Question about GPS
User manual ab2065-55a 3510-353081 ta 6n0006 gn-4-s
4 Suggested Answers
  • 2501 Answers
SOURCE: I had the battery replaced,
Go to http://www.citizenwatch.jp/support/pdf/coa/c300.pdf for instructions.
Posted on Jul 27, 2010
  • 794 Answers
SOURCE: Re. Citizen Blue Angel. Case
Hi bravofoxt126,
The C300-Q00842 TA GN-4-S 19425 is one of the case back markings that you can find on your citizen watch. C300 is called the movement caliber (4 digits) and the rest is your case number. This will be very helpful for you when you need to request for parts, service, setting instructions or other information.
Hope it helps.
Thank you for using Fixya.
Posted on Mar 25, 2011
  • 482 Answers
SOURCE: Can you help me find a Onkyo TA 2800 cassette deck users manual?
I can give you this link. You can download the service manual of this Onkyo. I hope it will be usable for you.
When you get to the site using the link it is possible that you have to wait a little bit to be able to download.
After waiting you should see a button as "Get Manual" and simply click on it and save the file.
Thanks.
gylacz
Posted on Jan 03, 2012
How to set timing 99 evolution 1340 cc
Hi Mason, I borrowed this from a Harley Davidson Tech Forum.
"•set piston in front cylinder at TDC on compression stroke center vertical line in timing hole
•turn ignition on make sure run switch is on
•using volt meter, measure voltage between GN/W wire from sensor plate and ground while rotating sensor plate to do that, follow wires from sensor plate to ignition module connector back-probe the GN/W wire at connector (it may be GN wire instead of GN/W on your bike)
•when voltage changes from 0 V to 4-5 V (or vice versa), stop, set sensor plate
•it's now timed at TDC at 0 RPM
It may be easiest to access the green or green/white wire (depending upon model/year) at the connector at the ignition module, not the connector from the sensor plate (between the ignition module and the sensor plate). Good luck
Jun 08, 2015 | Harley Davidson Motorcycles
Going on standbymode and power green light blinking TA4 nakamachi
I'm not familiar with this product, and there the best I offer is that you consult the user guide (which you probably already have)
http://www.ps2netdrivers.net/manual/nakamichi.ta-4/#manual
or (buy) a service manual (which it seems includes a troubleshooting guide) from any of a number places, two are given below:
http://www.manualszone.com/en/nakamichi-service-manuals/62888-NAKAMICHI-TA4-service-manual.html
and
http://www.nakamichi.owner-manuals.com/TA4-service-manual-NAKAMICHI.html
All three manuals/guides are available from
http://www.hifiengine.com/manual_library/nakamichi/ta-4.shtml
There other websites where you an download the service manual (I don't know if the are the 'official' service manual, or different ones that have been written by different people).
If you are really stuck contact Nakamichi through www.nakamichi.com or (what appears to be a more friendly site) http://www.nakamichi.co.uk/support
24.August.2014
Aug 24, 2014 | Audio Players & Recorders
Thanks.
gylacz
Dec 28, 2011 | Onkyo Audio Players & Recorders
How to make a GN 9350 unit work with Windows 7?
Skip dealing with it. You don't need the $110 BS "upgrade" as this is a driver issue. Jabra could very well have provided a downloadable and install-able driver for the GN 9350 that would work perfectly, and tell windows not to use the unsigned USB driver in the headset firmware.
Fortunately there is a quick-fix workaround... it is only a little bit of a pain (and proof that their $110 firmware upgrade is not necessary).
When you want to use the jabra with Win7:
1. Plug it into your computer via USB.
2. Go to your playback devices menu (right-click the speaker icon in the system-tray)
3. Set the GN 9350 as the default device for recording and playback.
(right-click, and test, should error (couln't play test tone)
4. unplug the power to the reciever/base.
5. wait 10 seconds.
6. plug it back in.
7. may need to set it as the default again, but you should be good for a while, just don't switch back and forth too much between computer and phone.
Oct 03, 2011 | GN Netcom GN 9350 Wireless Headset
Need radio cd wiring diagram for 2005 jeep grand chrokee
120706502.jpg FUNCTION PIN WIRE COLOR Accessory 12 Volt SEE NOTE ¹ Constant 12 Volt 1,12 RD/OG (2X) Chassis Ground 11,22 BK (2X) Power Antenna Remote Illumination Dimmer FUSE VALUE FUSE LABEL FUSEBOX LOCATION 20 AMP #28 DRIVER'S SIDE UNDER HOOD ¹ The receiver does not have an Accessory 12 Volt lead, it is triggered by the data lines in pins #5 and #6. When installing an aftermarket stereo, an Accessory 12 Volt lead must be run to the fusebox to a switched power lead.
² If equipped with "Hands-Free" cellular phone system.
The dash speakers are wired in parallel with the front door speakers.
Left Front Spkr + 10 D.GN Left Front Spkr - 9 D.GN/BN Right Front Spkr + 7 GY Right Front Spkr - 8 GY/BN Left Rear Spkr + 18 D.GN/D.BU Left Rear Spkr - 19 D.GN/VT Right Rear Spkr + 21 GY/D.BU Right Rear Spkr - 20 GY/TN Hands-Free Audio ² 4
16
17 D.GN/OG
D.GN/YW
D.GN Data Lines 5
6 WT/OG ¹
WT ¹ DO NOT USE THESE WIRES!
Sep 25, 2011 | Car Audio & Video
I'm hooking up my sony player to a nissan versa and the colors are confusing and I'm tryna get it to work , and it wont
Car Colors (Assuming NON-Rockford factory system)
4-6 speaker system.
Accessory 12 Volt L.GN
Constant 12 Volt BN
Chassis Ground BODY
Power Antenna
Remote
Illumination OG
Dimmer (-) Bk
Left Front Spkr + WT
Left Front Spkr - BN (PK @ Spkr)
Right Front Spkr + GN
Right Front Spkr - L.BU (RD @ Spkr)
Left Rear Spkr + VT (L.GN @ Spkr)
Left Rear Spkr - RD (GY @ Spkr)
Right Rear Spkr + L.GN
Right Rear Spkr - GY
CLICK HERE for generic wiring tips for your radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 19, 2010 | Sony XPLOD CDX-GT200 CD Player
GPS Logo
46 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
