Question about Mastercool Heating & Cooling
Bonaire Integra - fan only works in boost mode
This evaporative cooler's fan uses the Comfort Control remote and does not adjust speed in Economy mode anymore. Only works on Low setting or on high in Boost mode. Low setting is useless in the hot months and high
2 Suggested Answers
SOURCE: fan is slow
I have the same problem. You turn it on and the air speed is very low. Increasing the fan speed on the remote doesn't have any effect except when it's on boost, in which case it blasts out. Either too much or too little. Is it a remote problem?
Posted on Dec 13, 2012
Vulcan ducted heating system 530 E (5 years old) have replaced AAA batteries on remote control but still not working. Thanks Michael
You have to recode the remote to the heater if the batteries have been removed for more than 3 minutes. On the comfort control will the remote is in a off state turn the heater off at the power.
While off press and hold the up button and the on/off until code appears then release buttons and turn the power back on to the heater.
When code disappears from the remote turn on the remote set the temp higher than current temp and combustion fan should start up then heater will fire up.
If not repeat process as they are easily corrupted by other remotes.
Download control manual from - http://www.bonaire.com.au/support/documentation/owner/default.aspx
Set / check fan speed or it may overheat.
May 17, 2011 | Heating & Cooling
I have a bonaire evap system cant get it to come on have changed batteries and reset it still nothing happens the remote is called bonaire comfort control have recently brought the house and cant find an...
Remotes are a pain. Can you get into the unit to see the control box? You need to see if the unit has power. If its new enough it will have some diognostic lights so you can see if it has power. Without that its hard to diognose. Unit Model number is also helpfull. if it looks like the one on this picture it will be etched into a badge on one of the corner pillars. if its a plastic unit it will be on a sticker inside the unit
Feb 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Heating & Cooling
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Will not turn on after a blackout
Turn off your breakers and then back on. There are fuses located in the a/c control panel. Check them. If you aren't getting any power still, a board may have been blown during the storm.
Jan 30, 2009 | Mastercool 67471 Evaporative Cooler Air...
Fan is slow
I dont have a solution, but I have a similar problem with a Bonaire evap rooftop cooler which only started after a tech came to look at the unit when it stopped operating properly last summer. He said it uses less water now, but the issue is that it doesnt cool any where near as effectively with the fan speed so low. I am located in Melb Australia, and wonder if you are in the same area. I am going to call service AGAIN & get the minimum fan speed returned to what it was previously. I wonder if my original unit is too small for the house - but nevertheless, it used to work beautifully and now is a very poor example of evap cooling. The service guy said the base fan speed could be altered from the controller, but we dont know how to get into the setup menu.
Jan 30, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
