Question about LG Art Cool LA1000PR Air Conditioner
Mistral mss20 split a/c only cooling somtimes 4 about 10 m then
It becomes a fan the compessor doesnt kick in even when turned
off however it does start resonably cool
any ideas thanks adam
  • 400 Answers
Sounds like your unit may be a bit short of refrigerant and the compressor is therefore cutting out on low pressure.
Posted on Mar 05, 2009
Need to know what error 6 on a minstrel air conditioner unit.Also can you scan and email me the manual for a Chunghop K 1028E 1000 1 Uinverisal remote. Thanks Gwenda
Hope this helps
error code is the fan in the head unit (indoor part) of the split system. After rining around for hours this morning - the number to get parts Mistral Bellini & Ringroup. 1300 373 199 They are based in Melbourne.
Apr 03, 2017 | Heating & Cooling
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
Jul 22, 2011 | Amana Heating & Cooling
I was in the basement sealing the plenum on my furnace, i just happen to walk by the breaker box and noticed my breaker for my heat pump had kicked, tried to reset it but it trips immediately, doesnt even...
Pull disconnect or turn off outside, then reset breaker. If it holds, problem likely inside machine. If it still trips check wiring inside the disconnect or at main panel. Sounds like a direct short, either compressor, fan motor or crankcase heater. You can isolate each component right at the contactor by removing wires to each piece and resetting breaker. Obviously when breaker trips you know what part is bad. 220 hurts, if you are not familiar with electricity call a professional.
Jun 08, 2017 | Ruud Matching Split Air Conditioner
I am having problems with my cooling fan one of them will not work even with the relay fuse I bought for it
Here is how to test if you have a bad cooling fan. Start the car, turn the ac button on. both cooling fans should kick on, if one doesnt then the fan motor has gone out on you. easy fix, your local parts store will have replacement.
Feb 24, 2010 | 2000 Toyota Camry
Mistral Air-con split system shows F6 fault! What does it mean?
F6 INDICATION MAY MEAN THAT THERE IS A PROBLEM WITH THE BLOWER MOTOR. WHEN THE BLOWER MOTOR GETS HEATED UP (WHEN ITS WINDING BECOMES WEAK) THIS MAY HAPPEN. SO U GET UR BLOWER MOTOR AND PCB BOARD CHECKED.
Nov 23, 2009 | Heating & Cooling
Low refrigerant?
never of you have no leak but if every thing is working and it is not cooling them you may need to do that...
Nov 08, 2009 | LG Art Cool LA1000PR Air Conditioner
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
Fridge not cooling,compressor wont kick in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsdgj
Jun 02, 2009 | Maytag MZD2665HE Stainless Steel Side by...
Cooling fan wont kick in
Could be the FAN MOTOR, COOLING FAN TURN ON SENSOR, even the PCM. There are 2 fuses . Also check fuse panel under hood in engine compartment
May 08, 2009 | 1995 Cadillac Seville
LG Art Cool LA1000PR Air Conditioner Logo
532 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
