Question about Samsung X05 Notebook
Samsung X05 LCD screen (Need Connecting white wire)
Does anyone know where to get this white wire that attaches to the motherboard. the white wire comes from the LCD and then attaches to the motherboard. this wire snapped when i was fixing another problem, ugh. please help. the computer works great except for this problem which is huge.
thanks for your time.
paul.
  • 240 Answers
Get the part number and you can search to google whos selling it.
Posted on Mar 16, 2009
Part of the screen stays white in my nc150 netbook Looks like it's a left 1/3 of the screen is always white with some thin black and white vertical stripes but the rest of it works fine. I would like...
Paul -
This absolutely could be the ribbon cable connecting your screen to your motherboard. If you know how to check this, it would be worth trying before spending $150+ on an LCD. Any way you look at it, this is definitely a hardware issue. Just hope it's not the motherboard's onboard video card. Here is a modified answer I gave to a question similar to your issue:
If you turn on your laptop and the display is bad, your issue is with either the LCD screen or the motherboard (since the video card is built-in the motherboard). This will be easy to diagnose.
1.) Plug an external monitor (one which you know works) into the VGA port of your laptop.
2.) Turn on the laptop.
3.) Hold down the FN key (lower-left corner of the keyboard) and press the "CRT/LCD" key (it will be located on the number keys or F1-F12. You do this to tell the laptop that it needs to send the video signal to the external monitor instead of its built-in LCD screen.
If the display is good on the external monitor, then the issue is with the laptop's LCD screen (about $200 for the part plus labor to install). If the display is still messed up on the external monitor, then your problem is with the motherboard ($300-$500 for the part plus a lot in labor cost for installation).
Let me know if this helps you!
Sep 30, 2011 | Computers & Internet
Samsung x05 wireless internet net working
try reseting ur router then connecting
Mar 10, 2010 | Samsung X05 Notebook
Starting up samsung x05
sounds as if you have a motherboard problem. If you are not comfortable in taking the bottom half of the case to see if that "crackaling noise" was.. then you can send it into samsung for repairs and estimate. If you are comfortable, first put your nose near a heat vent and see if it smells funny, like a little bit burnt. if so, its a gonner. You can look around once you remove the bottom pannals for burn residue or any signs of problems and report back if you need further assistance
Sep 11, 2008 | Samsung X05 Notebook
Drivers
i want the drivers of x05
Jun 18, 2008 | Samsung X05 Notebook
White Horizontal line across screen
It is most likely the vertical deflection IC has overheated and lost its soldering. If you open your TV up, it is a 10-15 pin in a row IC sticking out of the motherboard attached to a heatsink. It should be labeled "IC451." Give it a wiggle, see if it affects the picture, You may have to resolder them in place.
The IC may be hard to find, look for a peice of metal that is sticking out of the motherboard, attached to a small chip. I fixed a samsung tv that had it in the middle area.
Mar 27, 2008 | Zenith Z32H41D TV
All I get is a white screen
copied from http://www.fixya.com/support/t190380-turn_screen_displays_white
I have a Samsung Syncmaster 175v Mfg Oct '03 displaying the __ White Screen . I removed the screws on the back , removed base stand, separated case with flat screwdriver starting at bottom, unplugged the small wire to the panel menu buttons , removed metal cover from back of LCD. Now you can see the powerboard \ inverterboard combo and the attached video signalboard. Follow the 30 wire plug to the LCD screen, the 30 wire plug goes under a metal panel , remove the 3 small screws securing the panel and you will see the hidden LCD screenboard. Very close to where the 30 wire plug attaches to this screenboard on the Rightside you will see with a magnifying glass a SurfaceMounted Fuse named F1 with a value? of "K". On my LCD the fuse tested with a volt-ohmmeter to be Open or Blown. The right thing to do would be to replace the fuse however I acquired my LCD from a trashcan / dumpster so I stretched a drop of solder connecting both sides of the fuse. Now I do not have the protection from power failures and surges that the fuse could offer but upon reassembly my screen works like new again .
PS : i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Jan 18, 2008 | Samsung SyncMaster 175V 17" LCD Monitor
Turn Screen on and it displays white
Aug 30, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Loose LCD Monitor
Sumsung technical support team may help
Jun 17, 2007 | Samsung X05 Notebook
Samsung X05 Notebook Logo
107 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
