Question about D-Link DPH-540
Can't get the D link DPH 540 TO GET A CONNECT TO WI FI
The Phone say no service, no sip account. I have a couple of hot spot next to me. So Please telle how to set up ,my phone to work. I just bought this phone a couple of days ago. I follow aht was in the manule I have a dph 540
  • 3 Answers
Dear Stoneway,
First create a network profile if not yet done so
Menu > Profile > Network Profile
then edit it, go to Account Choice and select "Default".
The "No SIP Account" error most likely comes from having a blank field in "Account Choice".
It's easier to set up the DPH-540 from the web admin interface, so you can try first to at least get an IP address assigned to the phone then use that IP address to access the phone from another laptop on that same wireless network. But again by the time you manage to thumb your way to get an IP address assigned, you have 3/4 of the problem already resolved so you may as well thumb in that finishing touch :-)
Viet
Posted on Mar 30, 2009
Need a manual for Samsung 4G so I can hott spot my laptop
no you don't need a manual its easy
Go to your normal home screen on the phone . Ie unlock the screen.
At the top of the screen you will see small white symbols .
put finger on them and pull/ drag finger down to see hidden menu
You will now see wi fi , location, sound, screen rotation, bluetooth
put finger on right hand side of these options and drag finger left
the forth option shown should be mobile hot spot
press on mobile hot spot with your finger
Attention
Enabling mobile hotspot will turn off wi fi
Cancel or OK
Click on OK ( you use wi fi to link the mobile data to the laptops , ect)
on your laptop you will see androidap as a wi fi network connect laptop to this !
network key come up
what is the password
go into the phones settings
look for Tethering and Mobile Hot spot
click on this
click on Mobile Hot spot
step 3 in list of instructions that have now come up will be the AndroidAP password you will need on the laptop , ect
Put password listed into laptop wi fi connection password question.
PS put mobile on usb power or usb charger while hotspotting !
Dec 08, 2017 | Samsung Cell Phones
Tip
No special firewall rules needed for DPH-540 and Dlink DI-604 router
My DPH-540 works fine behind a DI-604 NAT router, without any special firewall configuration on the DI-604 (I connect to either RingCentral or SIPPhone). I hope to get another SIP phone and see if both phones can work simultaneously behind the NAT router; many web sites suggest that a different proxy port must be used (the default is 5060).
on Jan 05, 2009 | D-Link DPH-540
Tip
Configure the DPH-540 with RingCentral
To get the DPH-540 to work with RingCentral, you need to add a DigitalLine to your RC service. Then you need ignore the email sent by RingCentral which provides configuration info; instead, login to your account on the RC web site.
Click on the Preferences tab, then the "Setup Instructions" for the DigitalLine device. That should produce a popup window with info like:
SIP Domain: sip.ringcentral.com:5060
Outbound Proxy: sip.ringcentral.com:5090
User Name: 1805715xxxx
Password: yyyyyyy
Authorization ID: yyyyyyy
The password will be the same as the Authorization ID.
Configure your DPH-540 just enough so that it can obtain an IP address via DHCP. Then use a browser to configure most of the rest of the DPH-540 (user admin, password admin by default). However, the browser interface does not let you associate a SIP configuration with a profile; that must be done on the phone itself (consult the userguide and just keep at it; it's not that hard).
For an image of what the web interface and config page for a DPH-540 SIP configuration looks like, see http://homepage.mac.com/saj777/techtips/DPH-540_RC-config.jpg
Can I get Wi-Fi hot-spot on my mobile and charge it on my account on next payment
You need to check the manual for your phone to see if it will work as a hot spot. You didn't say what the make and model is so I cannot help you with this, so check the manual. You will also need to have a data plan on your phone, not just a call plan.
May 24, 2016 | Cell Phones
Can I hot spot this phone to a wi fi
Hi Shelagh, If you're trying to connect to your home Wi-Fi The password is on the back of the modem, Write it down then go into your phone/tablet settings and tap "CONNECTIONS", Then tap on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens for the password, Type in the pass word tap ok and you're connected... Bellow is a link to a short youtube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
Apr 03, 2016 | Samsung GT-S5310 Galaxy Pocket Neo...
Why can't I connect to wifi anywhere?
there are two systems.
Mobile data and private Wi Fi networks.
Some Wi Fi networks with limited range are available at Wi Fi hot spots but you need to know the password to connect.
In my country Australia Telstra is going to offer Wi FI hot spots for its home users broadband customers and will then bill the usage to their home account. https://www.telstra.com.au/broadband/telstra-air
this is a new network concept in its infancy
Dec 31, 2015 | Tablets & eReaders
What is wi fi
wi fi is what we called wireless internet,, it comes up with the latest phone like your phone,, it is built in, go the the nearest hot spot area to connect to the internet using your phone's wi fi,, it is free to surf like on personal computers internet,, how lucky you are!
Nov 24, 2010 | Samsung S5620 Cell Phone
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
Update the firmware of D-Link DPH-70s to support SIP protocol
this phones doesnt got support for standard SIP protocol, so its not supported by any major voip provider.
Jan 11, 2007 | D-Link IP PHONE DPH-70S WITH BUILT IN...
D-Link DPH-540 Logo
283 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
