Televison & Video Logo
Posted on Jan 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i gotta panasonic TH 42 PS9 PLASMA and i want to connect with local HD channels can u please tell me which cable i have to buy for that?
shaun taylor
Level 3:
  • Televison & ... Master 1,527 Answers
  • Posted on Jan 24, 2009
shaun taylor
Level 3:
Answers
1527
Questions
0
Helped
338364
Points
3957
Hello you will need hdmi lead
shaun
Panasoics plasma viera rv will not auto tune telling us to insert aerial already in Model TH-P50X20Z
The manual for this TV can be found here. If you are watching broadcast television, or cable TV service that does NOT require use of a set top "cable box" tuner, you would connect the coax cable from the UHF / VHF antenna or cable into the ANT cable connector on the rear of the TV as shown on page 8 & 9 in the manual.
You would then tell the TV setup to scan for available channels as shown on page 12 of the manual.
If you are using a seperate tuner - like those supplied by Cable TV, Dish, DirectTV, Satellite, etc. you should use (1) the HDMI 1, 2 or 3 inputs (HD) 720P and up; (2) the RGB inputs of AV2 for best picture quality 720P or better (HD), (3 & 4) the AV1 & AV3 (on the side next to HDMI) for 480i and possibly 480P (SD) and finally the ANT connector for 480i. If you have a computer that offers VGA jack to connect to an external monitor, use the PC connector on th erear of the TV to send it HD images.
Page 27 & 28 detail manual channel editing.
How to connect a PC to a Panasonic TH42PX8B - 42" Widescreen HD
just need the right cable. Look into getting a VGA-HDMI cable
1helpful
TV- some channels don't have any sound, other channels do
RE TUNE UR TV AGAIN AND LET IT FIND ALL THE CHANNELS.......IF PROBLEM PRESISTS CALL PANASONIC SERVICE AND TELL THEM OR PROBLEM U HAVE IM SURE THEY WILL TELL U WHAT TO DO .........OR MAY OFFER U FREE SERVICE......WHAT WILL BE UNDER THE WARREN TIE U HAVE FOR 12 MONTS
Occasionally no picture with 42' Panasonic Plasma
It sounds like the cable modem is flaky. Have you called the local cable company to report the problem. This should be a no-cost solution.
2answers
Get HD Signals but it Says Channels not available
you might have to look for "hidden" hd channels.
most cable companies are broadcasting the local stations unencrypted, so you should be able to receive them and sometimes a few other "basic" hd channels like discovery or tnt.
try googling your cable system, city and hd channels to see if someone has posted a list of channels (eg, 88-1 or 102-1)
Possible Tuner Problem?
Go here and get the latest firmware. Find your model on the left side of the web page. http://www.pasctraining.panasonic.com/SpecialApplications/ProductFirmwareDownloads/downloads1.asp
HELP! MY 42" PLASMA TV IS ONLY GETTING BLACK AND WHITE CHANNELS.
If you are connected to a HD cale box using component cables IE (G, R & B) then check if either the Red or the Blue has come loose or unplugged as this will cause most HD sets to revert to a black and white picture.
Panasonic PT-52LCX66...Connecting to HD
the TV is "automatically" HD. You probably have to turn to the HD channels (which sometimes require a subscription through the cable company. For example in my cable company there are 2 Fox stations, channel 10 with is NOT HD and then channel 810 whish IS HD
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
