Question about Samsung HTZ-510 Theater System
The motor runs when I am in t.v. sound mode
My t.v. and sound system are connected using anynet when the receiver powers up the sound comes on and seconds later a motor starts. I believe it is the motor that spins the tray. I bought this in May 2009
  • bill menear Jan 15, 2013
    Thanks,the fan motor is the noise and yes it was dusty and i vacuumed it out and it is still noisey may be the bearing do you know how to get it out?
  • Steve K Jan 15, 2013
    If you take the fan out (there are two screws in the back panel) under the sticker on the back of the fan there will be a rubber plug. If you pull this plug out, put a couple drops of oil in there and let it soak in (any household oil will do, like 3-in-1 oil). Put it all back together, and it should be much quieter.
    Genius:
  • Samsung Master
  • 1,054 Answers
Are you sure it's not the fan on the back of the unit. the bearings on these fans tend to get dirty and noisy.
Posted on Jan 15, 2013
Where do I find the any net setting
Internet Explorer browser settings - Windows - Microsoft
windows.microsoft.com/.../internet-explorer-browser...
Microsoft WindowsLinks to information about how to set options in Internet Explorer.
Internet Explorer Connections settings: recommended links
windows.microsoft.com/.../internet-explorer-connecti...
Microsoft WindowsFind more information about Internet Explorer's connection settings.
How to turn on HDMI control, Anynet, SimpLink - YouTube
? 6:47
https://www.youtube.com/watch?v=Qa_V3lIaJ8M
Sep 26, 2011 - Uploaded by Tampatec
How to activate hdmi setting on tv & receiver & bluray ps3 player, What is Hdmi control, anynet, simplink ...
Setting Up Anynet; Switching Between Anynet+ Devices .
Jan 14, 2016 | Televison & Video
How do I connect Samsung smart TV to a Yamaha receiver and get sound to come out of surround sound speakers?
Generally you will connect the Digital audio or optical audio cable from TV to the input of Receiver. Then using the remote control of Receiver you will program the source for digital audio or optical audio as TV. I am assuming the speakers on the receiver are already connected and working. All you do is then turn on TV and turn on Receiver and select TV on Receiver. The TV audio will play through the receiver. Make sure the TV sound is in Mute.
Aug 07, 2014 | Yamaha Audio Players & Recorders
Whwn I switch on the system and even when the sound is ZERO. there is a hissing/humming noise from all the speakers. Not sure whay this sound is there.
It is noise most often referred to as E.M.I. or R.F.I. ( electromagnetic or radio frequency interference). Sources of it can come from other devices plugged into the same circuitry or from nearby running appliances containing electric motors such as fans, or fluorescent lighting.
Things that you can do to reduce this are as follows;
Relocate the receiver and/or plug it into a different outlet.
Plug the receiver into an electronic interference rejecting device such as a power conditioner.
Use ferrite clamps on your power cord of the receiver and all of it's connected devices, and on the analog audio inputs.
Move any power cables closer than about 6" to any other cables connected to the receiver, and any cables crossing each other at 90 degrees.
Make sure all of your RCA, composite and coaxial connections are completely inserted on each end and tight.
Nov 14, 2010 | Audio Players & Recorders
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
No sound when in tv/video mode
Do you have it connected with HDMI? If so, run the HDMI directly to the TV and run an optical or digital coaxial to the receiver. That will solve the problem. If that's not the case, go into the receiver's main audio menu and make sure it's set to "auto" or "digital" or "analog" whichever you are running. Hope this helps
Oct 17, 2009 | Sony BRAVIA DAVHDX275 Theater System
No sound
If your TV is a Samzung, and has the Anynet+ function, you need to set the TV up with the Theater system. If there is an Anynet button on your TV remote, push that, and then select the function that sets up the sound system to the TV. If you don't see that button on your TV remote, then look for the option in the TV menu section. Once set up, you can use the menu under that Anynet button to turn off the sound system and return to normal TV audio... and while using the sound system audio, you can control the sound system volume, or mute it, with the TV remote.
Dec 22, 2008 | Samsung HT-Z310T Theater System
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Nov 21, 2008 | Samsung HT-AS720ST Theater System
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Problem with Marantz SR5500 Receiver
Sounds like you have an issue with your electrical circuit. Your receiver could be receiving spikes of current from the electrical wiring in your house.
Review your current electrical situation. Keep in mind that certain outlets are on the same circuit and that running multiple, high-wattage devices on the same circuit can cause issues with some of those devices. Especially when it comes to turning devices on and off.
Many devices take a sudden, rapid charge to power their circuitry the moment you turn the device on. Home audio and HVAC systems are particularly notorious for doing this. Other devices on the same circuit can sometimes suffer influxes of power flow and may either turn off or go into standby mode to protect themselves from the resulting surges.
I've lost audio systems that way... I lived in an apartment building that has wiring most likely dating back into the 40's. I once turned on a space heater on it's max 1500 watt setting and blew my Logitech Z-680 speakers. (The "BOOM" sound that emitted from my subwoofer was AMAZING. I had just blown an amp circuit. It literally exploded inside of the subwoofer. Took pics and everything.)
If you have the means to do so... You might consider re-wiring your electrical circuit. Take into consideration where you're going to run certain devices and wire the system accordingly.
In the meantime, you would want to be sure to buy a HIGH-QUALITY surge protector for the audio system. Spend a few bucks and get a GOOD one with a good warranty on it. Don't use those cheapy ones that we only really use to split the outlet. NOTHING under 1,000 joules.
My receiver sometimes locks itself like that, though. If we have a power outage or the unit is unplugged suddenly, it will keep itself in standby mode until you unplug it, press the power button a few times to discharge any current left in the capacitors and plug it back in normally. Only then will it turn on again.
Let me know what you come up with.
Cyryl
Nov 02, 2007 | Marantz SR5500 Receiver
Samsung HTZ-510 Theater System Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
