Question about Nailers 3 12" Pneumatic Air Round Head Framing Nailer Nail Gun
I have a rockworth gas nail gun what psi is recomended
2 Suggested Answers
H2_Brad
  • 425 Answers
SOURCE: Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Posted on Aug 22, 2012
Why might my nail guns not work?
Have you lubricated either nail gun? If not, go to Home Depot and get a bottle of air tool oil. It's in tools by the compressors. Disconnect the air hose from the tool. Pour about a teaspoon of oil into the air inlet of the tool. Reconnect everything and try it 10-20 times with no nails in the tool. Then try it with nails. Good luck.
Sep 14, 2015 | Porter Cable Tools & Hardware - Others
Nail gun 58-8434-4 will not drive 3" nails all the
Hi foxden503,
Welcome to fixya!
As a general rule, framing nailers use anywhere from 45 to 120 psi to drive nails. But this also depends on the hardness of the wood.
The nail head should be flush with the surface. If it sticks above the wood, increase the pressure a little bit at a time until you achieve this goal.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 20, 2011 | Tools & Hardware - Others
The tank pressure is 150 Psi but the regulated pressure is 0. I have never used this compressor.
150 lbs is the amount of pressure in the tank. When you connect a nail gun for instance you cannot nail everything at 150 lbs of pressure, it will blast through. The regulated pressure is at zero because you have the ability to regulate it by turn the know under or beside it to increase the output pressure to your desired amount. I was building a shelf last week and set my regulated to 80lbs with a brad and it blew through the panel and stuck in the floor. After you get to know your nail gun you will be able to regulate it between 60 and 80 depending on the type of wood. Panel - 50 lbs, Oak, 90 lbs, etc. Pleas remember to rate this solution high if it was helpful and explained it to your satisfaction.
Jan 30, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Can I limit the pressure to 120 PSI, the upper recommended limit for my nail gun?
adjust your pressure switch on your compressor .remove the cap and turn the screw clockwise to increase and counterclockwise decrease.turn the screw counterclockwise a bit and release some air till the compressor start pumping.then just before to reach 120 psi turn counterclockwise to stop the compressor at 120.then release some air again till it cuts in again and look at what pressure it will stop.keep going that way till you get your 120 psi.cut in should be around 90 psi(30 psi differential)depending what kind of pump you have (if the pump can handle 150 psi )you can adjust it to cut in at 120 and cut off at 150 and install a pressure regulator adjusted to 115 to 120 and get a nice steady pressure going to your nail gun.(the best way to do it!!!)
Jan 17, 2011 | Air Tools & Compressors
I want to use a 120psi brad nail gun on a clarke ranger 115psi compressor ..will it be ok
It'll be perfectly fine. Wear safety glasses with them nail guns, they can really send a nail flying.
lp
Dec 29, 2010 | Clarke Power Products Clarke Pioneer 2 Hp...
I am thinking of getting a compressor for my husband for christmas...looking at Bostitch and Porter Cable..both 6 gal portable...cost is comparable, in stock at both Lowes and Home Depot. We are going to...
Eighter one of these will work good for nail guns personaly i have the porter cable and i like it i do a lot of construction work. And i think the porter cable comes a finish nail gun for small nails and staples mind did. But there not for running tools that require a large volume of air like air sanders air rachats or air cutters.
Dec 20, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Adjusting airpresure
There is nothing on a nailer to adjust the air pressure. You have to do it at the pressure regulator. It is feasable to mount a regulator at the gun but more likely it's on the compressor. Most nail guns are rated for 90 to 120 psi. Set your regulator to hold the hose pressure between 90 and 100 psi. Using higher pressure to set the nail will ruin your nailer. Use the depth adjustment on the gun to set how far the nail is driven.
Sep 23, 2010 | Nailers 3 12" Pneumatic Air Round Head...
How many tools will operate at same time
I think you'll have to look at your specs on your nail guns and see what the demand is . Whether measured in cfpm or psi, your compressor will tell you the max output of each of those. Then you divide the maximum sustained output of the compressor,, lets say it is 60 psi. Let's say the guns require 10 psi, 60 divided by 10 is 6 = 6 nail guns. This is completely hypothetical as I have no idea what your nail guns require, only you know what kind of guns you have.If you need to run more guns than the compressor can push air for, you'll have to invest in another compressor, maybe even one larger to handle the guns running wide open consistent nailing. Nothing a drywaller hates more is than for all the cursed clip nails not being drove in all the way, lol, and that's what will happen with insufficient air supply.
Matt
Nov 18, 2008 | Hitachi EC12 Portable Electric 2hp Air...
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Nailers 3 12" Pneumatic Air Round Head Framing Nailer Nail Gun Logo
23 people viewed this question
Top Nailers Tools & Hardware - Others Experts
Are you a Nailers Tool and Hardware - Other Expert? Answer questions, earn points and help others
