Question about Garmin Fishfinder 140
Display sona failure - Garmin Fishfinder 140
Where blackberry t mobile service centers in india-mumbai located??
You have the blackberry service center in mumbai in following address with phone numbers provided:
1) Unit No 2, Sona Villa, 113, S V Road, Khar West, Mumbai-400052.
Phone 91-022-31920452,91-022-31920051
2) F-11, Eternity Mall, Teen Haath Naka, Thane-West,Mumbai-400601.
Phone 91-022-40242604
3) 13/14, Sharda Bhavan, Station Road, Kandivali (west), Mumbai-40067.
Phone 91-022-42763636
Hope this helps.
Shane
Feb 01, 2011 | RIM BlackBerry Bold 9700 Smartphone
It does not display
Possible failure of the LCD display unit , failure of the power supply to the LCD, possible failure of the display driver interface in the main CPU unit.
You will need to open the camera- only if you able- check the voltages to the display unit before you can confirm.
Jan 17, 2011 | Cameras
Can this fit in any car
YES go to walmart and look at the dash Plastics inserts there marked with year make model and a SCOOSH wiring harness to plug in to ur old harness so u can connect the harness to ur Head unit wiring and color Cornated with What it is on the wires HOOK THAT SONA ***** UP looks nice
HOpe i helped bud i have the same unit in my 02 intrepid Se
Apr 15, 2010 | Dual XDMR7710 CD Player
Photosmart 7360-ink Ink System Failure error
1) Press * and # at the same time
2) Press 1, 2, 3 and “support R0632M” should display
3) Press > and “information menu” should display
4) Press > and “configuration menu” should display
5) Press OK and “hardware failure status” should display
6) Press OK “failure status: clear”. Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, and plug cord back in then turn printer back on.
And Thanks.
Mar 11, 2010 | Office Equipment & Supplies
Sony Wega TV color problem from power outtage
Please intimate exact model of your Sony TV to look for problem reason and possible solution.
Jul 02, 2009 | Sony Televison & Video
How do I play my iPod on my Sona Bravia? It's really puzzling me and I need to play it for a party tomorrow night!
hey. your ipod needs a cable with 3rca's on the one end and a jack that look like the ones on your earphone's.
they are colour coded just insert that in you av input on your screen and there you go.
May 11, 2009 | Televison & Video
Ink system failure
Follow these steps:
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Dec 24, 2008 | HP Photosmart C6180 All-In-One InkJet...
Garmin Fishfinder 140 Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
