Question about Toshiba REGZA 47HL167 TV
Black line we have a 37" toshiba flat screen,there is a black line 2" from the top of the screen,from one side to the other,could it be a faulty control panel?
I would recommend you stop posting stuff if you have no idea
Posted on Feb 09, 2015
  • 43 Answers
It could be two things, several rows of non performing pixels, or one of the boards has gone out in the television, i would recomend unplugging it for five minutes and plugging it back in to see if it continues, bring up the menu and see if the black line cuts through that as well as another source, if that all fails call toshiba and see if its under warranty, either have them repair it or return it to the store
Posted on Jan 24, 2009
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
WHY I HAVE GOT HARITONZAL LINES ON TOP OF SCREEN ON TOSHIBA LCD 37RV635D
sounds like the same problem as with most screens. it could well be the screen as gone
Apr 26, 2014 | Toshiba 37RV635DB Regza 37-inch Widescreen...
My Toshiba 42" has 3 black lines on right half of screen about 3 inches apart starting from the top, right side blurs and ghosts when playing. Is this a main screen problem or a board?
panel its dying :( sorry better get new one :((( you still can try with the old one some time the cables that control the the rows get unglued you can try heating them and reg glue them
Good luck
Sep 26, 2010 | Toshiba Televison & Video
There is a vertical line of dead pixels on the right side of the screen.
If the line travels from the top of the screen to the bottom, try disconnecting the Tcon LVDS lead. The Tcon is located in the top middle of the LCD rear. Disconnect the LVDS from the Tcon by pushing in the outer lobes. Clean the contacts on the LVDs lead and reinsert. If this doesnt cure the fault, disconnect the ribbons from the Tcon connecting the LCD and clean and reinsert. If this doesnt cure the fault you have a faulty LCD.
If the vertical line doesnt travel from top to bottom of the LCD, the LCD is faulty (LCD matrix buffer).Hope this helps :)
Feb 17, 2010 | LG 37LG30 37 in. LCD HDTV
Black line on screen
your lcd panel is failing and will need to be replaced
Dec 04, 2009 | Sylvania LD370SS8 37 in. LCD Television
Toshiba LCD 37" with gray band and blue line
Unfortunately you are right it is the display panel going bad. You can either live with it or buy you a new tv as the panels usually cost as much or more than the tv. Sorry.
ladytech
Nov 01, 2008 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
I have a plasma tv need help
Sounds like panel is bad or driver ic is bad on the board directly below the black line. Good luck on the repair. Any questions, we can do a chat and go from there. GURU JAY
Mar 14, 2008 | Televison & Video
Toshiba REGZA 47HL167 TV Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
