I have a Cisco linksys router up stairs where my computer is also. I have a Cisco extended wireless router downstairs. I had no problems at all using my laptop and rokus. But today all wireless devices are not working. I get message : upstream Ap is missing. I have reset my router and extended one. Do u have any suggestions? Do u think I need a better router?
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Connecting WUSB100 to Wireless G WRT54G
laptops have a wide range reciever built around the screen and tend to be far better than a normal usb dongle.
The fact that your pc is downstairs will be effected a lot because the signals from the router will be bouncing around in an area around the antenna and above, signals below will be effected by floors, doors and wall partitions.
Your best solution would be to place the router on a phone line downstairs and see if the signal is increased.
Posted on Aug 18, 2008
SOURCE: linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Posted on Jan 04, 2009
  • 104 Answers
SOURCE: securing my wireless linksys BEFW11S4 ver. 4
I’ll be pleased to help if I can. To answer your last question first, this router is already set up for wireless networking, so nothing further needs to be done with regard to that.
However, to prevent others using your connection, it's necessary to set up wireless security. There are four main steps, which are the same for most routers:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
3) Enable WPA encryption
Here are the details:
1) Login to your router, using a wired connection.
First, you will need an Ethernet cable to connect one of your computers to the router. This cable just plugs into a spare port on the back of your router, while the other end plugs into the Ethernet port on your computer (looks like this picture).
When you are connected, open a web browser on your computer. Type the router’s IP address into the address bar, which is http://192.168.1.1 for this model. (Note, there is no ‘www’)
You should then see a popup box, prompting you for a username and password. If these have not been changed, leave username blank and enter password: admin
If you log in successfully, you should then see the Linksys router configuration screen.
2) Change the router login password.
To set a new password, go to Administration > Management. Set and confirm a new Router Password. On this screen, I would also recommend that ‘Remote Upgrade’ and ‘Remote Administration’ are disabled. Click ‘Save Settings’ when finished.
(Tip: write the password on a label and stick it on the router, or keep it somewhere safe. )
3) Change the SSID (router name):
Go to Wireless > Basic Wireless Settings. Change the ‘Wireless Network Name (SSID)’ from the default, to anything you like, that you can remember. It is case sensitive, and you can use up to 32 letters –but do not use something that could identify you, or your location.
At this stage I’d recommend that SSID broadcast remains enabled.
4) Enable WPA encryption
Go to Wireless > Wireless Security. Enable Wireless Security. Under ‘Security Mode’ you have a number of options for encryption, but I would pick WPA-Pre-Shared Key, which is very secure and good for most equipment.
Under ‘WPA Shared Key’ you need to enter a network key. This is a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers
( eg: 456the51stSTATeOFtheUSA1599 ). It is case sensitive. The stronger the network key the better, if you are very concerned about security.
Note down the network key carefully. You will need this to connect wirelessly. (The network key may also be called the WPA shared key, PSK, WPA-PSK, pre-shared key, security key, passphrase, or authentication key). Click ‘Save settings’ when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you should see your network with its new name in the 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work, or if you need help with any of it.
Posted on Jan 17, 2009
SOURCE: dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Posted on Aug 31, 2009
I am having problems extending wifi range
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Sep 16, 2012 | Cisco Re1000 Linksys Wireless And Range...
I have an old Cisco wrv210. Is there a way to use this as a wireless bridge? Specifically can I set this up in a different location in the house, say the upstairs office, and have it wirelessly connect to...
Not currently. Many Linksys models can be flashed with DD WRT, a third party firmware, which allows wireless bridging. Currently the WRV210 is not supported.
Sep 15, 2011 | Cisco WRV210 Wireless Router
I have a M10 Valet. 2 computers downstairs have excellant signal while computer upstairs has low signal. Is there an exspander that works with the Valet
You can get a Linksys Access Point (WAP) to entend the signal.
Expanders do not work too well.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Linksys by Cisco Cisco Valet Plus Wireless...
Laptop is upstairs, computer and router downstairs. Keep losing connection upstairs. shaw suggests I ask you to change settings. I have model WRT 160NV3 , Cisco.
You will need to check the wireless settings of the
router
is there any computer connected to the router ?
If yes then you can open the router set up page on
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
Click here for step by step instructions
Jan 16, 2010 | Linksys WRT160N Wireless Router
So I really need help. I have a Linksys (WRT54GS) wireless router upstairs connected to the internet, printers, etc. and a Netgear (WGT624) downstairs connected to a desktop, xbox and laptop. I don't want...
More information is needed.
Is the 'WAN' port on the Netgear router connected to anything?
(cable-modem? DSL-modem?)
How many friends will come over at the same time?
How many 'LAN' ports are on the Linksys? How many ports are "free" ?
How many 'LAN' ports are on the Netgaear? How many ports are "free" ?
How many "spare" Ethernet cables do you have?
Is your goal to provide computer-to-computer connectivity,
or are you just trying to provide Internet access for everybody?
If you are "downstairs", is the wireless signal from the "upstairs" router strong-enough to provide wireless coverage "downstairs"?
If you are "upstairs", is the wireless signal from the "downstairs" router strong-enough to provide wireless coverage "upstairs"?
Jan 04, 2010 | NetGear WGT624 Wireless Router
Can I boost signal strength?
You will need to get hold of a Belkin Wireless G Universal Range Extender relays the signals of your wireless network and extends its range model number F5D7132 from PC world or another online dealer.
You will still need the wireless router as the central connection point, using the booster your network now reaches further I have one at the top of the stairs with the Router downstairs to I can browser wirelessly in the loft conversion of my old house
Oct 11, 2009 | NetGear DG834G Wireless Router
Problem connecting to my network
What I would do is replace the wireless router with a 4 or 5 port switch to control computers (devices) downstairs. Or, if you need wireless access, purchase only an access point to cover downstairs.
This way the wire from upstairs goes directly into the access point and you have wireless access downstairs.
And yet another way would be to purchase Airlink 101 PowerEthernet boxes ($54.99 each) and use those to connect an access point anywhere in your home that has an outlet.
Nov 19, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
My laptop is not working
you mean not working wirelessly? please elaborate so we can help.. :-)
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
1,549 people viewed this question
David Payne
David Payne
