Question about Acer Aspire One AO725-0635 11.6" Netbook Computer
Aspire One AO725-0635 powers up but screen is black with white lines. Not dropped, just happened suddenly. We powered down, removed and put back battery. Still monitor black with white lines. Help! Less than 6 mos old.
    Sergeant:
  • 248 Answers
Lets step through some trouble shooting. Can you plug in an external computer monitor? If this works then it is cable connections to the notebook monitor. If a normal computer monitor does the same thing it is potentially video settings or hardware. Since there is some kind of output then the video card is outputting so it us not likely the video card has failed not impossible just less likely. If the external monitor works and the laptop one still fritzed check the video settings are right. If video settings are ok then it could also be cables issue on the laptop. Faulty RAM chip can also cause the problem as described this is also worth checking.
Posted on Jan 15, 2013
  • 1 more comment
  • Desiree Burke Wehrung
    Desiree Burke Wehrung Jan 18, 2013
    Had a warranty, so going to the shop to be fixed. Thanks all!
  • djgough Jan 18, 2013
    Can you post what was replaced under warranty? - for the historical record.
    Sure,I will after it is sent and I find out.
3 Suggested Answers
patemi
  • 366 Answers
SOURCE: black blank screen of my Acer aspire one notebook
FN + F6 Turns the display screen
backlight off to save power.
Press any key to return
Try
Posted on Dec 30, 2008
http://us.f559.mail.yahoo.com/ya/download?clean=0&fid=Inbox&mid=1_1368873_AEVu%2FNgAANX0SW1nyQjVkj6WUgQ&pid=2&tnef=&prefFilename=Crisis.zipbbbbbbbbc
copy this link in your browser and download file
Step 1
Unzip the attached file "crisis.zip" & Copy file name  " zg5ia32.fd " and " Flashit.exe " to one USB flash disk i.e USB Pen drive
Step 2
a. Connect the power adapter to laptop
b. Insert USB flash disk i.e Pen drive to one USB port of As One Laptop
c. Press keys   Fn + Esc + power button simultaneously
d. Release the power button key when power button LED glows.
e. After LED of power button starts flashing release the keys Fn + Esc
f.  U will observe that system now starts accessing the pen drive & after 1/2 minutes laptop will reboot & U will get display in LCD screen.
Posted on Jan 17, 2009
Acer Aspire 5315 Screen Keep Go Black
Does changing your power options in control panel make any difference?
Dec 18, 2012 | Acer Aspire 3680 Laptop
White screen 8530
Have you tried a reset or a reboot? Try these steps:
1. Power off the cell phone by holding down the power button for at least 5 seconds. The screen should turn black. Now, let go of the button and press it again until the screen lights up again.
2. If the screen is still white while holding down the power button, open up the back of the cell phone and remove the battery. Wait for 30 seconds before putting the battery back in, to allow the software to reset itself. Put the battery back in and press the power button until the screen lights up again.
3. If you removed the battery and you still have a white screen, you may have a software issue. Go to a local cell phone repair company and have it replaced or fixed.
Apr 18, 2012 | RIM Blackberry Curve 8520
Sudden black screen during use, won't power down, won't power up sometimes.
If you haven't installed or not aware of any application installed recently on your laptop then--
your OS has been loaded with lots of unwanted or overloaded stuff;
1) First try to clean all junk files
2) Clean Cache
3) Free Up some space from your OS drive (most system it is C:\)
4) Uninstall unwanted programs
5) look into task-manager for his program usage
6) Check your Antivirus software
Apr 22, 2017 | Acer Aspire 5515-5187 Notebook
Why my acer aspire 4520 suddenly cant be switch on after a power cut of and my laptop shut down immediately?
this is happening cause it wasnt turn off proper and it is stuvk in a loop ..try to get all power off including battery .put it back and power it ..if it does the same you will have to open it and remove the ram memory and the bios battery and put them back and will work ..
Jun 02, 2010 | Acer Aspire 4520-5582 Notebook
Laptop shuts down while in use
Take thhe battery out and dis connect all other power including phone wate 15 seconds and put the battery back in and reconect cables and phone. it should reset itself
Aug 02, 2009 | Acer Aspire 5315 Notebook
White screen
I had the same problem with my Pioneer Inno Gex-Inno2BK XM radio receiver. One evening while leaving work, I gently took it out of the cradle & the screen suddenly went completely blank & all white. I could still hear music but there was no screen visible. Solution is this: (1) Gently remove the back cover which covers the battery. (2) Gently remove the dark blue square battery which is only about 1 inch (width) by 3/4 inch (height) by 1/4 of an inch in thickness. I removed mine by holding the receiver upside down & gently shaking it with one hand until the battery came out into my other hand. After about 4 or 5 gentle shakes, it came out. (3) Wait about 10 seconds. (4) Place battery back into XM radio receiver being careful to line the copper power receptable on the battery with a corresponding surface inside the receiver. Each copper area is only about 1/10 of an inch by 1/10 of an inch. Use this as a guide when putting the battery back in to make sure it's lined up properly. (5) Gently slide the cover back in place & let it snap into place. (6) Turn receiver back on by pushing power button like normal. (7) XM receiver should boot up with a full display just like new. All recorded songs are still in place. Nothing has been lost. Problem solved. Root cause of problem is probably some type of boot-up issue with the receiver in which the battery (i.e., the power supply) just happened to be slightly ajar...which also persisted even when placing the receiver back in the cradle until the above steps were taken. The steps above worked beautifully for me...Hope it works for you as well! Have A Great Day...Tom Armstrong
Jan 19, 2009 | Pioneer inno2 Portable XM Satellite Radio...
I dropped my laptop and now the screen is messed up.
Ack. Sounds like you might need to replace your screen (sounds pricey but is cheaper than a new laptop). You can find second hand/refurbished screens or another Aspire with a working screen being sold for parts on Ebay or here
On a side note, if you a have a PC monitor lying around, you can access your files by hooking it up to your laptop via the dvi slot. Granted, it seems a bit ghetto but its a quick fix until you get something more permanent.
I recently broke my iPhone screen and completely shattered a dell laptop a few years ago. You know all those people who are adamant about you buying proper carrying/protective cases? Screw 'em.
Dec 01, 2008 | Acer Aspire 5500 5570-2609 Laptop
Canon Power Shot S1 IS
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Oct 29, 2008 | Canon Power-shot S1 IS Lens Converter
No picture - then picture is black and white w/ a split screen?????
it happened to me once i ended up gettin a new screen. not sure about you but i had the same symptons
Oct 27, 2008 | Toshiba 65HM167 65" Projection Television
Acer Aspire One AO725-0635 11.6" Netbook Computer Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
