Question about Shark Navigator Bagless Upright Vacuum
Shark nv356e brush not spinning - Shark Navigator Bagless Upright Vacuum
2 Suggested Answers
  • 19 Answers
SOURCE: Why won't the brushes spin on my Shark rocket vacuum spin
Either the belt is broken, the brushroll switch needs to be replaced or the brush motor is shot.
Posted on Mar 13, 2017
Mar 12, 2017 | Shark Rocket Self-Propelled Bagless...
Shark rotator nv340 roller brush is not spinning
just found this from another fixya member....There are a number of reasons why your brush roll has stopped spinning on your Shark Rotator. Here are a few things to check for when trying to fix your Shark.
First things first lets focus on the brush roll. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roll. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roll to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roll is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. This could be the other reason why your brush roll has stopped spinning. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush rolls turn rate and speed. If the belt feels loose then it certainly is effecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Dec 09, 2016 | Shark Vacuums
Why is there a lot of air blowing from the front of my shark vacuum and brush is not spinning
there is a plastic vacuum hose on the side of the brush unit , there is a blockage there , it is possible to pull one end of the hose off to remove the blockage.
Sep 27, 2016 | Shark Navigator Bagless Upright Vacuum
The power head has a device to hold the power head together what does it look like?
Shark NAVIGATOR LIFT-AWAY PRO NV355 Owner's Manual
www.manualslib.com/manual/.../Shark-Navigator-Lift-Away-Pro-Nv355...NAVIGATOR LIFT-AWAY PRO NV355 Vacuum Cleaner pdf manual download. ...Shark ® Getting Started Navigator ™ Mode 1: Upright Vac Lift-Away ® Mode 2: ...Important Safety Instructions - ‎Table Of Contents - ‎Ordering Parts - ‎Maintenance
Sep 22, 2015 | Shark Navigator Lift-Away Professional...
Why is the pet hair power brush not spinning?
Amazon.com: Customer Discussions: Shark pet hair & power brush
www.amazon.com/...pet-hair-power-brush/.../1?_...
Amazon.com, Inc.Jun 24, 2012 - I needed the belt and couldn't find one so I used a black heavy ponytail band in its place and it works, I don't know how long it will last, but until I ...
My shark pet hair power brush tool will not spin - Fixya
www.fixya.com/.../t13829250-shark_pet_hair_power_brush_tool_will_n...
Jul 30, 2012 - Posted on Jul 05, 2015.
Sep 21, 2015 | Shark Rocket Professional Self-Propelled...
Brush is not spinning on the pet hair power brush
Those things work off of suction, which spins a cog wheel that rotates and spins brush via a small belt. Disassemble the brush and check belt. Make sure the apparatus is clean and free of debris
Jul 25, 2015 | Euro-Pro Shark SC-505 Handheld Steam...
Brush spins once then stops.
I don't know this machine but I'd check the bearings on the ends of the brush to see if they are spinning freely. If it has a drive belt try changing it, if it is an impeller drive check the vanes for damage.
By the way this machine I believe has a 5 year warrenty,
Jun 22, 2015 | Shark Navigator Deluxe Vacuum - Model NV42
My Shark vacuum is making a weird noise how to fix it
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator Lift-Away Vacuum is making a loud noise while it's on then there's definitely a clog somewhere. Here' s a few places you should check prior to plugging in the vacuum and turning it on.
The first place to check would be the brush roll and belt. If you notice visible debris, like strands of hairs, or long carpet fibers this could be catching on the brush roll and causing it not to turn fully. Be sure to clear this debris from the brush roll and manually spin the brush roll a few times after you do so to help unearth and any other clogs. This may be the reason for the noise and its crucial that this part of your vacuum is clog free.
Another part of your vacuum to check would be your hose. Detach the hose and stretch it out as much as you can to see if any debris or clumps of dust are stuck inside. Using a broom handle can help if you see a clog, but it won't come out after you've stretched out the hose.
Another big factor would be a dirty filter in your vacuum. Most manufacturers recommend you change your filter on average every 3-6 months. However, it is recommended to change your filter even earlier depending on usage and allergy care. The cleaner your filters the less debris will get stuck in your vacuum, causing less clogs and overall less odd noises while vacuuming.
http://www.crucialvacuum.com/catalogsearch/result/?q=nv355
Jim Thompson
Crucial Vacuum Customer Care
Nov 23, 2014 | Shark Navigator Lift-Away Professional...
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
Shark Navigator Bagless Upright Vacuum Logo
153 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
