Coleman central electric furnace model 3400-818 won't come on
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Posted on May 30, 2008
jcpark50
  • 52 Answers
SOURCE: Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
Posted on Nov 07, 2008
  • 4 Answers
SOURCE: Fix for coleman rv furnace
Check all limit switches and check power to gas control
Posted on Jan 06, 2009
  • 252 Answers
SOURCE: HVAC
Could be a voltage problem, could be the motor or the run capacitor or the start capacitor (if it has one). Gonna need test equipment to diagnose this one. Check the input voltage both at rest and during start/operation. Use capacitor tester to test capacitors. If all else checks good, it's the motor. I bet it's a power supply problem though if you have two different motors with the same symptoms.
Posted on Mar 30, 2009
  • 233 Answers
SOURCE: need a downloadable pdf electrical
http://www.colemanac.com/PDFFiles/036-31114-001-C-0109.pdf
Posted on Jul 15, 2009
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Coleman central electric furnace model#3400a816 heat does work ,blower does not come on .
does your fan on the thermostat when you turn it to on work? If not you have a voltage problem. Does cool work? Need more info.
Oct 23, 2013 | Heating & Cooling
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Coleman furnace 7966 filter location ?
if not at furnace at blower section ,look at return duct at unit sometimes put in slot on return duct. also might be located in central return grille in living space generally located under t stat
Nov 12, 2012 | Coleman Heating & Cooling
I have a coleman central electric furnace model 3400-815 and a wire that connects the sequencer to the element burnt out. I'm not sure what caused the burn out so I don't know which part needs to...
The wire was probably loose on the terminal. This is very typical. Replace the wire end with a new spade clip. Make sure it pushes on to the terminal real good and tight and you probably won't have another problem.
May 14, 2011 | Heating & Cooling
When we turn on the central air there is a strong burning smell...like burnt toast but way stronger. IS it safe to remian in the house?
Is your central air furnace or electric heat. Electric furnace sometimes have electric strip sequencer stick in the closed positions leaving on one strip of the electric heat. Get a service tech as soon as possible to check this out. Any smells from a central unit need to be teken care of promptly. TURN OFF unit you have it checked for your safety. Rus
Jun 28, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
