How to replace the batteries to a Honeywell YRTH3100C1011 Digital Heat/Cool Pump Thermostats
Therinnaiguy
  • 1420 Answers
SOURCE: Changing Thermostats
This is one where you will need a good control man or woman. The American Standard ASYST system is not intended for the homeowner to change out. It has a room sensor wire that others do not account for.
Posted on Jan 16, 2008
  • 96 Answers
SOURCE: Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Posted on Nov 25, 2008
benmartinez
SOURCE: Heat pump that just blows cool air
I have a Honeywell heater i'll set my thermostat to 76 and ill turn on the heater and it would turn on... but when it get to 76 it turns off so when the temperature drops down and the heater clicks back on all i get is cold air .. it only works on the 1st time what to do ?
Posted on Dec 24, 2008
  • 5 Answers
SOURCE: thermostat burning walls
your thermostat may not be made for electric heat, if not then your wiring is overloading the thermostat causing the wires to heat up.
Posted on Apr 26, 2009
  • 587 Answers
SOURCE: Heat PumP: Rheem Two Stage Heat, One Stage Cool Thermostat Replac
R = R with jumper to RC hot side of transformer
B = Reversing valve
Y = Compressor relay
G =Blower
C = common on transformer (X on old t'stat)
W2 = Auxillary heat
E = Emergency heat
Posted on Mar 16, 2010
I have a Honeywell RTH6580WF Wi-Fi Thermostat that has "Cool On" or "Heat On" flashing in an endless loop. Could there be a major issue?
Pull the power red wire off the thermostat and batteries out if it has battery backup, then reinstall...much like a computer restart. If this doesn't work, then replace your thermostat.
Jan 21, 2016 | Honeywell RTH6580WF Wi-Fi Thermostat
Honeywell thermostats keep turning off and on and blowing cold air
Need to know the type of heat you have. If it is an air to air heat pump, with this cold weather, you are not going to get much heat out of it. It will feel cool (a little higher than room temperature). If the temps outside stay below 25 degrees, then switch it to Auxillary (Emergency ) heat.
Nov 25, 2013 | Heating & Cooling
Manual for honeywell 3550d1006
Press the SYSTEM button to select Heat, Cool Off or Auto. Here is the manual. Check this link for more information on Honeywell thermostats
Feb 29, 2012 | Honeywell Heat/Cool Thermostat
I have a heat pump for heat and a.c. Yesterday, on the thermostat on the wall it said REPLACE BATTERY. How do I do that, and what size battery will it take?
Remove the cover of the thermostat. That will give you access to the battery. It's probably a AAA battery. The cover of the thermostat should just pop off. However, on some programmable thermostats, just opening the programming door will give you access to the battery.
Feb 25, 2011 | Honeywell Electronic Programmable...
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
Mar 14, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
