Question about GE GSS25JET
Where is the water filter on hotpoint gss25jeta bb?
There is no anterior water filter in the upper right corner of the refrigerator !
2 Suggested Answers
EllaWatson25
  • 725 Answers
SOURCE: Where is water filter on GSS25jeta.
It may be at the back right corner of the top shelf. If there is not a filter in it, you will have to remove everything from the top shelf and look up at the back where you find the place that the filter is inserted. I hope this helps you!
Posted on Aug 17, 2009
Does GE frig model # GSS25JETA have a water filter?
I don't see a filter listed in the parts breakdown for that model. If you had one, in would located in the fresh food section, top right rear corner. GE does have an external filter that can be installed in the 1/4 inch water line. and should last 6 months to a year depending on how much water you use and how bad you water actually is. GE part number is GXRTDR.
Mar 04, 2015 | GE Refrigerators
Where is the water filter on my GE Refrigerator GE GSS20GEWNWW?
in the upper right hand corner of the refrigerator compartment behind a plastic cover, squeeze this cover to release the clips it will be behind this
May 11, 2012 | GE GSS20GEW Side by Side Commercial...
Does the GE GSS 20IEP BB have a water filter?
check in side the refrigerator on the back upper right.
Mar 22, 2012 | Refrigerators
Hello, my ice maker is not producing ice, also, there is no water flow for cold water. I checked the water connection, it is charged. Can you recommend a solution pls.? My fridge is a HotPoint...
What about water filter? Is clogged? It is located in fresh food side in back righthand upper corner. also the holder me be bad. You can bypass the filter assembly By going in back of fridge. Hook incoming water to water valve to test. I hope this helps.
Aug 29, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Where is the water filter for an Amana refrigerator model sqd26ve located?
your water filter is in the upper right hand corner of the fresh food (refrig.) compartment above the upper most shelf in the ceiling
GENE
Aug 27, 2011 | Amana Refrigerators
Need to replace water filter on ge side by side gss25jeta bb model and need to know what type of filter to replace it with.
Pull the old one out and see what it is. Check you owners manual for proper replacement instructions. If you do not have and owners manual copy and paste the below URL into your address bar.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60514-2.pdf
May 31, 2011 | Refrigerators
Water filter is located in frig compartment in back right corner.
Jan 15, 2011 | Roper RS25AEXLQ Side by Side Refrigerator
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
Aug 17, 2009 | GE GSS25JET
GE GSS25JET Logo
26 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
