Question about Humminbird 787c2 GPS Receiver
Screen freezing up, cannot turn the unit off, the only way to reset unit is to turn off power and restart.
Garmin freezes up on the first screen
Two things :
1. First a hard reset. Turn the unit off andunplug it from a power source. Then press and hold the lower right hand corner of the screen. While hold you thumb or finger here turn on the unit until you get the prompt erase all user data, tap yes and allow the unit to restart. Next we need to update the firmware because alot of the original firmware was buggy were the units would freeze up.
2. http://www8.garmin.com/products/webupdater/howtoinstall.jsp go to that link and downlaod garmin webupdater and install it. While its downloading connect your unit to your pc via usb cable. Once the program is downloaded and installed, run it and follow the onscreen prompts to update your unit. This should fix your issues with your unit freezing up on you.
if this information was helpful please click accept so i may get credit for my time. thank you!
Apr 02, 2012 | Garmin nuvi 260W GPS Receiver
How can i reset my coby tablet
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 20, 2011 | Coby Kyros 716829701508 Tablet PC
Sul display del frigo appare er pc lampeggiando
Code PC Er is saying there was a momentary power loss.
Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
If after all of this you still have issues with the lights or the unit is not working properly just repsond here and we will help you.
Hope this helps to solve it.
Jun 04, 2011 | Refrigerators
My garmin freezes on startup. Can't master reset
You could try pressing and holding the power button for 10 seconds. If that doesn't work, try a master reset by:
Start with the unit off and unplugged from power.
  1. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  2. Continue touching and holding the lower right hand corner of the screen then power the unit on.
  3. Release the power button when the device powers on.
    • You will see a new message: "Do you really want to erase all user data?"
  4. Remove your finger from the touchscreen when this message displays
  5. Touch "Yes"
  6. Restart the unit
Please let me know if it helps.
Thanks
May 03, 2010 | Garmin nuvi 1350 Car GPS Receiver
Every time I turn it on it freezes up and I have to reset it.
I've had a similar issue, where holding the power button for 10-15 seconds would restart the unit, but it would freeze at the "loading maps." part. I ended up plugging the unit into my PC, which started it for purposes of data transfer. I then disconnected it from the PC and it restarted properly.
Try those out and see if you have any better luck.
Mar 27, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin is totally blank
I assume you mean the screen stays black and won't turn on.
I had this happen to me on one occasion with a nuvi 1300. Pressing the power button any number of times would not turn on the unit. Also, plugging in the car charger did not turn on the unit or charge it either.
I found that holding the power button for 10-15 seconds forced the unit to reboot, and it started just fine after that.
Since then, I've had an even more irritating issue, where holding the power button for 10-15 seconds would restart the unit, but it would freeze at the "loading maps." part. I ended up plugging the unit into my PC, which started it for purposes of data transfer. I then disconnected it from the PC and it restarted properly.
Mar 14, 2010 | Garmin nuvi 1300 Car GPS Receiver
Need to reset nuvi 715, where is reset button
There is no dedicated reset button on this unit. If the unit is freezing up or causing other problems a reset is achieved by doing the following
1) With the unit turned off - slide the power button to the left and hold it there for 8 seconds or more.
2) Power the unit back on.
The unit will be reset.
You can also clear all user data by holding your finger in the lower right corner of the screen and at the same time power the unit on.
Keep your finger touching the screen until a confirmation message appears. Touch Yes to clear the data.
Hope this helps. Thanks for using FixYa.
Jan 21, 2010 | Garmin GPS
My Creative Zen started freezing a couple weeks ago. I would press the restart button at the bottom left and that seemed to solve it. Now though, when I turn it on, the Creative Zen welcome screen comes...
It sounds like the hard drive is damaged I have a archos 605 wifi it froze up on me so i turned it off and turned it back on and it wouldn't load pass the archos welcome screen come to find out my hard drive was damaged.Hopfully yours is still under warranty otherwise you'll have to send it in and pay to get it fixed but i would say the hard drive is damaged.
Nov 28, 2008 | Creative Labs Zen Touch MP3 Player
Frozen screen on my phillips mp3 player
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Sep 01, 2008 | Philips GOGEAR SA6045 MP3 Player
Palm turns on but will not operate programs
You need to perform hard reset by pressing reset and power button same time.
Nov 20, 2006 | Palm m515 Handheld
Humminbird 787c2 GPS Receiver Logo
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
