There's a barely visible green line running horizontal through the centre of the television. When light passes over it, it turns red.
    Problem Solver:
  • 8 Answers
I had a similar problem with a lg 47". Exactly like your problem but I had alot more lines. Turned out they said it had missing pixels. Which was a factory defect. Noticed 3 days after purchase, so I was refunded.
Posted on Jan 15, 2013
  • Kieran Hockins Jan 21, 2013
    This isn't a new set, it's about a year old. As far as I'm aware the red line appeared after a blackout one night.
  • 4090 Answers
SOURCE: I have blueish green lines
like 3D? This is a convergence chip problem. You can try tuning it from the settings in memu But it will eventually show up again> sometimes after you turn it on the next day. The only true way to fix it is to have the chip replaced. It is not a DIY as these chips are soldered to the board.
Posted on Sep 19, 2009
tvservice306
  • 458 Answers
SOURCE: black horizontal line, red parallel vertical lines
REPLACED LCD PANEL
Manufacturer Sharp Part Number RF-R1LK420D3LF2 Description 42" WIDE LCD PNL -
Posted on Sep 28, 2009
Randyincv
  • 17 Answers
SOURCE: television when turned on: light goes to green
If the Red Light Blinks twice and goes out, the TV is in Protection Mode. There are 6 voltage outputs to the lamps around the screen. If one of those outputs is missing the TV will sense that there's a problem and refuse to turn on. The predominant failure in this model are the output transformers on the Inverter board. A properly trained technician can measure the windings on each transformer and look for an open circuit, if one is found, replace that Transformer. i was given one of these sets from a friend and I replaced an output transformer ($11 w/shipping) and I now have a fully functional TV/DVD Combo. Also verify that all of the connecting cables internally are properly seated, there have been reports or the ribbon cables from the Power supply board to the main board above it not being fully inserted and it also prevented the TV from turning on. A word of caution. There are VERY High Voltages on the inverter circuit board, only persons with proper training and knowledge should attempt this repair.
Posted on Oct 31, 2009
SOURCE: LCD television
There are 2 resistors off of the Z3 diode they are 10 ohm chips (100 on chip) these were also open.
Posted on Dec 03, 2009
SOURCE: Samsung HPR4252 with red horizontal lines accross the screen
I just had my HP-R4252 repaired on 12.05.09 with a similar problem. The picture is covered in horizonal, broken lines and the color is predominately red. They lines are grouped together in large bands across the screen.
The tech replaced the Y-Buffer boards (Up) and (Low) in about 20 minutes.
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY
Posted on Dec 06, 2009
The TV just went off whilst watching
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Apr 03, 2015 | Televison & Video
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Why are green horizontal lines are appearing, too much yellow colour and green light blinking red?
These horizontal lines are vertical flyback lines and would indicate
one or more of the tubes cathode drive circuits are defective.
As the picture is predominantly yellow this would indicate excessive drive to red and green guns. Check the red and green video output stages especialy any clamping diodes.regards from Vintie
Sep 19, 2013 | Sony FD Trinitron WEGA KV-21CL10 21" TV
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    1/2" yellow line appearing in the middle of a background colored page
    sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
    Oct 03, 2008 | HP LaserJet 4600dn Color Printer
    Green horizontal lines
    Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
    Apr 30, 2007 | Philips 28PW6506 28" TV
    VS- 60705 Red,green,& blue lines all over screen.
    sounds like your screen controls are too high? thay are behind the front cover 6 contols 3 for focus and 3 are screen the screen controls.
    Apr 12, 2007 | Mitsubishi VS-45605 50" Rear Projection...
    Televison & Video Logo
    22 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
