Question about Kenmore Elite HE4 Electric Dryer
Clothes not drying
Drum is turning, heating element appears to be working great as clothes are warm, but not drying. Great exhaust from rear exhaust, and exhaust air is hot. But took wife 3 loads to dry load of towels.
  • 1 more comment
  • Anonymous Dec 09, 2008
    I have a hot point dryer. It is working but the clothes come out semi wet
  • Anonymous Mar 15, 2014
    Drum turns but the air is cold, no heat to dry the clothes
    Machine thrum turns but the air is. Cold, not drying clothes
  • 105 Answers
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Posted on Jul 15, 2007
When using my dryer i notice that my windows are steamed up why is this?
What is the dryer doing? drying your clothes right? so the clothes are wet and as the dryer goes round and round the fan which is attached to the drum ( which holds the clothes) is pushing hot air into it. the vent in the front or the lint trap sucks hair lint debris from going up the exhaust chute. so "steamy" windows is when the dryer exhaust is not vented to take the moist warm air out of the house and raises the humidity level to condensate on the windows giving the steamy look. which is a great way to heat and bring humidity into the house during the dry winter months.
Nov 17, 2015 | Dryers
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
How do you dry on this machine? if you dry on the green, does it completely dry?
The automatic preheat and drying cycle kicks in as the final wash spin is under- way. The system employs a condenser dryer in which the hot air used to dry the clothes is channeled into a drum, instead of being released into the great outdoors via a dry vent hose. Cold water is drawn into the drum at the same time. The two mix, and the result is a condensing process.
The chlothes should be dry. there may be a damp feeling to them but otherwise dry. If your machine is not drying then the element could be going bad, or a thermal cutoff. those would be the easyiest fixes.
The BIG drawback is drying. It takes about 90 minutes to dry a load, and the clothes come out very wrinkled. Because the drum is so small, the clothes don't 'toss' in heated air and don't fluff at all. Clothes also come out stiffer than a regular dryer.
Jan 06, 2011 | Equator EZ 1500 Front Load Washer / Dryer
Amana les60aw gets hot in dryer but clothes wont dry. cleaned out vent, shortend exhaust hose. noticed an orange glow coming from back vents when i turned it back on???
The orange glow is the heating element working. It mush have good air flow or the coil will burn out and stop heating. Also the thermal limit will stop the heat if to great. If you went all through the vent and the tubing is not smashed or flat check the outside vent for air circulation, if good try to dry a load of clothes. Are you sure your washer is spinning out well? Wet clothes take longer to dry.
Oct 20, 2009 | Dryers
Clothes are not drying
check the heating element - located either on the rear of the drum or below it / behind front lower pannel of the dryer
is the dryer getting hot?
Aug 06, 2009 | Dryers
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
450 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
