Hou can mearg two layer? - Computers & Internet
    Problem Solver:
  • 5 Answers
The keyboard shortcut for merge layers in Photoshop is: Ctrl+E or Shift+Ctrl+E.
Posted on Jan 27, 2009
Hou i use lenova laptop @key
If you don't know how to add the @ key to text, then you may try either to change the language layout or you may try to press Shift-2 or Shift "
Jan 27, 2013 | Lenovo Computers & Internet
When i turn on left turn the right also blinks
Side signal lamp wire hardness mearge with both left and right signal wire. while mswitch on both will be glowing. so check the wire harness circuit
Oct 05, 2012 | Cars & Trucks
How many layers does the 2003 Mercedes-Benz C230 Cabin Air Filter contain?
The 2003 Mercedes-Benz C230 Cabin Air Filter contains 3/5layers:The 3 layers model contains: - Non-woven pre-filter layer - Non-woven cover layer - Microfiber layer
The 5 layers model contains: - Non-woven pre-filter layer - Non-woven cover layer - Microfiber layer - Activated charcoal layers
Jul 16, 2012 | 2003 Mercedes-Benz C230 Cabin Air Filter
Hou to connect pilot gas line to the gas valve Is
Almost all of these fitting are a compression fitting. You may have to go to a plumbimg,heating, and A.C.parts supply store to buy the specific fitting you need but most have threaded male fitting with the compression ferrule attached in one fitting. Be careful when you start threads and finish tightening as the fitting are brass and the gas valve body is aluminium. Danger of cross threading or stripping threads if you over tighten. It is not mandatory to use pipe thread sealer on these fitting but I normally will to make it easier to get a good leak free seal without over tightening. Hope this helps you. Thanks
Nov 12, 2010 | Cozy Enclosed Front Console Heater 70,000...
Need an drawing showing hou to connect yamaha rx-
Hell Fixya customer,
Here are two links for the Yamaha receiver, and the Sony user manuals.
Please look through them concerning your specific hookup. If you still have questions or need help, please let me know.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V430e.pdf
http://www.sony.com.au/support/product/kdl-52z5500
Thank you for using Fixya
May 01, 2010 | Yamaha RX-V463 Receiver
Hou ay can transfer fils of my pda
you can transfer files to your pda by connecting it to the USB PC port with the data cable (use Microsoft ActiveSync to transfer files, it works for PDA, GPS etc).
you can also use a memory stick to transfer files to your pda if your pda has such a thing (you just need a pc card reader, usb-pluggable)
Nov 27, 2009 | Computers & Internet
Hou do i reset bios on a dell optiplex sx270
  1. Boot up the computer into the setup (depending on your bios, to get into the bios you need to hit the DEL key during boot up.)
  2. Press 'ALT' and 'F' at the same time
  3. Turn 'NUM LOCK', 'SCROLL LOCK' and 'CAPS LOCK' on. (Make sure the lights on the keyboard are on.)
  4. Press 'ALT' and 'P' at the same time. The bios should now be reset to the factory settings.
Apr 02, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
What is osi model
The 7 Layers of the OSI Model
Last updated: March 03, 2008
The OSI, or Open System Interconnection, model defines a networking framework for implementing protocols in seven layers. Control is passed from one layer to the next, starting at the application layer in one station, proceeding to the bottom layer, over the channel to the next station and back up the hierarchy.
Application
(Layer 7)
This layer supports application and end-user processes. Communication partners are identified, quality of service is identified, user authentication and privacy are considered, and any constraints on data syntax are identified. Everything at this layer is application-specific. This layer provides application services for file transfers, e-mail, and other network software services. Telnet and FTP are applications that exist entirely in the application level. Tiered application architectures are part of this layer.
Presentation
(Layer 6)
This layer provides independence from differences in data representation (e.g., encryption) by translating from application to network format, and vice versa. The presentation layer works to transform data into the form that the application layer can accept. This layer formats and encrypts data to be sent across a network, providing freedom from compatibility problems. It is sometimes called the syntax layer.
Session
(Layer 5)
This layer establishes, manages and terminates connections between applications. The session layer sets up, coordinates, and terminates conversations, exchanges, and dialogues between the applications at each end. It deals with session and connection coordination.
Transport
(Layer 4)
This layer provides transparent transfer of data between end systems, or hosts, and is responsible for end-to-end error recovery and flow control. It ensures complete data transfer.
Network
(Layer 3)
This layer provides switching and routing technologies, creating logical paths, known as virtual circuits, for transmitting data from node to node. Routing and forwarding are functions of this layer, as well as addressing, internetworking, error handling, congestion control and packet sequencing.
Data Link
(Layer 2)
At this layer, data packets are encoded and decoded into bits. It furnishes transmission protocol knowledge and management and handles errors in the physical layer, flow control and frame synchronization. The data link layer is divided into two sub layers: The Media Access Control (MAC) layer and the Logical Link Control (LLC) layer. The MAC sub layer controls how a computer on the network gains access to the data and permission to transmit it. The LLC layer controls frame synchronization, flow control and error checking.
Physical
(Layer 1)
This layer conveys the bit stream - electrical impulse, light or radio signal -- through the network at the electrical and mechanical level. It provides the hardware means of sending and receiving data on a carrier, including defining cables, cards and physical aspects. Fast Ethernet, RS232, and ATM are protocols with physical layer components.
For further details go to:
http://en.wikipedia.org/wiki/OSI_model
Jan 13, 2009 | Computers & Internet
I cant change the language
I have Olympus Camedia c-700 ultra zoom camera. somebody changed its language setting accidently and now i could not figure out hou to change back to english.
Jan 09, 2008 | Olympus Camedia C-700 Ultra Zoom Digital...
Computers & Internet Logo
99 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
