Question about Electrolux & Frigidaire 5308950197 Washer Tub Seal Kit
HOW TO INSTALL 5308950197 - Electrolux & Frigidaire 5308950197 Washer Tub Seal Kit
  • Electrolux Master
  • 15,557 Answers
How easy is it to change a heater core in a2003 Kia sedona
It is in no way easy. But if you want to try, here are the instructions....
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Disconnect the negative battery cable.
  4. Remove the heater hoses.
  5. Remove the driver air bag module.
  6. Remove the steering wheel.
  7. Remove the turn signal assembly.
  8. Remove the upper and lower steering column covers.
  9. Remove the A-pillar upper trim.
  10. Remove the instrument cluster trim.
  11. Remove the instrument cluster.
  12. Remove the A-pillar lower trim.
  13. Remove the hood release handle.
  14. Remove the left lower trim panel.
  15. Remove the multi box.
  16. Remove the audio panel.
  17. Remove the ventilation control panel.
  18. Remove the radio.
  19. Remove the glove box.
  20. Remove the center console.
  21. Remove the audio system speakers and mounting bolts from the top of the instrument panel.
  22. Remove the side covers.
  23. Remove the T-bar mounting bolts.
  24. Remove the bottom mounting bolts.
  25. Remove the instrument panel wiring harness connectors.
  26. Remove the instrument panel.
  27. Remove the heater unit.
26096060-nraukxomtaildozoxjjbr22p-1-0.gif 26096060-nraukxomtaildozoxjjbr22p-1-1.gif
To install:
  1. Install the heater unit.
  2. Install the instrument panel.
  3. Connect the instrument panel wiring harness connectors.
  4. Install the bottom mounting bolts.
  5. Install the T-bar mounting bolts.
  6. Install the side covers.
  7. Install the upper mounting bolts and audio system speakers.
  8. Install the center console.
  9. Install the glove box.
  10. Install the radio.
  11. Install the ventilation control panel.
  12. Install the audio panel.
  13. Install the multi box.
  14. Install the left lower trim panel.
  15. Install the hood release handle.
  16. Install the A-pillar lower trim.
  17. Install the instrument cluster.
  18. Install the instrument cluster trim.
  19. Install the A-pillar upper trim.
  20. Install the upper and lower steering column covers.
  21. Install the turn signal assembly.
  22. Install the steering wheel.
  23. Install the driver air bag module.
  24. Install the heater hoses.
  25. Connect the negative battery cable.
  26. Fill the cooling system.
  27. Start the engine and check for leaks and proper heater operation.
Feb 15, 2016 | Kia Cars & Trucks
How to remove thermostat on 06 Toyota alvlon 3.5 engine
(a) Install a new gasket to the thermostat. (b) Install the thermostat with the jiggle valve facing up.
HINT:
The jiggle valve may be set within 10°of either side of the prescribed position.
2. INSTALL WATER INLET
Torque: 10 N·m (102 kgf·cm, 7ft·lbf)
3. INSTALL RADIATOR HOSE OUTLET
4. INSTALL IDLER PULLEY SUB-ASSEMBLY NO.2
5. INSTALL FAN & GENERATOR V BELT
6. INSTALL ENGINE MOUNTING BRACKET FRONT NO.1 LH
7. INSTALL ENGINE MOUNTING CONTROL BRACKET
8. INSTALL ENGINE MOVING CONTROL ROD
9. INSTALL V-BANK COVER SUB-ASSEMBLY
10. ADD ENGINE COOLANT
11. CHECK FOR ENGINE COOLANT LEAKS
Jan 29, 2016 | Toyota Cars & Trucks
Dell studio one touch screen is not working
DO NOT install Dell Touchscreen driver as it does not work with MS Touch Pack
Update Windows
Install Dell Fingertapps Touch Zone.
Install Dell Cozi YouPaint, Dell TouchCam, TouchCam Update
Install MS Touch Pack. Find here - http://forum.tabletpcreview.com/showthread.php?p=179262
Install MS XNA 3.0
Install MS Bing Virtual Maps 3D
Install Next Window Touch Screen Driver 1.3.2.5. Find here -http://www.nextwindow.com/nextwindow_support/download_confirm.html
Optional - Uninstall MS XNA 3.0, Install MS XNA 3.1
Sep 02, 2013 | Dell Computers & Internet
Need timing belt digram for a 2000 kia sportage
  1. Install lower timing belt cover.
  2. Install upper timing belt cover.
  3. Install power steering drive belt and adjust belt tension.
  4. Install fan pulley.
  5. Install generator drive belt and adjust belt tension.
  6. Install A/C drive belt and adjust belt tension.
  7. Install splash guard.
  8. Install fan and fan shroud.
  9. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  10. Install fan shroud mounting bolts.
  11. Install fresh air duct.
  12. Connect hose to resonance chamber.
  13. Connect battery negative cable.
Apr 17, 2013 | 2000 Daewoo Nubira
How do u set timing on it? 1.8 engine
Installation
Install crankshaft sprocket on crankshaft.
Make sure mating marks on crankshaft sprocket face front of engine.
Position crankshaft so that No. 1 piston is at TDC and crankshaft key is at 12 o'clock.
Install slack side timing chain guide and timing chain tension guide.
Install timing chain on crankshaft sprocket.
Set timing chain by aligning its mating mark with that on the crankshaft sprocket.
Make sure sprocket's mating mark faces engine front.
Install camshaft sprockets.
Set timing chain by aligning mating marks with those of camshaft sprockets.
Install camshaft sprocket bolts to correct torque.
Apply new engine oil to bolt threads and seat surface.
Install chain tensioner.
Before installing chain tensioner, insert a suitable pin into pin hole of chain tensioner.
After installing chain tensioner, remove the pin.
Install timing chain guide.
Install O-rings to cylinder block.
Before installing front cover, remove all traces of RTV silicone sealant from mating surface using a scraper.
Also remove traces of RTV silicone sealant from mating surface of cylinder block.
Apply a continuous bead of Genuine RTV Silicone Sealant or equivalent to mating surface of front cover. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Check alignment of mating marks on chain and crankshaft sprocket.
Align oil drive spacer with oil pump.
Place timing chain to the side of chain guide. This prevents the chain from making contact with water seal area of front cover.
Install front cover.
Make sure two O-rings are present.
Be careful not to damage oil seal when installing front cover.
Install cylinder head bolts at engine front side as shown in Fig. 55.
Tightening procedure:
Tighten bolts (1 - 4): 6.3-8.3 N.m (0.64-0.85 kg.m, 55.8-73.5 in.lb).
Install oil pump drive spacer.
Install water pump and water pump pulley. Refer to REMOVAL AND INSTALLATION .
Install idler pulley and bracket.
Install RH engine mounting bracket
Install RH engine mounting.
Install oil pan. Refer to INSTALLATION.
Install crankshaft pulley.
Remove ring gear stopper.
Install starter motor.
Install cylinder head front cover.
Apply RTV silicone sealant to cylinder head front cover.
Use Genuine RTV Silicone Sealant or equivalent. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Install Camshaft Position Sensor (PHASE).
Before installing rocker cover, apply a bead of Genuine RTV Silicone Sealant or equivalent, to mating surface of cylinder head as shown in .
Install rocker cover gasket into rocker cover.
Install rocker cover and tighten in numerical order as shown in
Install spark plugs.
Install ignition coils.
Install front exhaust tube.
Install front/right-side splash undercover.
Install front RH wheel.
Install drive belts.
Adjusting drive belt deflection..
Nov 29, 2010 | 2002 Nissan Sentra
How to Install Two Operating Systems in my Computer
What do you mean by two Operation system do you want to install WinXP and WIn 7 or you want to install windows and Linux, if you want to install windows XP and windows 7, install windows XP first in once drivve ie: drive C: and then install windows 7 in another drive.
If you want Linux and Windows combination the install windows first and then install LInux. hope that helps if it helps please vote for me :)
Aug 10, 2010 | Computers & Internet
Remove ignition switch for a 2004 kia optima
Ignition Switch Removal & Installation To Remove:
  1. Disconnect battery negative cable.
  2. Disarm air bag system.
  3. Remove driver air bag module.
  4. Loosen screw and lift horn pad to remove.
  5. Remove lock nut and washer. CAUTION
    Do not hammer on steering wheel. Damage can occur to the energy absorbing portion of the steering column.
  6. Pull dynamic damper forward and lift up to remove.
  7. Remove steering wheel.
  8. Remove steering column shrouds.
  9. Remove lower cover.
  10. Remove multifunction switch.
  11. Remove entire lower portion of dash.
  12. Remove mounting fasteners and lower steering column.
  13. Remove bolts and separate ignition switch from steering column.
To Install:
  1. Install ignition switch to steering column and install bolts.
  2. Raise steering column and install mounting fasteners.
  3. Install lower portion of dash.
  4. Install multifunction switch.
  5. Install lower cover.
  6. Install steering column shrouds.
  7. Install steering wheel.
  8. Install dynamic damper.
  9. Install washer and lock nut.
  10. Lift horn pad and install screw.
  11. Install driver air bag module.
  12. Connect battery negative cable.
Jul 17, 2010 | 2004 Kia Optima
My lexmart X5470 will not scan
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
You need to install the application software .just install the cd which come along with the scanner it contains the driver as well as the scanning software just install it .then you will be able to use the scanner button .
Kindly install the scanner software for printer..You just re install the driver software cd it will automatically install the missing components
Have a nice day and do not forget to rate please...!
Feb 12, 2010 | Lexmark X5470 All-In-One InkJet Printer
I don't know how install driver to positivo sim 1025, like a special manner to do it . I tried almost every manner , but work partially only , and if restart, don't have audio driver active
install chipset driver 1st then install then install graphics driver then install audio driver then other driver or install the chipset driver 1st then install other driver using device manager
Jan 11, 2010 | Computers & Internet
WHEN I INSTALL LINUX FEDORA, I WAS UNABLE TO PLAY THE VIDEOES AND MP3 SONGS N NEITHER ANY EXE FILE EXECUTED.....
In order to play MP3's you will need to compile and install the " lame " audio codec's.
You will also need to install codec's to play back video.
You will also need to install Wine to run windows EXE's within linux.
To install A large package containing the most popular codecs
I believe you need to install the livna repository if you have notalready done so. The instructions for doing so are located here : Livna
Then you can install with yum
amarok-extras-non-free
you may also need to install
gstreamer
gstreamer-plugins-bad
gstreamter-plugins-ugly
and perhaps some others .. just do a yum list | grep gstreamer
or
yum -y install yumex
and you can use yumex [gui for yum] to search
You may also want to install the codec package which you can grab here : Codecs
And follow the instructions here to install them : Installation
To install Wine you can simple type the following command into any shell / terminal available
yum install wine
or
su yum install wine
May 31, 2009 | ASUS Computers & Internet
Electrolux & Frigidaire 5308950197 Washer Tub Seal Kit Logo
82 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
