Question about RCA L37WD12 37 in. LCD HDTV
RCA 32LA30RQ 32 Inch Tv won't change inputs... The Power buttons work on both the tv and remote, I have sound and i can play my PS3 But I can't change the input. I tried with both the remote a
I tried changing the Input with the remote and the tv itself. Nothing is working.
2 Suggested Answers
  • 43 Answers
SOURCE: rca truflat tv with univsersal
Look for a "source" button, if you do not find one, just try scrolling through the channels as some TV sets will cycle through inputs after you cyucle through channels.
Posted on May 05, 2011
RCA 32LA30RQ TV color distorted from all inputs
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
CQC08001026140 RE46LK1300 Leke LK PI320402A Power Supply Backlight Inverter
Dec 30, 2013 | RCA 32la30rq 32 Black Tv 720p - Lcd - RCA
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
TH BUTTONS ON MY RCA 32 INCH TV WON'T WORK
If all do not respond the set likely has a keyboard lock feature---look to the owner manual and read it carefully.
Dec 09, 2012 | RCA L32WD12 32 in. LCD HDTV
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
I have a 32 "
Check how you have the satellite cabled. I suspect that you have the video from the satellite to the TV but the audio cable going directly to the stereo. You probably have the DVD audio and video going directly to the TV. (I'm assuming you have the 32LA30rq and not the 32LA30rqd which has a built-in DVD and thus has the audio connection inside the TV.)
Since you don't mention which connection you are using for the DVD player and for the satellite, I will just mention the basics. If your DVD player is connected to one of the HDMI ports, that cable carries audio and video between the TV and the DVD player.
Devices that use component video cables use two separate cables. One cable with two sets of three RCA plugs carry the video; a second cable carries audio with 2 RCA plugs on each end. When you connect these, you do not have to connect the audio to the TV. (Similarly, a composite video connection can be modified for one line with the video signal going to the TV and the audio cable going to a speaker system.)
If my solution is correct, you may want to rearrange things. You can connect the satellite audio out to the TV audio in at the same location as you have the satellite video in. Then connect the TV's audio out (to the right of the component 2 in and above the coax audio out) to the stereo. Then switch the TV speakers off to use the stereo - Menu > Sound > Other Settings > Speaker On/Off. Then both devices will play either at the TV speakers or the stereo depending on the state of the TV speaker setting.
The manual is available here: http://tv.rca.com/product/manualdown.asp?modelnum=32LA30RQ .
I hope this helps.
Jan 20, 2011 | RCA Televison & Video
AWe are attempting to play PS Three, but the Inputs on the front and back of tv for the RCA cables arent working. What should we do to make the inputs work?
change the input, i have the same configuration ps3 and 52 inch rca, just plug it into front and change the input to front, if that dont work try this, since your ps3 probably came off a tv that had hdmi you need to hold down the ps3 button for 9 seconds and it will ask you if you want to change it to lower settings, but first make sure you have the input right
Sep 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Problem with remote control for my new Element brand tv
look for a button thats says tv/vcr, input, or a/v and it should switch your input.
Dec 25, 2008 | Olevia LT32HVM 32 in. LCD Television
Whana change my sanyo tv to input to play games?
you need a sanyo remote with input button - can buy from www.sanyo.com
Dec 09, 2007 | Sanyo DS31590 31" TV
RCA L37WD12 37 in. LCD HDTV Logo
131 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
