Memory Options Hey, thanks for all the help, I found these 2 different memory sticks that I believe will fit my acer Travelmate 290. Could you verify that before I buy? Also, is one better than another? Or Do you have an even better one to recommend in this price range? Thanks a bunch for the help! http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1558782&SRCCODE=PRICEGRABBER&cm_mmc_o=2mHCjCVybgwTyz__wyCjCVqHCjCdwwp http://www.bestbuy.com/site/olspage.jsp?skuId=8216487&type=product&id=1166236106350
    President:
  • 2,559 Answers
Hey,the ones you found should be fine judging by the specs.
I don't have a particular brand recommendation,but I would suggest you take the one you have with you to compare.(There are so many that look the same but aren't,it would help alot to have one to compare to)
Thanks and please rate this fixya solution
Posted on Jan 24, 2009
How to fit memory in acer travelmate 6292
On this laptop you can use 2 G of ddr2 on 667 mhz ..If the size is not a must be ..and can be 1 G or 512 modules the speed need to be the one specified so to work without problems ..and also the type (ddr2 sodimm )
If you think this is eh case...Just open the lid for teh ram memory on the back ..and if teh slots are already having 2 modules..just remove one ..if it is smaller and use the 2 G one in its place ..Usually it came with 2 G of memory ..and if it is in one slot it will have one free but it can be in 2 modules one G each ..in this case it is even better cause you will have 3 G in total and you can avoid some of the troubles some found when using the max memory ..(boot up problems )
here is the procedure exactly in a video ...I suggest to reinstall teh operation system after upgrading for to work on full capacity and avoid issues that might appear ..(the system may not see the memory or have difficulties..But usually will work just with a restart or a bios reset to factory settings ..)
http://www.youtube.com/watch?v=EdjceQNzFSQ
This is for a different model but same kinda ddr2 modules ..and also a travelmate ..so the difference may be just in the cover ..but inside they are the same on the procedure ..remove the on eon top ..and install the 2 G module ..If it only have one module ..remove it ..to get to the bottom one ..and install the module and put the one you removed back in ..
good luck and please rate my answer ..
Dec 21, 2011 | Acer TravelMate 6292 Series Laptop Charger...
I want to upgrade my travelmate 290 how much memory can i put in and what kind do i need
go here and run the system analyzer which will advise how much memory is supported and show you what to buy.
www.crucial.com
very good company, division of Micron. Lifetime warranty and great prices on memory.
Feb 16, 2010 | Acer TravelMate 290 Notebook
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
My Travelmate 290 series is not working...
Try taking the memory out and then put it back in making sure it seated correctly then start using AC power lead it's probably caused by letting the battery get too low before recharging.Use a start up disc to get it going if you have to. Good luck
Aug 02, 2009 | Acer TravelMate 290 Notebook
Acer Travelmate 529atxv states max memory as 512mb
512mb is the max memory amount this computer will accept.
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot. Two slots total. Hope this helps.
Mar 07, 2009 | Acer TravelMate 529ATX Notebook
Acer Travelmate 290 memory Options
http://www.computermemoryoutlet.com/CMO11042.html?utm_source=Froogle&utm_medium=Feed&utm_campaign=Froogle&utm_term=5F4451E0-DF77-44D2-8006-23545F519AB3_7F044D18-FAF2-4EE4-9DAE-A76DA3437F7D
that one should be the correct module according to the specs :) its only a few bucks more no big deal, if it fails to work you can always return it :D hope this helps
Jan 24, 2009 | Computers & Internet
Recovery cd lost
Probably need to contact acer and order one.
Jan 01, 2009 | Acer TravelMate 290 Notebook
MEMORY UPGRADE ON ACER TRAVELMATE 5720G
Acer's support isn't the best. IMHO But go to their support site anyway and look up your laptops manual (there should be instructions on upgrading your RAM there). I did find that your machine will accept up to 4GB of RAM 2 X 2GB sticks. There should be a door or port (for easy user RAM upgrading) that is being overlooked, but again it is an Acer.
Good luck.
Feb 23, 2008 | Acer TravelMate 2300 Notebook
Memory
The compatible ram for your travelmate 270 ram is 256MB PC-133 SDRAM DIMM Memory Module.
This information can be found on Acer website.
If this solves your problem, please mark this as Solved.
Thank you
Oct 12, 2007 | Computers & Internet
Acer TravelMate 290 PC Notebook not starting
I believe these are BIOS indicators on some type of motherboards This could be a motherboard or memory problem. What happens if you remove some or all memory?
Sep 24, 2007 | Acer TravelMate 290 Notebook
Computers & Internet Logo
David Payne
David Payne
