Question about Sharp Office Equipment & Supplies
Bad copies with white lines on paper sharp color copier AR C172M. opc drum or fuser?
  • patzeruga Jan 15, 2013
    drum or toner, sorry
  • Sharp Expert
  • 337 Answers
Could be either or LSU glass, or charge corona. inspect drum and fuser and look for similar patterns. do a skyshot (open the platen cover to make a black copy) and stop the copy process while the image is being formed (hit copy with the cover up, wait just a second, and open the side door while it still running the copy). This will jam it but you can see the toner on the drum and look for patterns.
Posted on Jan 30, 2013
  • patzeruga Feb 01, 2013
    thanks so much but i found scratches on a doctor blade in the toner cartridge and thet was problem
  • 62 Answers
SOURCE: SHARP AR-507 DIGITAL COPIER
Ckeck the glass on the left side it is about 1inck by 12 inch for white out on it also clean the optics.On your curling problem install fresh paper you can check your fuser temp. in sim 43-1 change it to 180.
Posted on Dec 13, 2007
  • 53 Answers
SOURCE: horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Posted on Jul 20, 2008
Bubbabear64
  • 2794 Answers
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
checkitright
  • 1362 Answers
SOURCE: Sharp AR BC260 color printing Lots of ghost lines in color prints
depends on what is the problem with it? if it's only toner on it, let it cool and clean w soap and water rag, then wipe clean. I suspect that it is most likely scratched and the coating on the fuser is missing, it should be a shiny smooth surface.
Posted on Nov 19, 2008
SOURCE: I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Posted on Jan 09, 2010
I need sharp color copier AR C172M repair manual please
go to your google page and type in sharp color copier ARC172M repair manual and it will bring it up
Jan 15, 2013 | Sharp Office Equipment & Supplies
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Dec 02, 2010 | Samsung ML 2010 Laser Printer
AR-M355 Latent copies.
This make is not my specialty, but if the fuser's been replaced, then it can only be a drum cleaning issue causing that problem.
Dec 28, 2009 | Sharp AR-M355N Copier
White and black lines appear on copies
do an internal printout and see if any lines occur... if none... then clean the glass table and the **** glass and anything else that touches them... look for white out and dark spots...
if yes... then check your fuser... see if there are any lines on it... if there then fuser bad...
then check your drum to see if there are any lines on it... if there then bad drum...
Dec 16, 2009 | Sharp AR-M205 Copier
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Horizontal black and white lines are coming on copy
Help
hi im jules_09,check the fuser unit paper are folded because the rubber roller is worn out then the black line is also cause by scratch or damage upper or hot roller in the fuser unit.if the hot roller or uuper roller is fine check the drum unit if the opc drum is damage or scratch then check also the drum cleaning blade or roller,blak line in copy indicate one or two part either in the fuser unit or drum unit is damage.
Nov 15, 2007 | Panasonic FP-7735 Black and White Copier
CLicking noise when you try to copy
hi im jules_09.have you check the transfer unit?may there is a piece of paper stock inside that the sensor doesnt seem to see,if no try try to see were its coming from it may be coming from the fuser unit or drum unit,any if you want to know where.full out the drum unit then try to rotate the drum gently to 360 degrees.check the gear at the where the drum gear is connected,sometimes there are plastic gear that are easily worn out also the drum gear.and at the fuser just full it out then see the fusing gear also the hot roller or upper fuser.rty lobricating the busing with oil just be carefull not to put oil in the opc drum
Nov 06, 2007 | Sharp AR-M550N Copier
139 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
