Question about Peavey PV-3800 2-Channel Amplifier
Looking for pv 1.3k schematic diagram - Peavey PV-3800 2-Channel Amplifier
May someone can give me the pv-2000 schematic diagram please?
No, I cannot give you the PV-2000 schematic diagram. Sorry ... But I CAN tell you WHERE to FIND it!
www.nodevice.com/manual/pv-2000/get125808'html
Apr 19, 2017 | Motorcycles
I need a diagram for a peavey pv 10 mixer
Contact Peavey Customer Service. They can email you the schematic, and you can get the part directly from them.
Apr 01, 2015 | Peavey Music
What is the value of the resistor marked R338 in the power supply of Peavey pv 1500 2 x 750w power amp?
i have bit of the problem, i cannot find anywhere on this schematic resistor with 338 value, go to this page:
http://www.schematicsunlimited.com/p/peavey/peavey-pv1500-amplifier-schematic
i have another listing which is for pure power supply only:
http://exodus.poly.edu/~kurt/manuals/manuals/Other/POWER%20DESIGNS%20TB343A%20Instruction.pdf
this is giving me value, if i am correct, your resistor will be metal film 100ohm +/-1% 1w
you can re-calculate if this is correct value.
hope this will help you, do not forget to vote
Jan 26, 2015 | Peavey pv 1500 2 x 750w power amp
I`m looking for schematic peavey pv 2.6c
Use your Google browser and enter: "pv 2.6 c service manual pdf". The service manual should have the schematic.
Jan 11, 2015 | Peavey Music
What is the value of the resistor marked R338 in the power supply of Peavey PV-1500
The full schematic is available at http://elektrotanya.com/peavey_pv-1500.pdf/download.html but there is no R338 in the design. It stops at R337.
Nov 27, 2014 | Peavey pv 1500 2 x 750w power amp
Peavey pv 1500 schematic
Try this: http://www.eserviceinfo.com/index.php?what=search2&searchstring=PV-1500 for the schematic. The growl is probably feedback, just lower the gain a bit. Microphones are touchy things.
Jan 30, 2014 | Peavey Audio Players & Recorders
Dayton Heater M/N 3E227E
Hard to believe they sell a retrofit kit for a Gas furnace to a Customer....This is ahrd to advise you on with out seeing the schematic and if it is indeed intended for that furnace....the Spark mounting location is CRITICAL for safety so make sure that is correct above all.....OK The wire coming off the transformer and tied to the red wire going to the heat excghanger would most likely be a High Limit switch...cuts the gas off if the blower doesnt work etc or you would have a fire...so this switch must be in series with the transformer to cut power when the switch opens....the wire MV/PV coming from the "Electronic control box" needs to go to the New Gas Valve you should have which will have a termional marked MV/PV (Main valve/Pilot/valve) as your old one was for a standing pilot application and when you have electronic ignition you req a Gas valve for Intermittent pilot .....you should also have 2 more terminals on the valve MV and PV which will have seperate lines from the ignition control as well....basicvally there will be another wire coming from MV/PV going back to the transformer...make sure all wiring is correct and I would strongly advise you have a technician check your work before you attempt to use it....if wired incorrectly you could have a serious delayed ignition as its possible to power the main burner instead of the pilot if you wire it up wrong below is a typical spark wiring diagram....may not apply totally to your system but it will give you the general idea79f9627.gif
Oct 31, 2009 | Heating & Cooling
Need a PV 1.3K schematic... I can fix the amp, but need a schematic with parts values, layout, etc.
As far as I know, these are not available directly on the web. Contact Peavey directly and ask for service parts. They will sell you the manual for $20 or so.
Dan
Aug 18, 2009 | Peavey PV-3800 2-Channel Amplifier
Circuit diagram for a Peavey 130 special
Try http://www.peavey.com/support/contactinfo/ You may be able to get one from them. When I was doing repairs they would only release schematics to Peavey dealers but you can always ask.
Jun 24, 2009 | Peavey Pv 2600 Power Amplifier
Peavey PV 4C Power amp
The service information for this unit can be purchased directly from
Peavey.
One other alternative is to describe the problem with the unit. Perhaps we can provide solutions to repair it for you.
Keep us posted.
Dan
Apr 11, 2009 | Audio Players & Recorders
Peavey PV-3800 2-Channel Amplifier Logo
56 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Steve
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
