Question about Optoma EP739 Multimedia Projector
Do optoma projectors have fuses?
Bulb replacement did not work I figure it might be a fuse that relays power to the bulb
SOURCE: No Power
The problem with the bulb cover interlock(safety switch) tab is that it is molded with the plastic cover. When these projectors are ceiling mounted upside down, the heat from the bulb melts the interlock tab and causes it not to actuate the interlock switch. 5e5b596.jpg If you push the switch arm in you can hear the switch click. The fix I did on my projector was to bend the switch arm so that it stays actuated. You can use a small set of needle nose pliers or two small screwdrivers. be careful to only bend the arm in the middle, if you break the arm from the switch, you will have to go in and bypass the switch.... Just be carefull...
c0cb930.jpg After you bend the switch arm try to press it in, if you did it right you won't hear the click. install the lamp, cover, and your done.
Posted on Apr 14, 2009
  • 7 Answers
SOURCE: optoma DX605 hard reset
Have you tried going to Menu>Options>Lamp Settings>Lamp Reset>Yes?
Hope this helps!!
Posted on Jul 13, 2009
SOURCE: OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Posted on Mar 29, 2010
SOURCE: My Optoma HD72 projector operates for about 1
The problem is not over-heating. The Optoma HD72 has a known problem that Optoma won't advertise. The lamp driver is faulty. They simply have to replace the lamp driver. I purchased a spare lamp with my original purchase. I had the exact same experience as you at around 1200 hours on the lamp in ECO mode. I used the spare lamp. Same thing happened at about 1200 hours. I had a friend at Optoma. he confided to me the problem. I sent it in and they replaced the lamp driver at no charge. I got another 800 hours out of the first lamp and am now using my second lamp and have about 600 hours on it. The pic quality is so good with this projector (used Digital Video Essentials to calibrate) that I'll just order a bare lamp or two and use the existing lamp housings when I need a new bulb.
Posted on Jun 19, 2010
SOURCE: How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Posted on Jan 28, 2011
Replaced the head lamp bulb but only works on high beam
Make sure the other filament is good and that it is receiving power. If no power check relays, fuses, switches,etc for low beams.
Mar 31, 2016 | 2008 Pontiac Torrent
I am trying to figure out which fuse to change or is it a relay. Nothing in the owners manual or the under the hood fuse boxes is labeled clearly.
Andrae, If it is just the right rear signal not working, re check the bulb and wires to the socket, signal bulb should have 2 filaments. When you put emergency flasher on do both tail lights flash, .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 25, 2016 | 2006 Dodge Durango
Left headlight replaced but still not working, swapped with right bulb so bulb is good
If you checked for power inside the socket(power and ground) the bend the tabs in the socket to touch the bulb wires. They get hot and bend. pull them out a bit.
May 19, 2015 | 2008 Hummer H3 Alpha
Stop lights not working
You need to test for power and ground at the connector for the bulb. If no power, then you need to spend some time to figure out why. If power and ground are there, you have a bad bulb.
Sep 04, 2014 | 2004 Dodge Dakota
Fog lights on my 2003 mazda 6 not working. fuse & relay are both ok, but no power going to the bulb. is there another fuse other than in the drivers compartment panel?
probably corrosion on the ground wire to the bulbs or the wire to the bulb did he check from chassis to connector or just take the bulb out sounds like you need to find a real mechanic
Mar 02, 2013 | Mazda 626 Cars & Trucks
Bulb blows on gt700
Possibly a bad ballast or power supply going to it causing it to either kill the bulb or your old bulb may still be good. Did you rest the counter in the menu for the bulb life after replacing?
Nov 05, 2012 | Optoma GT700 Projector
My headlight on my volvo v4o isn't working i have replace bulb
If the fuse is OK it is probably Central Electronic Module. There are some relays in it that switch high-current deviced as headlights. The relays sometimes are dead after years of work. It is possible to replace only the relays (about 1 euro) instead of whole module (a few hundred euros at the dealer).
Jul 20, 2012 | 2002 Volvo V40 Wagon
Headlights burned out replaced and still not working
check fuses and relay there is 2 fuses and 2 relays one for left one for right
also probe for power at light and also gronnd you may have also purchased the wrong bulb
or a bad bulb
Apr 02, 2011 | 2003 Chevrolet TrailBlazer
My Optoma HD72 projector operates for about 1 minute and then shuts off. I kept my old bulb around "just in case", I've replaced the bulb with the old one and have the same problem.
Apr 12, 2010 | Optoma H30 Multimedia Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
Optoma EP739 Multimedia Projector Logo
57 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
