Question about LG 32LX3DC 32 in. LCD HDTV
Lg 32lx4dcs how do i get it out of hotel mode
I can get in to sevece mode but no reset or hotel mode that i can see
How do i get my lg32lx4dc tv out of hotel mode?
You have to enter its service mode option to release the Hotel mode. For that, you should have its 'Service Remote Control'; not the user remote control. It will be best to contact the authorized service center for LG. google.com/+GopakumarGopalan
Jun 08, 2015 | Televison & Video
How to rest the LG 32LX4DCS with out a remote
How to Rest ?????
you mean RESET ,,,, it's in the menu , you can do that using the side panel menu buttons , goto settings , options , reset...
good luck ... The Cable Guy ...
Mar 11, 2015 | LG Used Original 32LX4DCS Remote Control
Helllo, wanted to know how to get out of hotel mode
The following are for LG TVs: From your remote, push MENU button for 5 seconds then type 1105 and press OK. You should now have a special menu displayed where you can modify the settings or disable hotel mode. Use the same procedure to go back and modify or enable hotel mode.
Oct 20, 2014 | Televison & Video
How to reset a used hotel bought LG 32LX4DCS T.V.
Check this link, and download the user manual to your TV. It has all details. If you wish to get more details, check this link too.
Feb 17, 2013 | LG Used Original 32LX4DCS Remote Control
Have a 32 in 32lx4dcs that will not power down from either remote or the buttons, no button functionality what so ever. Item immediately turns on when plugged back in. How do i do a hard reset?
you can try unplugging the unit holding the power button for 10 - 15 seconds then plugging the unit back in. this issue is related to a signal fault carried by the main board in the unit. you may need a board replaced. to do a system reset you will need an LG service remote.
Apr 16, 2011 | LG 32LX4DC 32 in. LCD Television
Reset Hotel mode
Hi, have you tried holding the TV menu and the remote menu buttons together, then selelcting menu again on remote.
Oct 02, 2010 | LG 37LG50 37 in. LCD HDTV
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
Stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
Jan 16, 2009 | Philips RC2573 Remote Control
LG 32LX3DC 32 in. LCD HDTV Logo
55 people viewed this question
Computer Repairing
Computer Repairing
