attaches to the lcd panel itself. You can try to change out cables, if that doesn't correct it, then the panel may have to be replaced. If you have the option of trying the computer on another monitor that would be the first step in seeing where the problem lies.
May 24, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
A vertical line has appeared just off of the center of the screen. I have unplugged turned off reset and changed the background but the line stayed.
The vertical lines means you have failing T-CON board, part of the LCD panel assembly, it will get worst, new LCD panel will be needed. Westinghouse uses cheaply made screen like CheiMai, not LG/Philips.
http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | Westinghouse L1975NW Monitor
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Green line vertical on screen keeps appearing
in the monitor menu button you will be having a option called "degauss" give that when it appears ...
if you still persist the same problem then there may be some problem in the CRT tube ....
just take your monitor to the technician ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Aug 12, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Display
HI,
Disconnect the monitor from the computer and check if the vertical line still appears on the screen . If yes the monitor needs to be replaced.
Generally all viewsonic screens come with 3 yr warranty and you can call them up for repairs or replacements .
Thanks
Proton
Jul 26, 2008 | ViewSonic VX2235wm LCD Monitor
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Apr 09, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Compaq Presario M2000 Notebook Logo
16 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
