Teclast a11 cannot charge battery
Cannot charge the battery
User manual for Teclast 98 tablet?
May be able to contact Teclast to request - has a form at web link below:
http://www.teclast.com/en/contactus.html
https://www.gearbest.com/blog/download/teclast-x98-pro-tablet-pc-user-manual-in-english-1122
Requires a login to download. I have not verified.
Teclast X98 Pro Tablet PC User Manual in English
Mar 25, 2018 | Tablets & eReaders
The tablet "Teclast X16 Pro" has a very bad WLAN Connection. My Mobilfone (10 cm near Teclast tablet) has a typical download rate >45 Mbit, Teclast below 11 Mbit.
I believe that this wireless radio operates in the 2.4Ghz range, so I would recommend trying to have it in a "line of sight" to the wireless access point if possible. If you have the ability to change it to the 5Ghz range/connect to a 5Ghz SSID you should do so. This will cut down on the interference from metal and other structures.
You can download a Wifi analyzer app for your phone that should help you determine what you have in the 5Ghz range if anything, and what the SSID is.
Dec 28, 2016 | Computers & Internet
2 WIRES PULLED OUT OF THE PLUG ON BACK OF ALTERNATOR ONE WHITE WTH RED STRIPE ONE BLACK WTH WHITE STRIPE WHICH ONE IS IN THE CENTER
dont guess.
ouch, the FSM shows all connector pin outs in the rear.
you never said the year.
nor country diff, countries have different harness colors.??????
my 04' FSM shows.
2 wires. (not counting case and big wire)
the 2 plug. called A11 plug.
a11 pin 2 white red. charge lamp.
a11 pin1 black white,,, IG fuse.
but where are the, page 9a-16 shows that.
harness side,
key up, locking key up
1, 2 , X ( x is blank socket pin) left to right.
1 blk-wh
2 whit red,
or go to alldata dot com and look.
Sep 22, 2013 | Suzuki XL7 Cars & Trucks
How to hard reset my teclast tpad
Hold the power button and volume-up button simultaneously, then when the tpad logo appears, release the power button only. Then the bootloader will appear. choose reset and you're all set!
Aug 16, 2013 | Teclast P76e 7 inch Allwinner A13 1GHz 8GB
Service Teclast
Not in a motorbike shop. And it would depend what you mean by "Service". Try asking in a computer shop. It may not be worth stripping it to try fixing it though, as most tablets have a bonded screen.
May 17, 2013 | Motorcycles
How to disable bios password on toshiba tecra A11-15Z laptop
dear sir "
this is not a just password this is a supervoiser password of toshiba tecra a11 please give me a stronge solution of this cheap password .
Apr 23, 2012 | Toshiba Computers & Internet
Need help finding fuseible link that goes to starter
CHARGING SYSTEM
The charging system is an integral part of the battery and starter systems. Since all of these systems work together, any diagnosis and testing should be done in conjunction.
The charging system is protected by a 12 gauge fusible link located in the A11 circuit. This fusible link is between the generator and the starter.
The generator ground is provided through a case ground in the generator to its attaching bracket. This generator uses a voltage regulator internal to the Powertrain Control Module (PCM)
When the vehicle is running, battery voltage is applied to the generator field terminal through the A142 circuit. This circuit is the output from the contact side of the Automatic Shut Down (ASD) relay. The ground, or voltage regulated side, of the generator field is controlled by the K20 circuit which connects to cavity 4 of the PCM connector.
When there is current present in the field, and the rotor is turning, the stator in the generator produces a B+ voltage that is supplied to the battery through the A11 and A0 circuits. The A11 circuit is connected to the output terminal of the generator and connects to the engine starter motor battery feed terminal. The A0 circuit is a direct feed line from the battery and connects to the engine starter motor.
Grounding for the system is accomplished at the battery negative terminal. These grounds connect to the engine and body.
HELPFUL INFORMATION
Inspect for a blown fusible link in the A11 circuit between the generator and the starter motor.
other Fusible link goes from the starter to the alternator. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 11, 2010 | 2004 Dodge Neon
Driver for Teclast WE 303 USB laptop/pc camera to install on laptop with windows xp
Try this link:
http://www.drivermax.com/driver/search/index.php?search=teclast
Mar 31, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
David Payne
David Payne
