Question about Canon CanoScan 5000F Flatbed Scanner
My scanner wasn't working, Iooked for it in my start task bar, but it wasn't there. I followed the properties to a link?
What is 4.6 link properties?
  • jma200459200
    jma200459200 Jan 15, 2013
    I am talking about visioneer strobe XP 220
Start tast bar disappears
Right click (hit right mouse button) on task bar and click to lock task bar and uncheck hide task bar. If you cannot right click on time before it disappears move pointer to the bottom of screen and it should reappear. Than follow above steps. If all else fails restart computer clicking on the F8 key repeatedly until start menu comes up , choose safe mode and when the computer starts up your task bar should remain in place, follow above steps to unhindered it permanently and reboot the computer it will start back up in normal mode and your task bar should be "fixed"
Feb 05, 2013 | Lenovo ThinkPad T410 Notebook
I lose the installation CD of my printer Epson Stylus CX3900. How can I use my Epson Stylus CX3900 scanner with Windows 7.
Ya plug it up then turn it on. Go to start on task bar then to printers/scanners button and it will show up there. Right click on it and click properties. Then update driver. Let it automatic search online for it. If you cant find it there go to control panel/system/find the usb or printer connection right click and properties updte driver\
Jan 31, 2012 | Epson STYLUS CX3900 All-In-One InkJet...
Trying to install canoscan lide25, but when using set up cd it says'cantttt install , twain only 32 bit
your scanner could be a 64 bit and your computer is only 32bit follow this to verify if your computer is a 32 bit or 64 bit system
1. click start menu 2. right-click MY COMPUTER 3. click PROPERTIES 4. from the properties window you will see if your computer is a 32-bit or 64 bit system
32 bit won't work on 64 bit system
Sep 10, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
MENU BAR IS GONE...PUFF, GONE
Press ctrl+esc to see if the start menu pops up, if it does not then proceed by trying the following steps below.
Make sure explorer.exe is still running:
Press ctrl+alt+delete to get into Task Manager and do File -> New Task -> explorer.exe -> OK
Otherwise check to see if your task bar is auto hiding:
Move the cursor to all four edges of the screen in an attempt to locate the hiding task bar. If the task bar does pop up, right click on it and press properties. Proceed by unchecking Auto-hide the taskbar under the Taskbar tab and pressing Apply and OK.
If all else fails, try rebooting the PC.
Jul 19, 2011 | Computers & Internet
Have only realtec audia manager but can find my normal volume botton anymore on my home pc
Hi Tania,
This problem is a 'bug' in Windows XP operating system.
Follow these steps to restore your volume button:
  • Click on 'start' & select 'Control panel' from the menu.
  • Look for the icon named 'sound' in your control panel & click on this icon to open sound properties.
  • Look for the check box with the words: "Show volume control in task bar"
  • Remove the check from the check box & click on the "apply" button at the bottom right of the properties window.
  • Now click on the check box once more to add the check once again.
  • Apply the change by clicking "Ok" at the bottom of the properties window.
Your volume control should now be visible once again in your task bar.
Don't hesitate to respond should you have any further queries.
Best wishes,
Graemevm
May 28, 2011 | Microsoft Windows XP Home Edition
It was suggested that I find my task bar in order to correct the
probably you just messed up the settings ...if you still can click on start ...just right click near the user name ..and properties will appear..click on it ..and you have the settings choice for both the task bar ..and the start menu ...I really hope you will handle it ..
if not ..just try to make a system restore task ..and assuming that you no longer have the start ..just click on my computer ..than in the side task bar (left ) you will have tasks and other places...there look for control panel ..and click on it ..
be sure the control panel is on the category view..(it has a task in the same left task bar) ..and in the category view click on performance and maintenance ...in this moment you have a second task in the left bar named system restore..click on it ...and follow instructions..choose to restore to an earlier point ...than choose one highlighted date in tha tab ...that you know for sure the computer was fine ...and proceed..If you are lucky and the system was not affected by another kinda virus...and is not a case for reinstallation...your system will restore itself after the reboot to an earlier setting stage ..
May 09, 2010 | Toshiba Satellite A135-S2276 Notebook
My network icon is gone from my notification bar, I try to add it on but the check box is gray.
Follow this steps. 1. right click on "My Network Places". 2. select properties. 3. right click "Local Area Connection". 4. select properties. 5. check the "2 checkbox" below description of your network. 6. your done. it will automatically appear at you task bar, beside of your system clock. God bless.
Apr 12, 2010 | Microsoft Windows Vista Home Premium...
Task bar displays
Just right click the task bar and click properties and then click customize , then click restore default Over!!!!
Aug 22, 2009 | Microsoft Windows XP Professional SP2 Full...
Task bar is grey upon start up
^Try going do the display properties again but this time on the Appearance tab.
You will have a dropdown box and select windows xp default.
let me know if it helps
Jun 20, 2009 | Microsoft Windows XP Home Edition
My bottom task bar periodically disappears
When you see the task bar, right click on it and set it the way you want it to work.
Feb 05, 2009 | Toshiba Satellite A105 Notebook
Canon CanoScan 5000F Flatbed Scanner Logo
old marine
old marine
