Question about Vacuums
My Bissell pro heat 2x 9200 won't put out water HELP!!!
    Problem Solver:
  • 8 Answers
As bissell said, the troubleshooting at My ProHeat 2X doesn spray What can do totally rocks. You can leave the vacuum upright the whole time. clean the nozzles from the inside using a pin. verify by blowing on it. Note that when doing a water check without the nozzles on you have to put your finger over one of the lower hoses to verify that the other hose will get water. They didn't mention that in the FAQ and it's a nice check before you reattach the nozzles. Getting the two lower nozzle out of the hoses is the hard part. Putting them back in is a snap.
Posted on Oct 16, 2014
  • Official Brand Answer
  • 315 Answers
Hey Brenda! I can understand how frustrating it can be when you're ready to clean your carpets and no spray.
Here's a link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Posted on Jan 16, 2013
heatman101
  • 43501 Answers
SOURCE: bissell pro 2x the cleaner solution & water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
shg
Posted on Sep 30, 2010
SOURCE: My Bissell Pro-Heat 2x 12
my bissell 9200 won't release water or solution when the trigger is pulled.
Posted on Nov 20, 2008
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
BissellCSR
  • 276 Answers
SOURCE: My Pro heat 2x by Bissell does not put out or ****
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If these suggestions do not resolve the issue contact BISSELL Consumer Services at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Posted on Sep 28, 2010
guru_fixya
  • 944 Answers
SOURCE: My Bissell 9200 Pro Heat
Don't worry this is small issue.It is due clog problem.Clog in the heater.Unscrew all the screws on the base.Remove the cover over the motor. Doing so will reveal the hoses attached to the soap dispenser. Locate closer to the rollers were more hoses. On the same side as the foot lever, above the wheel is the the heater is located.Clean all the hose clog to and from heater.I have attached the manual for your purpose(Link)
Parts diagram overview:
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
Manual to troubleshoot:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000075846.pdf
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 12, 2011
My Bissell pro heat pet 2x model 9200 does not allow the shampoo to mix with the water. Something must be clogged, and I don't know how to unclog
The 2X is designed with 5 solenoids. I am not allowed to tell you that it's a flaw in the design, but I will say that is the only machine on the market that our store refuses to work on. Buy a Hoover F5914-900 machine and end your pain.
Jun 08, 2017 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Why won't my Bissell pro heat wont suck up water with the upholstery tool
You may have a valve that switches from floor suction to tool suction. This could be not deployed or stuck.
Nov 09, 2014 | Bissell 2X Proheat 9200 rug cleaner
Bissell pro heat 2x manual
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Sep 30, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
I have a bissell pro heat 2x +and the water is not coming out of the hand tool or the carpet cleanerr
We are sorry about the issues you've run into.
This link gives detailed troubleshooting instructions for you: http://www.bissell.com/FAQDetail.aspx?id=1122&icid=ccrr
And this video shows easy maintenance items: http://www.bissell.com/how-to-videos/proheat-2x-machine/care/?icid=ccrr
If your machine continues to not spray, please take it to a BISSELL Authorized Service Center for warranty repairs. If you are experiencing difficulties other than no spray, the technician will let you know the cost for those repairs if your machine is outside of the one year warranty timeframe. You can locate a BISSELL Authorized Service Center at this link: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&icid=ccrr
One pointer that can help between uses is running water through the lines. First, put clean water in both tanks and set your unit to the heavy traffic setting for one pass. This will flush out any cleaning formula in the lines so your spray tips won't get build-up between uses, which can lead to a lack of dispensing the cleaning formula.
Jun 27, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro 2x the cleaner solution & water
heatman101
shg
Jul 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Vacuums Logo
584 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
